Author Topic: [Chrerry MX Brown] [Filco] Tenkeyless vs. Full-Size (104)  (Read 3541 times)
Offline Peleg
« on: Thu, 02 June 2011, 13:57:21 »
Filco with Brown Switches.
Any differences between Tenkeyless and 104 ?
The Numpad is not important to me.
thank you
Offline noodles256
  • le legendary
« Reply #1 on: Thu, 02 June 2011, 13:58:26 »
Omg, why do you start so many threads about the same topic (pretty much)?
If the numpad isn't important to you, the answer should be obvious.
/thread
AF | Ducky YOTD |
Offline SecrtAgentMan
« Reply #2 on: Thu, 02 June 2011, 14:01:46 »
As ^ said
If the numpad is of no use then get the tenkeyless.
It's not very hard to use the number keys anyways.
Offline noodles256
  • le legendary
« Reply #3 on: Thu, 02 June 2011, 14:38:33 »
for a pro hacker, you sure are dumb.
AF | Ducky YOTD |
« Reply #4 on: Thu, 02 June 2011, 15:03:01 »
Ummm....
Offline Zet
« Reply #5 on: Thu, 02 June 2011, 15:47:31 »
Going a little bit back on topic, think if a switch gets messed up, and you have the skills, time, and tools, with the 104 key layout you could take the switch from another useless place, and replace it with the one that got fked up :D
Offline flaming_june
« Reply #6 on: Thu, 02 June 2011, 16:19:05 »
We need more bumps for this thread people!
Offline scribble
« Reply #7 on: Thu, 02 June 2011, 16:21:44 »
Get the tenkeyless if you want a smaller more compact and cheaper keyboard.
if you need the numpad then get the 104-key.
Filco Majestouch Tenkeyless Cherry MX Blue | PLU ML-87 Cherry MX Red
