Author Topic: Help - gotta type fast, fast, fast - all day long!!!!  (Read 2508 times)
Offline colbabe
« on: Wed, 01 June 2011, 20:42:22 »
Ideas, suggestions, anything welcome - i'm desperate!
Offline keyboardlover
« Reply #1 on: Wed, 01 June 2011, 20:47:46 »
Crystal Meth?
Offline DaemonRaccoon
« Reply #2 on: Wed, 01 June 2011, 20:55:20 »
Quote from: keyboardlover;354470
Crystal Meth?
Not even once.
Try a chorded keyboard? What exactly needs to be typed so quickly?
122-Key Model F 6110345 1985-03-01 | Model M SSK 1391472 1991-01-22 | Rosewill RK-9000 v1 | KBC Poker X | Filco FKBN87M/PWE2
Offline audioave10
« Reply #4 on: Wed, 01 June 2011, 22:52:45 »
Please stay away from the "5 Hour Energy drink".
This is what I drink...(with NO whip)
DECK Legend "Toxic" - SOLD
96 IBM Model M 82G2383- 95 IBM Model M 92G7453 - SOLD
Cherry G80-3000/Blues
new: MechanicalEagle Z77 RGB/Blues
Offline hoggy
  • * Ergonomics Moderator
« Reply #5 on: Thu, 02 June 2011, 01:15:21 »
I'm assuming this is a work issue...
Why do you have to type it?  Unless you're paid a bonus depending on your keystroke count I'd say eventually you'll just work yourself into some sort of upper limb disorder with the stress.  Usually, no-one will care how it's done, so why do it the hard way?
If you're typing the same paragraphs over and over - store them in word doc or a text file and just copy and paste.  Keep the file organised.  Keep adding to it.
If you are using word then investigate autotext and templates.
Texter will help you reduce your typing 'costs' very quickly.  You simply type in a trigger - thxe- could produce "Thank you for your email dated ".  kr- could trigger "Kind regards".  d- could trigger today's date.  Little savings will add up quickly.  Texter is free - which is nice.  It's better than word's autotext for this sort of thing.
Once you've made yourself a bit of breathing space, have a look at macro express or autohotkey.  I use macro express to set up function stubs - I just type the function name into a dialog box - so in about a second I've just 'typed' over 500 characters.
The time it takes to setup these things may be a pain when you start, but it's totally worth it.  Start small so you see the results quickly and use the time you save to setup more.  You'll also start to have a bit more control over how you do your work, it really helps your mood.
If your first thought is "but I type different stuff each day" - I understand - but look again at texter...
Offline igro
« Reply #6 on: Thu, 02 June 2011, 15:12:26 »
Just do more of those http://play.typeracer.com
Offline colbabe
« Reply #7 on: Thu, 02 June 2011, 19:53:52 »
I'm a word processor and my job is to type data all day at a high rate of production.  So looking for tips, assists, helps, etc.  What is a chorded keyboard exactly?
« Reply #8 on: Thu, 02 June 2011, 19:58:13 »
Quote from: colbabe;354931
Chorded keyboards are what court stenographers use (wiki here) they can achieve 375wpm.
Offline colbabe
« Reply #9 on: Thu, 02 June 2011, 20:04:15 »
Great tips and information!  I use word and content is usually different but I will definitely look at texter.  Thanks so much.
Offline hoggy
Offline ch_123
« Reply #11 on: Fri, 03 June 2011, 06:15:14 »
It's all down to practice.
Offline kpeezy
« Reply #12 on: Fri, 03 June 2011, 09:16:45 »
Quote from: igro;354776
This is great. Thanks for the link. Watch for the breeziest on the leaderboards! That's right.
« Last Edit: Fri, 03 June 2011, 10:06:57 by kpeezy »
