Author Topic: Keyboard for coding , at home & work  (Read 8809 times)
Offline csharper19
« on: Mon, 06 June 2011, 10:07:13 »
Looking for a keyboard , I'm a coder.
Gonna use it in home and also in work.
I need tactile one , but non clicky.
I think Cherry Brown will do the work,
I figured this is the best switch for programming.
Tenkeyless is better because I gonna carry it to work and back every-day.
thank you
Offline noodles256
  • le legendary
« Reply #1 on: Mon, 06 June 2011, 10:09:27 »
wlcm 2 gh, looks like you already decided.
gl
AF | Ducky YOTD |
Offline daerid
    • Rossipedia
« Reply #2 on: Mon, 06 June 2011, 10:10:35 »
Sounds like you know what you want. Might I suggest a Filco?
Or... if you're fealing stealthy, you could try a Ninja
Offline hyperlinked
« Reply #3 on: Mon, 06 June 2011, 10:44:28 »
If you're looking for a Brown switch because you want something that's quiet you might be disappointed. While the switch itself is very quiet, the way the keyboards are made make them somewhat loud. If you're getting a Cherry Brown keyboard because of noise, you might want to look at a Topre instead or find a model of a Cherry Brown board that's not loud. The popular ones are all loud.
Topre: Realforce 103U Cherry: Filco Majestouch 104 (Brown), Ione Scorpius M10 (Blue)
Buckling Spring: IBM Model M1391401 ALPS: Apple Extended Keyboard II (Cream), ABS M1 (Fukka/Black), MicroConnectors Flavored USB (Black)
Domes: Matias Optimizer, Kensington ComfortType, Microsoft Internet Keyboard
Scissors: Apple Full Sized Aluminum
Pointy Stuff: Razer Imperator, Razer Copperhead, DT225 Trackball, Apple Magic Mouse, Logitech MX1000, Apple Mighty Mouse
Systems: MacPro, MacBook Pro, ASUS eeePC netbook, Dell D600 laptop, a small cluster of Linux Web servers
Displays: Apple Cinema Display 30", Apple Cinema Display 23"
Ergo Devices: Zody Chair, Nightingale CXO, Somaform, Theraball, 3M AKT180LE Keyboard Tray
Offline Tony
« Reply #4 on: Mon, 06 June 2011, 11:09:05 »
I own a Filco brown and a Compaq brown MX 11800.
Although both are Cherry brown switches, I see that the Filco one are better for typing but much noisier than the Compaq. So brown is quite noisy sometimes.
Still, I recommend Filco brown tenkeyless for you.
woody
  •  Guest
« Reply #5 on: Mon, 06 June 2011, 14:57:15 »
Quote from: csharper19;356235
So you code? What about data?
Without that sentence the Filco MX brown was a sure recommendation, but carrying everyday is plain crazy.
Just in case, take a look at G84-4100 and HHKB Pro 2.
EDIT: Also the Poker, although I haven't touched one.
Offline daerid
    • Rossipedia
« Reply #6 on: Mon, 06 June 2011, 15:05:42 »
I used to carry my DasK to and from work everyday, back when it was the only mech board I had.
Then I got my tenkeyless brown and leave that at work now. I too am a programmer, and Cherry MX Browns are the perfect programming switch (IMO).
Offline csharper19
« Reply #7 on: Mon, 06 June 2011, 15:46:38 »
The noise isn't important, I can buy Buckling Spring without any problem..
The tactile is important.
HHKB Pro 2 is about 300$ and I can't afford it.
Poker looks nice , is it recommended ?
I repeat , I gonna carry her everyday , I need good keyboard.
So I have Filco Tenkeyless and KBC Poker. The poker is cheaper..
Offline komar007
    • komar's blog
« Reply #8 on: Mon, 06 June 2011, 16:10:57 »
Quote from: csharper19;356410
And the Noppoo Choc mini. A little larger than the poker, and it has the F keys and "normal" arrow keys;)
Offline Atenacius
« Reply #9 on: Mon, 06 June 2011, 16:53:03 »
The Noppoo Choc Mini comes with thicker caps so the clacking of the keys bottoming-out will be slightly dampened. If you were to get it with linear switches, it would be even quieter. I have one with Blacks at work and it's still kind of louder than some of my co-worker's rubber domes.
Keychron Q6 GATERON G PRO YELLOW
Vortex Pok3r CHERRY MX RED
Das Keyboard Model S CHERRY MX BLUE
IBM Model M
1391401 09 MAR 93
Offline Chobopants
« Reply #10 on: Mon, 06 June 2011, 18:13:17 »
I love my reds for coding though I have to say my Topres feel damn nice at the end of the day.
Realforce 87UW 45g - Filco Blue 87 - Filco Linear R - Filco Brown 104
Offline False_Dmitry_II
« Reply #11 on: Tue, 07 June 2011, 00:00:21 »
I'd get this: http://geekhack.org/showthread.php?17570-G80-8113LRCUS-0-on-eBay-for-20usd
and leave it in one place or the other, and then get something more expensive too. Or just two of those, you can get them really cheaply if you use the offer system.
Offline mmmty
  • bang! bang!
« Reply #12 on: Tue, 07 June 2011, 00:09:15 »
Quote from: False_Dmitry_II;356606
Hey! I just bought that keyboard yesterday. My offer was $10. Half of asking price. I just wanted to try clear switch.
Keyboardless
« Reply #13 on: Tue, 07 June 2011, 00:14:20 »
Yeah, I was surprised at the condition (... of the one I opened) it was much better than I expected, so I think it's definitely a viable option.
Honestly after using it, and hearing the descriptions of browns, I don't think I'd like browns. I might like ergo clears though.
Offline Sam
« Reply #14 on: Tue, 07 June 2011, 01:05:10 »
Quote from: daerid;356375
I spent most of my career coding and don't see why Cherry MX Browns would be "the perfect programming switch".  They may be your favorite switch, but I don't see how that would have anything whatsoever to do specifically with "programming".  I consider the keyboard layout to be of supreme importance for coding, with different types of coders having different preferences there.  As to the key switches, I would think it comes down to which key switch you like personally, but I don't see how, beyond your personal preference, any switch has any advantage with respect to coding.
I personally love the IBM buckling spring boards.  Of those, my favorite is the Model F AT, because of the numpad, without the cursor pad.  Actually I use the cursor keys on the numpad, and the regular number keys up top when I need to use numbers - or in the case of extensive number inputting, switch the numpad to the numeric mode.  Tenkeyless boards do not work nearly as well for me, because of the lack of the "numpad" where the cursor keys are laid out in a perfect position for coding, in my opinion.  When coding, as opposed to just typing text, I find I use the cursor keys VERY extensively.  They, along with the positioning of certain heavily used symbols, are the absolute most important factor with respect to layout.
Now perhaps different coders use different methods of moving the cursor around.  For me, I use the mouse very little.  I constantly am jumping around in a file, up and down, to the beginning and end of line, etc. using the cursor keys.  Take a look at the standard cursor pad.  The Home/PageUp/PageDown/End are separated from the Up/Down/Left/Right keys.  It is in effect 5 rows of keys your fingers have to cover while cursoring.  Now look at the cursor keys on the Numpad.  Those keys are laid out in a perfect 3x3 matrix, which is absolutely the best layout possible in my opinion for extensive cursoring.  The Ins/Del keys are on the 4th row if you need them, of which I personally sometimes use, but not so extensively.
During a typical day of coding (20+ hours in my case), many hours would be spent just cursoring around.  Those extra two rows and a not so logical layout of the cursor pad mean much more fumbling around and spending much more time.  If I'm 30% faster with the numpad cursor keys, that means I'll save more than an hour a day with it over the cursor pad.  Quite a huge difference in my case.
So back to my personal preference, the IBM AT, it isn't a perfect layout, being it has the F keys on the left, not up top, and doesn't have F11, F12.  What it does have (actually doesn't have) is no useless cursor pad hindering me by having to skip over that area when switching between the regular keys and cursoring.  However, if I had to lug a keyboard between work and home, an IBM AT board would be way down on my list.  I'd probably be much more inclined in that case to go with a standard IBM Model M, and live with the useless cursor pad.  But even then, a full-size Model M is pretty bulky and heavy.  I guess I'd probably spend more time in figuring out how to buy two and be able to leave one at the office.
If I was designing my own keyboard, with coding specifically in mind, I would make a keyboard which had the cursor keys laid out in the numpad layout, but transposed over the standard area and accessible as a layer (such as over the 'UIOJKLM,." keys).  With one key to toggle the cursor mode on, do my cursoring, without the need to relocate my right hand any, then toggle the cursor mode off to go back to regular typing.  Some boards have something similar, but unfortunately for me it doesn't duplicate exactly the numpad layout, and even if it did, the standard staggering of the keys I think would create some problems.  So ideally, I'd need to add to that keyboard an "ergonomic" layout where the two halves were separated, and there was no staggering.  Something like the uTron, but with full-size keycaps, not the reduced-sized ones they use which I think my fingers would have some problems with.
Ok, that's a long explanation as to why I prefer a certain board for doing coding.  I don't expect everyone to agree with me, but for someone who hasn't yet become fixated on a particular layout, it's something to consider.  Just for fun, you might want to do a test...time yourself for doing a certain cursoring task with the cursor pad, and then with the numpad.  Of course if you're already predisposed to one over the other, it might not be a valid test.
Offline domin8r
« Reply #15 on: Tue, 07 June 2011, 02:23:35 »
I think you might wanna reconsider carrying the keyboard back and forth from work. That would get tiresome quite fast.. let alone for those times when you run out the door, slightly late and at the office you find out you forgot your keyboard :s (that would happen a lot to me atleast)
Btw.. I use a Model M at work (usually) and a Dell AT102W at home (a bit more suited for gaming too)
Compaq MX-11800, Ergo Clear/Brown/Ghetto Red
Ducky 1087XM
Laser SX-25 , White SMK
Black Dell AT101W
IBM Model M 1390120 (\'86)
Cherry G80-1000, Panda Clears
woody
  •  Guest
« Reply #16 on: Tue, 07 June 2011, 06:57:25 »
Quote from: Sam;356625
I am also one of those who spend most of their time cursoring back and forth and sideways, but never ever thought of using the numpad for numbers (that should be accountant / data entry area). I agree that the numpad is better than the tenkeyless split and I miss it, but it was so long ago. The two reasons that steered (read: adapted) me away were that with the advent of the PC101 keyboard layout the numpad became positioned too far away, and lots of (then DOS) software actually expected the new cursor keys. So liking it or not, I just got used to the new cursor cluster. Which makes a tenkeyless board perfect for me.
I kinda preferred them being on the left, eventually easier chording with Ctrl/Alt/Shift and less finger stretch. The Battleships posted here and at DT.net looked nice - F keys both on left and on top.
My HHKB rant was that the cursor key layout could've been better, so I think we're on the same page. But the two problems here are that the staggering becomes cumbersome and I don't see practical solution, and that switching layers would be irritating to me when I have to do lots of 1-2 cursor key plus alphanumeric or del in long sequences.
All in all, everything in a keyboard is a compromise. I can use comfortably few layouts, and that gives me enough peace of mind. Most of all, less typing - less errors.
Offline devilirium
« Reply #17 on: Tue, 07 June 2011, 09:04:12 »
Have you ever heard about the vim text editor? It works exactly like that, and also there are several commands to make thing easier. It's cross platform, so you could run it on whatever OS you use, and you could transport your configs to there. The main concept that it uses two kind of modes, the main mode is where ever key is registered with some kind of command, for example: h for left arrow; j for down arrow; k for up arrow; l for right arrow, i for insert mode.. etc.. So if you navigated to the right part of the code you can just press i to type right there, or a (append) to type after the current character, or type o to instert a line after the current line and type there, or press capital O to instert a line before the current line and then type there. So, basically you'll never have to leave to keyboard for navigational and typing purposes. Try if out =)
(If you use visual studio, there is an addon the does the same thing there)
Offline daerid
    • Rossipedia
« Reply #18 on: Tue, 07 June 2011, 09:10:25 »
Quote from: devilirium;356720
I haven't found one that runs well that isn't exhorbitantly expensive
Offline csharper19
« Reply #19 on: Tue, 07 June 2011, 16:29:33 »
I did another research , and found Topre switches.
It sounds good.
Is there any keyboard you can compare to the HHKB2 ?
Any Topre realforce ? it's the same switches , isn't ?
Offline Reaif
« Reply #20 on: Tue, 07 June 2011, 17:44:10 »
The Realforce boards do use the same switch as the HHKB.
Currently own:
Das S Ultimate with Browns
Cherry G84-4100 with ML Linear switches
Memorex Telex with NMB Space Invaders
Leopold with Blues
Offline csharper19
« Reply #21 on: Tue, 07 June 2011, 17:49:14 »
I'm so IDIOT. The realforce is expensive as the HHKB (Topre Switch).
Which switch is the most like the HHKB's Switch ? (Topre Capacitive)
Of course the blue is not. Red also (I Think)
What about the Brown , Black , Clear ?
woody
  •  Guest
« Reply #22 on: Tue, 07 June 2011, 18:16:35 »
Quote from: csharper19;356981
Minus the capacitive sensing - a rubber dome.
Offline csharper19
« Reply #23 on: Tue, 07 June 2011, 18:21:08 »
I can't get the capacitive sense unless I got a Topre switch?
Well , that's a bummer :/
Anyway,
the KBC Poker will do the job ? It's very close to the HHKB in the design.
I think get it in Brown or Black or Clear ,
but I don't know who is better for Programming and Typing.
Offline hyperlinked
« Reply #24 on: Tue, 07 June 2011, 19:12:16 »
Quote from: Reaif;356978
They're both Topre switches, but apparently according to a few people here who've owned both a HHKB2 and a Realforce attest that the HHKB2 doesn't feel as smooth as the Realforce.
Offline csharper19
« Reply #25 on: Wed, 08 June 2011, 03:17:59 »
Which switch has the "Soft" feeling like the Topre ?
« Last Edit: Wed, 08 June 2011, 03:24:46 by csharper19 »
Offline djmoymoy
« Reply #26 on: Wed, 08 June 2011, 12:15:11 »
I was also considering getting a keyboard with Cherry Browns for work. (I have a Filco with Blues at home and its much too loud for the office.) Does anyone know if something like this would make the Browns quieter?
Offline sam113101
« Reply #27 on: Wed, 08 June 2011, 12:56:40 »
I would suggest you clears, browns and topre.
Only the deck has clears, and it's not tenkeyless.
The realforce is tenkeyless and has topre, but it's too expensive for you.
It leaves you with browns.
There are many boards that use browns, like leopold and filco.
The filco is a bit more expensive, but I think it's worth it.
It has browns and is tenkeyless.
You can also have the otaku version, or the ninja version.
It's the perfect board for you.
Hoping to hear from you again, your dearest friend, sam113101.
Offline sam113101
« Reply #28 on: Wed, 08 June 2011, 12:59:19 »
Well, I think that non-clicky switches that require not so much force are the best for programming.
There's no sound to disturb you, your fingers won't get tired after 10 minutes of programming. That's only my point of view, though.
Offline Wibox
« Reply #29 on: Wed, 08 June 2011, 13:54:15 »
I don't really get the whole "keyboard for coding" thing. I've seen multiple threads asking for the best keyboard for a programmer. I have a decent average wpm, but when I am programming I never type that fast. When I'm programming I am thinking, and I'm stopping often to test or debug. the most intense typing I do is in IRC and IM. Key layout can be important- as seen in the dvorak layout specific to C developers. I've also read the HHKB is good for Emacs but I'm not sure what that means since I'm a vi user.
Find a keyboard that is the best to type on, and you will have found the best keyboard to program with.
That said.. If you want tactile but don't want blues, go with the browns. If you want something that you're going to be picking up and carrying with you everywhere, I suggest the poker for its size.
!! YKBDS !! - KBC Poker (Ergo Clear Cherry) - Apple M0116 (Pink ALPS) - Apple M0115 (Orange ALPS) - Das Keyboard (Blue Cherry) - IBM Model F - IBM Model M - Dell AT101W (White ALPS) - Cherry POS 8000 (Clear Cherry) - Apple Extended II (Cream ALPS)
Offline theferenc
« Reply #30 on: Wed, 08 June 2011, 14:48:47 »
Actually, I think the HHKB is at least as good for vi users as for emacs users, but that's just personal opinion. In both cases, it moves the often used keys closer to where they should be.
Offline csharper19
« Reply #31 on: Wed, 08 June 2011, 15:11:59 »
I think I'll go for the Poker , it's the cheapier.
I'm not gonna buy filco , the Poker is for trying the Mechanical.
My next keyboard will be defenitly the HHKB2 , but for now I'll go for Poker Brown.
Thank you all.
Offline Sam
« Reply #32 on: Wed, 08 June 2011, 23:21:24 »
Quote from: sam113101;357389
I totally disagree.  Typists all over the world used IBM Selectrics for years and years, typing all or most of the day, and I never heard of them getting tired after only 10 minutes of typing.  In fact I worked in an office environment for several years next to a group of typists and heard them happily click clacking away all day long.  I use my IBM Model F AT all day and never have any problems whatsoever getting tired of typing, even when my work involves typing most of the day.
I love the click sound and would hate to use a keyboard without the click sound.  I've used IBM keyboards almost exclusively for the past 30 years and the click sound is not the least bit disturbing to me.  It give me 100% positive feedback that the key has been pressed, and thus positive confirmation of an error if I mistakenly didn't depress the key fully.
Whether typing or coding, my preference in having IBM buckling springs doesn't vary.  Now I do agree that some people, evidently you included, do not like the click sound, especially when coding.  I think it simply comes down to one's personal preference, perhaps having a lot to do with what they're used to.
Offline csharper19
« Reply #33 on: Thu, 09 June 2011, 02:36:52 »
Hey guys , just found out we have Cherry reseller here.
What keyboard can you recommend me from Cherry Company ?
Is the G84-4100 is good ?
He sells it for 74$ (US Dollars) or 250 ILS.
with Hebrew layout is 86$ or 290 ILS.
Is there any cherry keyboard that I'll be satisfied from it ?
Offline Chobopants
« Reply #34 on: Thu, 09 June 2011, 10:37:47 »
Quote from: Wibox;357409
I agree with this mostly. I only disagree in that I get going REALLY fast in vi when I start pumping out some boilerplate code (getter/setters etc).
I think, depending on preference, that Topre, Blue, Brown, Red are all great for typing/coding (yes they are the same thing) and its entirely on what you feel is best for you. Until you try the switches you aren't going to know what your favorite is.
Offline kps
« Reply #35 on: Thu, 09 June 2011, 10:58:48 »
Quote from: ripster;357393
I betcha people on punchcards were lousy programmers because of this.
>implying programmers punched cards
[ Attachment Invalid Or Does Not Exist ] 18984[/ATTACH]
Offline Wibox
« Reply #36 on: Thu, 09 June 2011, 11:33:36 »
Quote from: kps;357883
>2011
>green texting on a vBulletin™ board
Offline pcunite
« Reply #37 on: Fri, 10 June 2011, 13:16:36 »
I have only tried the Black MX switch on a tenkeyless Filco board and I love it. Didn't really want to take the time to order them all and test. Maybe I'm easy to please.
Offline Engine
« Reply #38 on: Fri, 10 June 2011, 19:45:55 »
Hey, I'm a programmer in training.  That is, I bought my own books and am diving into MS training in VS/VB, etc at home.
I also love browns and am intrigured by your comment on them being good for coding.  Can you explain?  Thanks.
In order of purchase:
Unicomp Space Saver(Black) - Topre Realforce 103U-UW -   Topre Realforce 103UB - Leopold Tenkeyless MX Blue - Leopold Tenkeyless MX Brown - Filco Majestouch 2 MX Blue - Filco Majestouch 2 MX Brown
Offline keyboardlover
« Reply #39 on: Fri, 10 June 2011, 19:58:49 »
I code with ergo clears at home and topre at work. I don't think it matters much though. Coding and typing are pretty similar activities.
Offline sam113101
« Reply #40 on: Fri, 10 June 2011, 20:06:13 »
Quote from: Engine;358787
Those are two good arguments I think.
Offline daerid
    • Rossipedia
« Reply #41 on: Fri, 10 June 2011, 21:50:42 »
(My $0.02): I prefer browns the best for programming
Offline Wibox
« Reply #42 on: Fri, 10 June 2011, 23:56:30 »
Quote from: keyboardlover;358792
Programming is typing.
Still don't get the whole "this keyboard is better for programming" thing.
Offline Hydroid
    • http://justin.tv/hydr0id
« Reply #43 on: Sat, 11 June 2011, 00:05:01 »
Well for my input, I just got my first blues and while I'm not a programmer by profession, I've been known to dabble and do the occasional basic web design and I can't wait to let it fly with these blues, I think they'd be great for coding. I've only been using it for a day but the clicking isn't that bad, if you really poke hard at the keys and consistently bottom out with high force they will be loud but I'd think you'd get that from browns too anyway unless you plan to silence them.
Intel Core i7 870 @ 2.93GHz | Corsair H50 | 16GB G.Skill DDR3 | Asus P7P55D-E Pro | Galaxy nVidia GeForce GTX 460 SLI
OCZ 60GB SSD | 2x 1TB Seagate Barracuda RAID-0 | Samsung Blu-Ray Burner | Corsair HX-850W | 2x BenQ G2420HD 24"
Leopold FC200R Tenkeyless Blue | Ducky DK9008(B) Blue | Qsenn DT-35 Black PS/2 Rubber Dome |2x Razer Lycosa USB | Microsoft 500 PS/2
Help me support and grow e-sports below!!!
What Happens in Starcraft -- Vlogs -- Twitter
