Author Topic: So I need a new keyboard...  (Read 3107 times)
Offline prpnightmare
« on: Wed, 01 June 2011, 22:30:55 »
Now, my Das Professional Silent is great, but I finally caught hell from my sister and dad for giving my mom an IBM Model M:) So, I was thinking of giving up the Silent and getting another keyboard as the Model M would not sit well for gaming and my light-ish typing style with a little more resistance than the Browns (I make more errors than I'd like because of it. The comfort is great though). The only Poker on ebay had Reds, and I'm not really sure if I'd like that, and don't want to spend $100 just to try it out. The obvious choice is another Das, but variety is the spice of life, so if there are any suggestions, I'd like to hear them.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #1 on: Wed, 01 June 2011, 23:42:49 »
if you want a poker theres always taobao. there seems to be some sources that have brown switches in stock.
Offline daerid
    • Rossipedia
« Reply #2 on: Wed, 01 June 2011, 23:57:35 »
You are saying that Brown's are too light? Well, you could always try clears. Or blacks.
Offline Ascaii
« Reply #3 on: Thu, 02 June 2011, 03:10:27 »
I'd recommend clears, you will want some tactility for typing. The blacks can be nice but do take some time geting used to.
Offline mbc
  • -delete-
« Reply #4 on: Thu, 02 June 2011, 03:15:03 »
Why don't you simply get a model M when it seems to fit you? It would be much cheeper then buying a new cherry mx kb.
Edit: or are you looking for something in between browns and buckling spring?
« Last Edit: Thu, 02 June 2011, 03:18:54 by mbc »
« Reply #5 on: Thu, 02 June 2011, 11:52:19 »
Yeah, something a little in between, with that oh-so-nice tactile bump but without the heaviness of buckling springs.
Offline daerid
    • Rossipedia
« Reply #6 on: Thu, 02 June 2011, 11:55:29 »
Clears are probably your best bet.
« Reply #7 on: Thu, 02 June 2011, 12:17:50 »
I can't seem to find a keyboard with Clears though, any suggestions? That's why I mentioned Blues, they seem to be much more popular.
Offline noodles256
  • le legendary
« Reply #8 on: Thu, 02 June 2011, 12:18:18 »
deck keyboards
AF | Ducky YOTD |
Offline sordna
« Reply #9 on: Thu, 02 June 2011, 12:27:41 »
Get blues... that's an easier switch to find, which seems to fit the sort of touch you want. You can install soft-landing pads to reduce the noise.
Offline daerid
    • Rossipedia
« Reply #10 on: Thu, 02 June 2011, 13:05:45 »
Quote from: sordna;354715
They're still crazy loud.
Offline sordna
« Reply #11 on: Thu, 02 June 2011, 13:31:54 »
C'mon, dampened blues are quieter than buckling springs, no?
Offline theferenc
« Reply #12 on: Thu, 02 June 2011, 14:26:45 »
But still much higher pitched, so the perceived loudness is actually quite a bit higher. I convinced one of the HCI people here to do a user study on this. Blues are consistently rated as the loudest mechanical switch, even though they are actually quieter than buckling springs.
It's just how our ears work, I suppose. I've heard claims it has to do with children having higher pitched voices, but I don't know how true that is.
Offline daerid
    • Rossipedia
« Reply #13 on: Thu, 02 June 2011, 22:29:59 »
I've always worked it out to be due to the fact that higher frequency sounds actually have a higher quantity of vibrations per section.
For example: 30db @ 1KHz has 10 x the number of vibrations as 30db @ 100Hz. Thus, higher frequency sounds are perceived as louder.
Idunno, makes sense to me.
Offline aggiejy
« Reply #14 on: Thu, 02 June 2011, 23:31:56 »
prpnightmare: I was in just about the same boat as you.  I had the Das Pro Silent and liked it.  I recently got the Leopold tenkeyless (because I wanted more mouse room) with blues and I really like it.  Though, I wouldn't say it's lighter at all... feels close to the same I guess.  However, I like the audible click once you pass the threshold as it helps me not to bottom out at much or as hard.  That said, I do enjoy going back and typing on the browns from time to time... variety is nice to have!
