Author Topic: 2 Months Filco -> dead switch  (Read 2914 times)
Offline SNP
« on: Fri, 03 June 2011, 13:13:07 »
Hello,
I recently (2 months ago) bought a Filco Majestouch with MX Browns from Army Group. Today the S key just died on me. I had it on PS/2, tried it with USB too but it does not seem to work. I am back on my cheapo MS rubberdome.
I didn't even use it that much cause i was really busy @ work.
What is the warranty on the Filcos'? Can I send it to the EU distributor or must I send it back to taiwan? Any ideas/suggestions ?
Thank you!
PS. Sorry if I have posted it in the wrong forum. Please move it if it is misplaced :)
Offline SNP
« Reply #1 on: Fri, 03 June 2011, 13:28:58 »
Quote from: ripster;355258
Hmmm... I think this is one of the dangers of buying from a Taiwanese online reseller.  Sending it back would be spendy.   And unfortunately I don't know of a good online source of Cherry MX brown switches (mouser and digikey have large Minimum Order Quantities IIRC and mine are all used in my RipOmeter test keypad or I'd send you one).
Hmm is it easy replacing a switch? Removing the old one and soldering a new one in?
I guess it voids the warranty right?
ArmyGroup sells the switches individually , I guess I could order some from them.
Offline SNP
« Reply #2 on: Fri, 03 June 2011, 13:56:44 »
Thanks for your help! I just sent a message to ArmyGroup, hope they understand English!
Will probably send an e-mail to diatec too tomorrow.
Offline keyboardlover
« Reply #3 on: Fri, 03 June 2011, 14:15:09 »
Couldn't he buy a used Compaq mx11800 and use the spring and stem from one of its switches?
Offline bpiphany
« Reply #4 on: Fri, 03 June 2011, 15:25:52 »
What is the probability it is the switch and not a solder joint or other electrical failure? MX-switches seem pretty sturdy and repairable to me. If the option is to take it apart anyhow the OP might as well do that and investigate the problem further before trying to get a new switch
Offline Incognetus
« Reply #5 on: Fri, 03 June 2011, 20:44:31 »
Any suggestions on how to get the switch out of the keyboard?
Offline bpiphany
« Reply #6 on: Sat, 04 June 2011, 02:16:12 »
Quote from: Incognetus;355380
Yes, a PH2 screwdriver, a butter knife and a soldering iron. Honestly
Offline SNP
« Reply #7 on: Sun, 05 June 2011, 12:58:54 »
I am an impatient man!
Opened up the keyboard, saw that one of the switch's pin was not soldered very well (it was a bit higher than the pcb, as if it was levitating). Unsoldered, resoldered, everything works like a charm.
I'm off the warranty (destroyed that beautiful white OK sticker) but I was too lazy sending the keyboard back to Taiwan anyway :P
Hopefully no other problems will occur, or if they do occur they can be easily fixed :)
Thanx all for your assistance :)
