Author Topic: Introducing: The CM Storm Trigger  (Read 79772 times)
Offline The Solutor
« Reply #150 on: Tue, 30 August 2011, 15:46:44 »
Quote from: JackA$$;407608
There is no reason for me to buy a Trigger anymore.
:lol:
Offline Chobopants
« Reply #151 on: Tue, 30 August 2011, 15:51:28 »
Now it happened...
Razer will release a new Black Widow Ultimate.
MXBrown, no glossy and 6KRO. There is no reason for me to buy a Trigger anymore.
O_O The Storm still looks more attractive to me. Not into BWUs.
« Last Edit: Tue, 30 August 2011, 16:21:27 by Chobopants »
Realforce 87UW 45g - Filco Blue 87 - Filco Linear R - Filco Brown 104
Offline Tallon
« Reply #152 on: Wed, 31 August 2011, 23:14:11 »
Quote from: False_Dmitry_II;393884
I didn't do up that picture. So I'd also tell them what it's for so they can make the holes a good size. I don't know who did do up the picture, but I don't mind if it's done at all. If it was this would also be the first one that would allow that to be done. I think I would say that I'd prefer legally if any company could do it. Sort of an open source-ish idea, if you get what I mean.
I really wish they had implemented this - I would have purchased two keyboards and done some modding. Oh well. Looks like it'll be red, black, blue, and brown - no clears. ;(
Offline battlesheep
« Reply #153 on: Thu, 01 September 2011, 05:57:16 »
Quote from: Lanx;393468
i'm using the cm inferno, the software is junky, everytime i bootup the software it recalibrates my mouse, so i loose my settings, currently there's no way to turn this off, so what happens? i never turn on the software, so it's useless.
the mouse software is all buggy and is a chore to make macro's with.
i'd actually would junk this mouse if i didn't mod it to be awesome
*edit
oh and only 2 of the 5 modes work, but that may have been my fault since i've modded it.
ha, awesome! :D love the mod :D
tell you what, once i worked my way through everything that piled up while i was in europe, ill check out the inferno driver and do my best to get it worked out in case i can reproduce your probs, alright? :)
its from before my days tho, havent played much with inferno at all tbh...
i dont think wed sue anybody over this... especially if we didnt come up with it... just worried we do it and then somebody sues US... especially since this will only be interesting to a very small percentage of users after all...
Quote from: N8N;393994
When I pop the top on a Cherry switch, I use two jeweler's screwdrivers... if you look at the top of the switch, there's a little rectangular hole in each of the four corners.  If you stick a screwdriver with about a 2mm blade in one of those holes and pry, it'll release the two latches on that side.  then take the other screwdriver and jam it under the top so it doesn't pop back down, go to the other side and pop those two latches.  Harder to type out than it is to do, but it only works w/ PCB mounts because the plate prevents the latches from unlatching.  If you put those notches in the plate I think that that method would likely work.
If you wanted to be real slick you could probably make a little fork shaped tool precisely shaped and spaced to make the process slightly quicker.  Or even something like snap ring pliers with two forks, to pop all four latches at once.  The last might be more idiot proof because then you wouldn't put any bending stress on the solder joint if you got all ham-handed with it.  Or if you had two snap ring pliers with tips about the right size that might work too, haven't tried that (yet.  Just got that idea as I was typing this post.)
I'm sitting here behind a board w/ plate mounted Cherries and a spaghetti sauce jar full of clear stems and springs, just waiting for my new soldering iron to show up :P  Might have to go retrieve my Dremel and try the plate mod just to see if it'll work.  I don't know if I have the patience to Dremel out four little reliefs in each of 104 cutouts though... but if the plate is stamped or laser cut in production, no biggie.
Of course, if I modded my plate I'd have to repaint it, giving me the opportunity to do paint it Safety Orange, or something like that.
cool! if it does work, let me know!
our PMs here werent really blown away by the idea, but id like to push for it since itll make our keyboards very geekfriendly at 0 added cost :D
Quote from: JackA$$;401882
Hey Ho,
Some news from the Gamescom 2011. Finally in Germany the CM Storm Trigger will be released next month for 100-120 EUR.
Cherry MXBlack will be used for the main-keys and Cherry MXRed for the macro-keys.
Click me for more Info
I do not know if i should believe him, he says that the BlackMX are having a tactile feedback and the RedMX should be Clicky... wtf?
Could battlesheep enlighten us?
and i thought I was camera shy and start talking gibberish :D
I think rene was a little nervous and mixed some things up :)
to clarify, the EU version is gonna be all black
Quote from: DeltaGunner;402139
I heard from a contact of mine at CM Storm that the Trigger is pushed back to 2012.
Also I guess it would be more likely to assume that there will be 4 'full' versions ie. one full blue, one full brown, one full black and one full red.
This of course is just what I would expect.
would be new to me...
but yes, itll be all black, all red etc...
Quote from: kaiserreich;402151
Just came across this, a Tenkeyless CM Mech keyboard with detachable cable.
source: http://www.pcwaishe.cn/thread-188760-1-1.html
youre from malaysia but have a german nickname and posted on a chinese website? a fellow geek-vagabound? :D
let me know when youre in taipei, maybe we can meet up :)
its nice eh? for me a tenkeyless is actually interesting, oddly enough at i43 nobody liked it too much...
a lot of people said they use the numpad area in games... weird...
Quote from: DeltaGunner;402576
Wow that tenkeyless looks really nice, and its much cleaner looking than the full size keyboard with all the case details. This just has a **** load of CM Storm logos which isnt even bad.
Detachable cable is something I never had so I dont know how much of an improvement it will be.
Still hope this one has backlight. but looking at f9-12 cluster it certainly looks like it.
yepp, love the slick design!
i wish trigger couldve had a more slick shape like this one... :(
about the cable, its quite convenient... you can unplug the keyboard real fast and plug it back in again... if you want to clean your desk for example
and i use the same for my mp3 player, so i got a cable like this on my desk all the time and can plug the KB in and out quickly...
but if you dont move it a lot, it wont make a difference...
Quote from: False_Dmitry_II;402689
If you use it in more than one place, just get cables that can sit there. If it gets destroyed, just get a new cable instead of soldering it back together. I really would prefer it if most keyboard cables were like that.
exactly...
Quote from: PeeJeff;407100
Macros are useless TBH, they're just a gimmick to sell more... heck, they're illegal in all the sc2 tournaments I go, why would I bother using them... I'd rather have backlit and a usb/hub.
depends on what youre doing...
for most people, i agree though...
honestly i dont get why macros are banned in sc2 though... its not like it would be a bot match then... not at all...
a macro can only do so much, it will always only be able to do so much, what it really does is help the player to spend less time doing stupid repetitive tasks and work out some real strategy and macro task the units etc...
but i guess im representing a minority here... :P
Quote from: flaming_june;407207
There are other instances where macro keys work wonders.  Hence I'm looking forward to the ttesports G unit, with 12 keys (even 2-2-2 per column).  It works well with SC2 where you don't have to reach all the way to the right for 5-0 keys.  Even one of those keys can be bound to pop two or three types of potions simultaneously in games like Diablo 2, or mmorpgs.  Just because macros are not allowed in tournies, doesn't mean you couldn't use them for single keys, or use macros at home for other games.
Unfortunately it took CM too long.  I bought a BWU to hold me over til esports releases their Meka G unit keyboard.
just out of curiousty, why do you like the G unit?
Now it happened...
really? wow!
Quote from: ripster;407887
These are supposedly 50g.
Have any Yuan or USA Nickels?  RipOmeter.
mhhh pretty busy now, ill try to remember doing it when i got some more time k?
btw, video about both keyboards at i43, cheers to the guys from OC3D!
was a blast hanging out with them :D
http://geekhack.org/showthread.php?21446-Has-anyone-been-watching-the-new-CMStorm-keyboards-Interesting-interview-from-i43
Offline battlesheep
« Reply #154 on: Thu, 01 September 2011, 05:58:04 »
Quote from: Tallon;408504
its not like these two are our last and only keyboards ;)
Offline slueth
« Reply #155 on: Thu, 01 September 2011, 06:53:13 »
@battlesheep: buckling springs are awesome and if CM makes a modern looking board with it you can have all my money(not much).  Maybe CM could get into touch with Unicomp and they make a deal so that we can finally not have an ugly buckling spring board. Win/Win for both companies. I know a bunch of users would love a modern tenkeyless buckling spring board.
Offline zulios
« Reply #156 on: Thu, 01 September 2011, 07:42:45 »
Quote from: battlesheep;390811
cant wait to try an ergo clear, cause clear does feel a liiiiittle stiff...
Hi,
Just wondering : do you feel clears to be stiffer than blacks ?
Tipro matrix - mx black
Offline False_Dmitry_II
« Reply #157 on: Thu, 01 September 2011, 21:47:24 »
Quote from: slueth;408654
I dunno about tenkeyless, but I would say that would be a very interesting board.
Offline Tallon
« Reply #158 on: Thu, 01 September 2011, 23:41:06 »
Quote from: battlesheep;408639
Good :)
Offline battlesheep
« Reply #159 on: Mon, 05 September 2011, 02:08:25 »
Quote from: zulios;408664
Hi,
yeah, its probably cause of the bump...
same with blues and reds, they use the same spring as far as i can tell, but blue feels harder cause of the click which adds extra pressure and momentum you have to overcome...
you shouldnt have mentioned you dont have a lot of money :D
but yeah, i already ordered a sample and cant wait to play with it :)
btw, got a new toy today, a black/grey cherry switch, has anybody ever seen one of those?
the top is grey, the bottom is black, the switch stem is black too
Offline The Solutor
« Reply #160 on: Mon, 05 September 2011, 03:02:58 »
Quote from: battlesheep;410775
Clear and black are different the clear spring is softer at the start and stiffer at the bottom of the keystroke and viceversa.
Offline DeltaGunner
« Reply #161 on: Mon, 05 September 2011, 05:08:24 »
Isn't that one of those tumbling switches. Press first time and it stays, press it again to reset back.
Too lazy to look in the wikia so just my guess.
[SIGPIC][/SIGPIC]
Keyboards:
Razer BlackWidow Ultimate
Wishlist:
DAS Ultimate Model S Ultimate Silent, or atleast some other Cherry Brown
Mice:
Logitech Trackball
Logitech Trackman Wheel
CM Storm Sentinel Advance 5.600 DPI
Switches:
Blue
Want to try:
Black, Brown, Red and BS
Offline battlesheep
« Reply #162 on: Mon, 05 September 2011, 23:52:38 »
Quote from: The Solutor;410788
oh really... i thought cherry only uses 4 or so different types of springs and thats that... interesting!
Quote from: DeltaGunner;410811
yeah, youre right, its an on-off switch... could be useful for LED backlight or other stuff like that i guess... :)
Offline battlesheep
« Reply #163 on: Tue, 06 September 2011, 00:04:37 »
mhhhh i measured the pressure of the different switches with piles of YUAN and posted it here a few weeks ago... but the post has been removed? 0_o
Offline slueth
« Reply #164 on: Tue, 06 September 2011, 00:07:37 »
hmm shouldn't be removed
Offline shogrran
« Reply #165 on: Wed, 26 October 2011, 09:59:44 »
Does this come in MX Blue or MX Brown?
Razer Blackwidow Elite
CMStorm Quickfire Rapid
[SIGPIC][/SIGPIC]
« Reply #166 on: Wed, 26 October 2011, 17:27:31 »
Quote from: shogrran;439721
Yep. It'll have a gunmetal grey case colour, and (I believe) a black plate. The one in MX red has a black case, a red plate, and chinese on the keycaps.
It also comes in black, I believe.
Offline slueth
« Reply #167 on: Fri, 28 October 2011, 19:48:58 »
Whats with that ugly little ridge at the top of the keyboard lol.  If it doesn't do anything just remove it or make it flat.
Offline battlesheep
« Reply #168 on: Fri, 27 April 2012, 05:51:17 »
hah... wow, its been a loooong time... trigger is finally out :D
any comments? has anybody given it a try yet? :)
Offline Stn
« Reply #169 on: Sat, 12 May 2012, 03:32:14 »
Quote from: battlesheep;583732
When is the US/Canada release? Which switches will be available right away?
Offline JackA$$
Re: Introducing: The CM Storm Trigger
« Reply #170 on: Wed, 01 August 2012, 02:13:17 »
CM Storm, CM Storm, CM Storm... i don't know if I should laugh or if I should cry. The Trigger was my favorite mecha, but the MX Black switches killed it for me (already have 3 keyboards with MX Blacks and the market is full of MX Blacks).
Why did you not listen to me and released the Trigger as the first mechanical keyboard with MX Red switches and non US-layout? So many gamer would have bought it.
Today almost all manufacturers/suppliers offers a mechanical keyboard with MX Red switches and the people are happy.
Till now I don't understand the decision why CM Storm build in MX Blacks in the Trigger while so many other mechanical keyboards uses the same type of switches and the market was overcrowded with this type of keyboard..
Offline rudyzhou2
« Reply #171 on: Fri, 03 August 2012, 13:17:36 »
need to get rid of that logo... mannn
Offline -36-
« Reply #172 on: Thu, 16 August 2012, 13:59:09 »
Does anyone know if it's an Ione of Costar keyboard? I'm reading lots of confusing stuff on the internet (50% says Ione , 50% says Costar)
Offline Daniel Beardsmore
  • RIP
    • Boring twaddle
« Reply #173 on: Thu, 16 August 2012, 15:44:43 »
You don't need a new keyboard – you need typing lessons!
Bore Awards
Offline Carter
  • CM Storm Rep
  • * Commercial Vendor
« Reply #174 on: Thu, 16 August 2012, 16:33:57 »
Costar
-CM Rep
Offline lazerpointer
  • ya gotta stay phresh
« Reply #175 on: Mon, 24 September 2012, 17:46:32 »
Quick question (and first post on Geekhack!)
First of all I have the trigger :cool: I got it a week ago to test out the Brown switches, which I am pretty satisfied with... I'm beginning to acclimate. My question is; Does anybody know how easy it will be to change out the key switches? Specifically will I have to solder?
Getting a Ducky Shine 2 delivered to the office this week with MX Reds (Wow i never thought i would be so excited about a keyboard!) because I still haven't tried the reds yet. My thoughts are that I will like the reds a lot more, and want reds in my CM Storm Trigger. I know the ducky is switch-change-friendly so if i end up liking the browns better, I can just throw browns into my ducky.
i type, therefore i geekhack
Offline alaricljs
  • I be WOT'ing all day...
« Reply #176 on: Mon, 24 September 2012, 17:49:59 »
Wait WHAT?  Since when is the Ducky switch change friendly?  Especially with LEDs!!
Both boards are plate mount, both boards require desoldering to change out the switch or stem/spring.  The Ducky has twice as many leads to desolder since all the LEDs have to come out too.
Filco w/ Imsto thick PBT
« Reply #177 on: Mon, 24 September 2012, 18:02:15 »
thanks.... I guess I'll just have to sell the board if i REALLY refuse to go back to browns. or learn how to solder  :))
Offline HKD
« Reply #178 on: Tue, 25 September 2012, 14:12:16 »
I recently purchased a CM Storm Trigger from ncix.com for $80, which I believe is quite the deal. The only alternatives I was looking at in my price range ($70-80) were the Black Widow and Quick Fire Pro. I definitely liked the design for the quick fire pro a lot more, but then I saw the storm trigger, and instantly fell in love with how it looked. From the reviews I researched, it seemed like the storm trigger was a "better" quick fire pro, and once I saw that I could get the storm trigger for around the same price, I seized the opportunity quickly.
I should be getting it in the mail tomorrow, and then I can judge for myself how I like it. This is also going to be first mech keyboard ever, and from what I've heard, I'm going to love it.
On a side note... does anyone use custom keys + a back lit keyboard? I want to add some custom keys to my board (red QWER and some other keys) and I was wondering if anyone has seen how a storm trigger, or any other back lit keyboard looks with custom keys.
Thanks.
« Last Edit: Tue, 25 September 2012, 18:25:58 by HKD »
Offline wetto
  • Brazil's Keyboard Enthusiasts Representative
    • Portuguese Mechanical Keyboard Guide
« Reply #179 on: Tue, 28 May 2013, 18:24:45 »
Ressurecting a damn old thread, but for a good reason. There are almost NO pictures of this keyboard dissasembled or any disassembly tutorial on the internet. Anyways, here's mine:
Comparison between the external cover of the CM Storm Trigger against a Metadot Das Keyboard Model S Professional Silent.
Actually, the external cover of the Das Keyboard is a piece of crap. Just by trying to open it up, I broke 6 out of the 8 ****ty locks there were on it. The CM Storm Trigger is indeed built like a tank.
Now, what most people were waiting for...
And the controller (which got damaged due to a problem on the external power supply I was using, but somehow I managed to get someone to fix it and it's working):
Comparison between WASD white keycap vs Das Keyboard Model S Professional Silent keycap vs CM Storm Trigger Keycap (they're all Costar keycaps anyway)
Finally, a photo showing its rear (which is damn well made)
Rubber feet:
And the thing I hated the most on it: The connectors for its wrist rest, they're WAY too fragile.
« Last Edit: Tue, 28 May 2013, 18:27:11 by wetto »
My collection:
Mice: Logitech G602, CM Storm Recon, CM Storm Spawn, Razer Naga, Ozone Radon Opto, Corsair M60, Tesoro Gandiva, CM Storm Alcor, Mionix Naos 8200.
Keyboards: Matias Secure Pro, Matias Mini Quiet Pro, custom modded Metadot Das Keyboard Model S Professional Silent (MX Brown, Costar), CM Storm Trigger (MX Brown), Noppoo Choc Mini (MX Red), Tesoro Lobera G5NFL Supreme, CM Storm Devastator.
Soon: CM Storm Quick Fire TK (MX Brown), CM Storm Trigger Z.
Boards I don't own anymore: CM Storm Quick Fire Rapid (MX Black), Logitech K800 (Membrane), Logitech G710+ (MX Brown), Thermaltake Meka G-Unit (MX Black), Corsair K70 (MX Red).
Mice I don't own anymore: Logitech G9x MW3, Corsair M65, Logitech G700, Roccat Kone Pure.
Offline Photoelectric
« Reply #180 on: Tue, 28 May 2013, 22:59:34 »
Great work, thanks!! Could you also post a photo of the keyboard's back side with screw locations circled + any notes / tips on disassembly?
The wrist rest is surprisingly comfy despite being plastic.  I ended up detaching mine and just keeping it as close to the keyboard but to locked in, so I could move it out of the way periodically.
Offline wetto
« Reply #181 on: Wed, 29 May 2013, 07:27:29 »
Disassembling the CM Storm Trigger is easy as pie. First of all, there's 5 screws hidden under it and a few plastic locks (but you won't have to worry about them since they come off easily).
Flip up the heigh adjustment and remove the screws on each side. Remove the warranty seal on the middle of it and its screw. Now, using your nails, remove the two rubber feet on each side of the top of the keyboard (not the one on the middle) and remove its screws.
Now, here comes the easiest part (seriously, the CM Storm Trigger is 100x easier to open up than a Das Keyboard or a CM Quick Fire Rapid).
Using only your hands, start gently pulling the cover off, but try not to remove only one side of the keyboard. It's easy, just be gentle and it'll come off easily.
My collection:
Offline Jokrik
« Reply #182 on: Sun, 15 September 2013, 19:49:49 »
Thx for the guide wetto
Im gonna repaint the case is weekend!
Offline cspirou
« Reply #183 on: Mon, 10 June 2019, 08:20:58 »
Thanks for the teardown. I have this keyboard from 2013 and the 'T' switch is having some problems. It only works if I force it bit so it looks I'll need to open it up or replace it.
One question for @wetto (or anyone else that has opened this up), do you know what kind of microcontroler chip it uses?
Offline cspirou
« Reply #184 on: Tue, 18 June 2019, 02:15:38 »
I'm disassembling my Trigger right now and you made a mistake with this diagram. It's the pads at the bottom that are covering the screws, not the ones near the height adjustment feet.
I added some close up pics on the control board
« Last Edit: Tue, 18 June 2019, 03:55:38 by cspirou »
