Author Topic: How hard would it be...  (Read 2024 times)
Offline scribble
« on: Thu, 02 June 2011, 16:42:54 »
To take Browns out of a cheap Adesso and put them into my filco if i like them?
I'm thinking about getting browns to try now but I don't think that I'd want to get another filco because of how expensive they are.
I've heard of people modding keyboards, is what they mean?
Filco Majestouch Tenkeyless Cherry MX Blue | PLU ML-87 Cherry MX Red
Offline DaemonRaccoon
« Reply #1 on: Thu, 02 June 2011, 16:47:15 »
That depends, how good are you with a soldering iron?
122-Key Model F 6110345 1985-03-01 | Model M SSK 1391472 1991-01-22 | Rosewill RK-9000 v1 | KBC Poker X | Filco FKBN87M/PWE2
Offline daerid
    • Rossipedia
« Reply #2 on: Thu, 02 June 2011, 17:20:08 »
You don't need a soldering iron, you can just pop the tops off the switch and swap the stems/springs.
There should be a Wiki entry on that, just look for it.
Offline Dox
« Reply #3 on: Thu, 02 June 2011, 17:23:05 »
Quote from: daerid;354828
Yes you do need a soldering iron. The flico is plate mounted so you need to de-solder each switch in order to open it.
ErgoDox x2 | DoxKB x2 |   IBM SSK   | HHKB pro2
Offline daerid
    • Rossipedia
« Reply #4 on: Thu, 02 June 2011, 17:33:07 »
****ake... you're right.
Offline Dox
« Reply #5 on: Thu, 02 June 2011, 17:54:11 »
I've de-soldered all the 104 switches from a G80-3000 mx blue with 4 solder points each. Then, I've opened each of them to remove the useless wire in the diode cavity and swap some of the stem for a cherry clear stem. All in all, desoldering 104 switches, opening 167 switches and reassemble the switches (not on the keyboard) took around 4 hours.
Offline noodles256
  • le legendary
« Reply #6 on: Thu, 02 June 2011, 17:59:07 »
desoldering is like making sandwiches. takes practice
AF | Ducky YOTD |
Offline Orphagn
« Reply #7 on: Thu, 02 June 2011, 18:01:51 »
Quote from: ripster;354866
I have women make me sammiches.
You trust women with your food? lol
Keyboards:
KBC Poker
Cherry G80-11900
Cherry G80-3494
Offline Dox
« Reply #8 on: Thu, 02 June 2011, 18:10:31 »
I do have some previous soldering experience but the most important thing is to get a good technique/position to remove the switches and just keep on going. I got to say that the hardest part for me was my left thumb getting tired from pumping the de-soldering pump. It may seem kinda weak but pumping that thing over 400 times isn't an easy task.
Offline Dox
« Reply #9 on: Thu, 02 June 2011, 18:20:15 »
The jumpers are indeed harder to remove. I use a pump that look a lot like this one:
Offline scribble
« Reply #10 on: Thu, 02 June 2011, 18:35:18 »
Alright, I guess it's not gonna happen!
Well anyway, something random just started happening, I'm realizing when i hit my enter key, i can hear a metal "ding" noise echo about the board.
I can get this noise to happen when i tap on the board near the enter key as well.
Filco Tenkeyless
Offline scribble
« Reply #11 on: Thu, 02 June 2011, 19:07:40 »
hahah holy sit! no way you actually did that... so how common is this then?
Offline BucklingSpring
« Reply #12 on: Thu, 02 June 2011, 19:47:26 »
Quote from: ripster;354902
Spring ping.
Fix by adding lead to the keyboard (probably my craziest mod) or sticking on a mousemat like the Xtrac SuperXXL.
I wouldn't mind adding this kind of lead to my XArmor.
Boards I own, click ->
