Author Topic: IBM 1392980 Space Saving Model M 250$ BIN  (Read 3124 times)
Offline MissileMike
« on: Wed, 01 June 2011, 14:46:39 »
This seems a little high to me, but maybe space saver mania knows no limits.  First, you have to swap controller boards with a full sized M to even get it working.  And it's used.  And it has no good pic of the keyboard.
...but it's a ssk.
http://cgi.ebay.com/IBM-Model-M-1392980-Space-Saver-Keyboard-type-3151-/310322866706?pt=PCA_Mice_Trackballs&hash=item4840af2a12
BS: 5 Space Savers  ||  9 42H  ||  10 1391401 or similar  ||  1x 1390131  || AT&T 305b  ||  Dell Model M
Cherry: Leopold FC200RC/AB  ||  3 Ducky 1087  ||  PLU ML87 ||  Cherry G80-8113LUVEU-2  browns
Alps: Filco Zero Tenkeyless (fukka)  ||  ABS M1  ||  3x Dell AT101w  ||  Ancer KF-191  ||  6 Vivanco Compact
Misc: NMB RT6855T+  ||  NMB RT101 Space Invader  ||  Dell Quietkey  ||  Ge Fanuc Industrial Metal
Offline litster
  • rare caps?! THAT'S A SMILIN
« Reply #1 on: Wed, 01 June 2011, 15:20:08 »
So you would need to buy a regular Model M to swap the controller board?  But then the embedded numpad would not work, right?
Offline DaemonRaccoon
« Reply #2 on: Wed, 01 June 2011, 15:22:20 »
Build an adapter, call it good.
122-Key Model F 6110345 1985-03-01 | Model M SSK 1391472 1991-01-22 | Rosewill RK-9000 v1 | KBC Poker X | Filco FKBN87M/PWE2
Offline Ascaii
« Reply #3 on: Wed, 01 June 2011, 15:23:23 »
or a teensy and make it USB native?
250$ is over the top for this
Offline MissileMike
« Reply #4 on: Wed, 01 June 2011, 15:32:21 »
Quote from: litster;354292
Correct.  But does anyone ever use it anyway?  I never have.
Offline litster
« Reply #5 on: Wed, 01 June 2011, 15:53:34 »
Quote from: MissileMike;354302
For your own use, true.  For futher resale as a collectable item, that would lower the value.
Offline ch_123
« Reply #6 on: Wed, 01 June 2011, 17:16:29 »
You could adapt the controller to be PS/2 or USB compatible. I would NOT want to pay $250 for the luxury of doing that though.
Offline Tennobanzai
« Reply #7 on: Wed, 01 June 2011, 19:18:16 »
Lmao. These spammers are spot on with the intended audience
« Reply #8 on: Wed, 01 June 2011, 19:18:57 »
Quote from: Tennobanzai;354428
Soft? No! Clicky!
