Author Topic: Where can I get Blank white for Das?  (Read 1389 times)
Offline zephyros
« on: Mon, 06 June 2011, 17:00:48 »
I know that filco and ducky has same key set with Das, but I couldn't find one.
I just need half of 104 key to make my keyboard similar to this
[ Attachment Invalid Or Does Not Exist ] 18929[/ATTACH]
Give me some help guys!
Offline sinis
« Reply #1 on: Mon, 06 June 2011, 17:13:42 »
Quote from: zephyros;356450
(Attachment Link) 18929[/ATTACH]
those on the picture white are not blank. I can see numbers.
Just buy a cherry MX-keyboard with white/beige keycaps. The 1.0 keycaps should work on your Das.
The bigger keys, like shift, backspace and so on, so 1.25 size and bigger most likely wont work to switch them between boards
