Author Topic: Ipad2 with Happy hacking keyboard 2?  (Read 6477 times)
Offline lam47
« on: Sun, 05 June 2011, 04:15:58 »
Hey all. Long time no see.
I'm looking at getting an iPad 2. I was wondering if there is a way to get my HHKB2 to work with it.
I saw it done with the first iPad using the camera adapter. Can this still be done?
Thanks sexys.
X
Keyboards. Happy Hacking pro 2 x2. One white one black. IBM model M US layout. SGI silicone Graphics with rubber dampened ALPS. IBM model F. ALPS apple board, I forget what it is. And some more I forget what I have.
Typewriters. Olivetti Valentine. Imperial Good Companion Model T. Olympia SM3
Offline litster
  • rare caps?! THAT'S A SMILIN
« Reply #1 on: Sun, 05 June 2011, 13:39:31 »
This adapter? Maybe I should try it with my ipad 1.
http://store.apple.com/us/product/MC531ZM/A
Offline litster
« Reply #2 on: Sun, 05 June 2011, 13:50:20 »
Quote from: ripster;355964
I recommend buying lots of iPads.
Do you work for Apple?
Offline prava
« Reply #3 on: Sun, 05 June 2011, 14:28:09 »
I should buy some AAPL stock myself, I don't think its likely they will go down any time soon: any new product range they start, its a success.
Offline lam47
« Reply #4 on: Mon, 06 June 2011, 11:11:26 »
Thanks guys. So we are going with a 'yes' it should work. But does anyone know for sure? I read something about the latest OS killing this trick with the camera adapter. Can anyone try it to be sure?
Thanks again.
X
Offline noodles256
  • le legendary
« Reply #5 on: Mon, 06 June 2011, 11:33:02 »
it will work.
[video=youtube;5AN4QT9ZC94]http://www.youtube.com/watch?v=5AN4QT9ZC94[/video]
« Last Edit: Mon, 06 June 2011, 11:36:03 by noodles256 »
AF | Ducky YOTD |
Offline mosquitoguy
« Reply #6 on: Sat, 25 June 2011, 23:40:04 »
Quote from: lam47;356260
Thanks again.
X
It doesn't work.   It used to work with the old 3.2 firmware, but not anymore... in fact, most if not all, USB keyboard stopped working with the ipad + camera adapter.
Offline litster
« Reply #7 on: Sat, 25 June 2011, 23:50:12 »
I am running 4.3.3 on my ipad1 and it works for me.  It will always say the USB device is not compatible with the camera adapter.  Just tap OK.  Then go to a text and type away.  It did stop working once for whatever random reason.  but a reboot of the device make it work again.
Offline The Solutor
« Reply #8 on: Mon, 27 June 2011, 08:46:54 »
Quote from: ripster;355980
Geekhackers laughed when hyperlinked and I said the iPad would be huge.
I laughed when I first saw the iPad, just because I had a similar sized (and way more featured) tablet since 2003.
Jack Bauer and the CTU members had a lot of TC1000/TC1100 too...
Offline sordna
« Reply #9 on: Mon, 27 June 2011, 10:50:09 »
We all laughed, but the only ones laughing now are AAPL shareholders! I can't believe there are STILL people lining up in some Apple stores at 5am.
Offline The Solutor
« Reply #10 on: Mon, 27 June 2011, 10:58:26 »
Quote from: sordna;368870
I think that things can only getting worse.
I already thought that one day or another I'll decide to disappear as Ettore Majorana did when become aware of the incoming slaughter, due also to its contribution
Offline stein
« Reply #11 on: Mon, 27 June 2011, 15:29:05 »
Nice to see that, for now, a USB keyboard works with the camera adapter.  Thanks for the video, noodles256.
Now I am wondering, if there is a way to have your iPad charging while using a USB keyboard.  Maybe there is some sort of dock that serves as a USB hub?  Perhaps one could modify Apple's iPad keyboard (which does charge your iPad while it's plugged in)?
Leopold Tenkeyless w/ Browns (FC200RT/AB)   |   Group Buy #3 (some SC2 keys)
Offline lam47
« Reply #12 on: Mon, 05 September 2011, 09:13:34 »
Yes, thanks very much for the video.
I hope to get my ipad2 this week and then next month my lovely girlfriend is going to buy me a blank white HH to go with it.
Lovely.
Offline spaceship
« Reply #13 on: Sat, 07 January 2012, 18:12:51 »
Just tried this with hhkbpro2 and an ipad 2. It does not work, and no error message is displayed on the screen. My filco works just fine.
Damn.
