Author Topic: Mx Revolution soft middle click MOD.  (Read 6939 times)
Offline The Solutor
« on: Tue, 31 May 2011, 21:02:14 »
Quick and dirty mod here.
As you know MX revolution have a bit too stiff middle click with partly breaks its role of best mouse ever.
So I modded it in the same way I modded the little brother VX.
So let start
#1 remove the three antifriction feet (and put them in a safe place)
#2 Unscrew the four screws.
#3 open the mouse slowly and disconnect the flat cable who connects the upper and lower halves of the housing
#4 unscrew the 1 screw on the photo and pay attention to the small plastic block, then remove the wheel assembly
#5 remove (or shorten) the tiny spring responsible for the middle click stiffness
#6 reassemble the mouse.
#7 optionally use the aftermarket teflon feet instead of the original ones.
That's all I hope it helps.
Offline himynameisbunny
« Reply #1 on: Tue, 21 June 2011, 00:23:28 »
Wonder if this works with a Wireless Trackman M570. It's really nice save for the really stiff scrollwheel.
[SIGPIC][/SIGPIC]
Happy Hacking Keyboard Pro 2 // Logitech M570 Trackball // Topre Realforce 23UB
Offline The Solutor
« Reply #2 on: Tue, 21 June 2011, 03:03:48 »
I had only mice with the inertial wheel since 2006, and even before I never felt the old style wheel as stiff.
So I can tell that this mod works surely on most of the mice provided with the inerthial wheel, but I can't say a lot about the older ones.
BTW check if thhe spring was present on the latter is matter of 5 minutes of work, so just check yourself, and let me/us know if it's possible.
« Reply #3 on: Wed, 22 June 2011, 08:01:01 »
Hmmm...might give it a go tomorrow after hours at work. Was using the middle click today and I gotta say it's a mighty pain in the bee-hind. Makes it feel like a $5 mouse you buy from your local IT supply joint.
Sent from my Vega using Tapatalk
[SIGPIC][/SIGPIC]
