Author Topic: I NEED a new baller a$$ monitor  (Read 4216 times)
Offline benis
« on: Thu, 02 June 2011, 22:08:41 »
This 23" acer just ain't cuttin' it any more.
I'm thinkin' Dell 27" or 30". Looking for opinions on whether to get 1080p or higher...
of course all opinions are welcome.
Offline sndstrm
« Reply #1 on: Thu, 02 June 2011, 22:28:25 »
Depends on if your video card can push resolutions higher than 1080p.  I like the Dell Ultrasharps but all the buzz right now goes to the HP ZR30w.
But the HP does not have near as many I/O ports as the Dell U3011.
Both of these are 30" IPS panels which is, indeed, baller a$$.
rm -Rf /*
Offline ironman31
« Reply #2 on: Thu, 02 June 2011, 22:34:15 »
Get 2 dell 2209wa's. You can get two for around 500 on ebay. I bought my second one from printersplusmore.
Keyboards:
IBM Model M Space Saving Keyboard (Used), HHKB Pro 2 (White, Lettered), Realforce 87U all-45g in White, Filco Majestouch 2 TKL with Cherry MX Browns, Model F PC/ATNoppoo Choc Mini (MX Browns), Model F XT, IBM Model M 1397735 (bought NIB), (2) Siig Minitouch (GHSS) one with XM, one with complicated ALPs (modded),2 Dell AT101W, Cherry G80-11900HRMUS (modded with MX browns)
Pointing Devices:
Offline benis
« Reply #3 on: Thu, 02 June 2011, 22:45:29 »
I'm done with dual monitors. I realize now my mind can only ever look at one screen at the time, meaning I might as well alt+tab rather than pay 250 for a second monitor. This is definitely one of those GO BIG OR GO HOME situations.
After looking at a few reviews Ill probably get a nice 27", gotta choose between Dell/HP/Apple/???.
Offline chongyixiong
« Reply #4 on: Thu, 02 June 2011, 23:11:01 »
Get the U2711 before they are phased out for the newer (bleargh) 16:9 IPS monitors.
Or if you're hardcore enough, you could try this - remove the Anti-Glare (AG) coating as it makes pictures definitely MUCH clearer and brighter and contras levels will go through the roof yo!
http://forums.overclockers.com.au/showthread.php?t=878149
(Although the general consensus is that the maintenance's a ***** once u remove the AG layer)
Offline benis
« Reply #5 on: Thu, 02 June 2011, 23:38:24 »
why not just buy an AG display then?
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #6 on: Thu, 02 June 2011, 23:59:09 »
ag removal is risky. i gave it a go on my old samsung 205bw. it was not a success. the glue was very very strong in the center and resulted in the polarizer layer being torn.
another suggestion is LG ips. they use the same panels as the dells (lg makes them) and are cheaper. the trade off is that they are only 1080 even at the larger sizes. there are also some asus ips and mva models available too.
the current apple models are display port, so your gpu must have a display port. there are not controls available for anything as its all done in software. which there is none for windows. you might as well take the cinema display off your list if you're not on a mac as nice as it is.
Offline sndstrm
« Reply #7 on: Fri, 03 June 2011, 08:34:39 »
I think all the buzz for the HP ZR30w comes from Maximum PC and PC Gamer mags and is then channeled through OCN.  I want the U3011.  I actually had one in my shopping cart at dell.com but things went... awry.
rm -Rf /*
Offline alaricljs
  • I be WOT'ing all day...
« Reply #8 on: Fri, 03 June 2011, 08:57:45 »
U3011 25% off...
Dell UltraSharp U3011 30-in 2560 x 1600 IPS-panel LCD Monitor
List Price: $1,499.00
You Save: $375.00 (25%)
Price: $1,124.00 + FREE SHIPPING
Expires June 9th, or after 1000 uses
Use the coupon code: PK541WQ0GXF8D6
Filco w/ Imsto thick PBT
Offline mbc
  • -delete-
« Reply #9 on: Fri, 03 June 2011, 09:13:05 »
Quote from: benis;355013
you do realize that "your mind" wount be able to look at the entire screen at a time, without you sitting quite far away?
Offline benis
« Reply #10 on: Fri, 03 June 2011, 09:29:52 »
yeah, i cant describe it, but its like my mind forgets the other monitor is there and just tunes it out. Also with 2 monitors it looks off center and kinda crappy imo. Where did that coupon code come from? Is there one or the 27"? also are there any high quality glossy displays? I like this and i  could probably get it for less than 600 bones. http://h10010.www1.hp.com/wwpc/ca/en/ho/WF06b/382087-382087-3284302-215012-215012-3757979-3757982.html
Offline alaricljs
« Reply #11 on: Fri, 03 June 2011, 11:39:53 »
Quote from: benis;355170
I got it from Anandtech's forums, and that dude got it from SD.  No idea what SD is, other than South Dakota...
Offline DaemonRaccoon
« Reply #12 on: Fri, 03 June 2011, 11:46:51 »
Quote from: alaricljs;355161
U3011 25% off...
God dammit! If only I had $2500 right now I'd purchase a pair.
122-Key Model F 6110345 1985-03-01 | Model M SSK 1391472 1991-01-22 | Rosewill RK-9000 v1 | KBC Poker X | Filco FKBN87M/PWE2
Offline benis
« Reply #13 on: Fri, 03 June 2011, 13:51:57 »
Quote from: ripster;355226
Or you could get one NEC 30 incher for that.
Maximum PC's recommended rig in their latest issue was 3 of those in portrait with some serious graphics card processing power behind it.
Link?
Offline benis
« Reply #14 on: Fri, 03 June 2011, 15:36:13 »
DAYUM! that's one expensive monitor. I was thinking in the <$1000 range. I hope no one thinks of me as any less hardcore since I won't spend $2500 on a display.
Offline audioave10
« Reply #15 on: Fri, 03 June 2011, 15:44:48 »
I could buy one, but I'm already close enough to a 27" TN Samsung that looks nice to me. (my eyes are also very old)
I think eventually I'll have to try an IPS screen. Ultimate Geekdom calls.
DECK Legend "Toxic" - SOLD
96 IBM Model M 82G2383- 95 IBM Model M 92G7453 - SOLD
Cherry G80-3000/Blues
new: MechanicalEagle Z77 RGB/Blues
Offline benis
« Reply #16 on: Fri, 03 June 2011, 16:16:00 »
Quote from: audioave10;355306
I agree.... I meen, I could only imagine a screen without ips... Well it's probably no better than a dirty ol' rubber dome keyboard!
Offline benis
« Reply #17 on: Mon, 06 June 2011, 11:38:45 »
Yo Rip, is there any input lag on your u3011? I will buy the u2711 unless you tell me there's lag. I'm a gamer and don't want any more lag than I have now :p the only thing i like about my acer is it's great(low) for lag, but now that I think of it, I notice all mac's i've used have input lag and those are the only IPS monitors I've used, and this has me worried. Is it still worth it given input lag factor?
Offline Lpb45
« Reply #18 on: Tue, 07 June 2011, 22:37:49 »
The u3011 does have a bit more lag then the zr30w (which I own) but its such a small amount sometimes I think the people who say they notice it are full of ****.  Both monitors are a great buy and will be great for gaming, you have to weigh the options I guess?  Do you want a scaler(u3011) which is good if your going to play your ps3 on your monitor which im not a fan of and why I have a 40" lcd tv or do you want less input lag(not really noticable), less inputs and a worse return/pixel policy(zr30w) although they did replace 2 monitors for me due to stuck green pixels right near the center of the screen and they didnt have to .
 If I had it do over again and the dell was on sale I would get the dell, thats not to say I dont ****ing love my zr30w though as its amazing but the dell is pretty equally amazing + a great return policy if you dont mind talking to Indians who claim to be named Adam if you have a problem.
Topre - 86U   |   Filco - Tenkeyless Linear Red
Filco - Tenkeyless Blue       |   Filco - Fullsize Non NKRO Blue (Work)
Offline bhtooefr
    • bhtooefr.org
« Reply #19 on: Wed, 08 June 2011, 10:27:28 »
You want baller-ass?
IBM T221, DG5, DGP, or DGM.
It's only 22.2", but who cares, when it's 3840x2400?
Offline sndstrm
« Reply #20 on: Wed, 08 June 2011, 11:32:26 »
Quote from: bhtooefr;357318
Those screens are so awesome *drool*
Here is one on ebay!
25ms response time lol
« Last Edit: Wed, 08 June 2011, 11:35:59 by sndstrm »
rm -Rf /*
Offline benis
« Reply #21 on: Wed, 08 June 2011, 11:56:16 »
I would never get this, lol as a gamer in every respect, i'd consider this a downgrade.
Offline benis
« Reply #22 on: Wed, 08 June 2011, 11:59:15 »
Quote from: ripster;357354
You can't be a baller with one 22" screen.
yeah, i think ill end up with the 27" dell, even if there was lag, it would be made up with picture quality.
What monitors(speakers) are those, im looking for an inexpensive set for my DAW setup.
