Author Topic: Replace model m spring  (Read 12401 times)
Offline hglazm
« on: Tue, 07 June 2011, 17:35:46 »
I have a model m, quite like it.  However, my cousin was using it and at one point threw a hissy fit, slamming his fists onto it.
I know the running joke is that nothing can destroy a model m, but he found a way.  The E key no longer registers unless completely bottomed out.  So I figure I need to replace the spring or something?
woody
  •  Guest
« Reply #1 on: Tue, 07 June 2011, 18:20:00 »
Step one - try this.
If it doesn't resolve your problem, you'll have to open the case and check the pivots (hammers).
Offline TacticalCoder
« Reply #2 on: Tue, 07 June 2011, 18:31:34 »
Quote from: woody;357000
Can the hammers be checked by opening the case without needing the bolt mod?
If so, how comes I can't transform an ANSI to ISO and vice-versa without the bolt mod? (I will try to bolt mod one my Ms one of these days but meanwhile I'm curious)
woody
  •  Guest
« Reply #3 on: Tue, 07 June 2011, 18:35:58 »
By opening the case, I meant "it gets complicated".
Offline hglazm
« Reply #4 on: Tue, 14 June 2011, 05:25:30 »
Wait no! Success! The E key now actuates when it should.  However, I now have the problem of it double tapping occasionally with only one keypress
No, no nevermind.  I tried tightening the key slightly and ruined the success  I had.  No longer activates upon press.
I have also manged to remove the spring for the P key and am having severe difficulty putting it back on.  In fact the only spring I can get to go back onto any of the hammers is the one off the E key.  Both springs off the P and R keys refuse to go back onto any hammers.
« Last Edit: Tue, 14 June 2011, 05:45:59 by hglazm »
Offline chongyixiong
« Reply #5 on: Tue, 14 June 2011, 07:50:23 »
It's a simple fix - don't worry.
Facts gleamed from this thread
Step 1:
Try this, this or this.
Step 2:
Post back when you're successful
Offline hglazm
« Reply #6 on: Wed, 29 June 2011, 23:06:40 »
After managing to remove the springs from 4 other keys to try and see why I couldn't get any of the springs back in, I called it quits and ordered a 122 key terminal keyboard from unicomp to replace it.
Oh well.
Offline False_Dmitry_II
« Reply #7 on: Thu, 30 June 2011, 00:20:56 »
You could just buy new hammer/springs from unicomp as well. I imagine that would be easier...
Offline hglazm
« Reply #8 on: Sat, 08 October 2011, 22:40:41 »
Alright, after having a bit of a fiasco with getting the wrong 122 key model (I couldnt reassign the keys), I gave up and have been using my DAS blues for awhile.
However, I'm craving that delicious spring action.  I've got the keyboard in question here, and the E and P springs don't actuate correctly.
I've tried twisting them every which way but they refuse to either go on at all or actuate correctly.  Am I doing something wrong?
« Reply #10 on: Sun, 09 October 2011, 12:03:08 »
Bolt-modding is pretty tedious, but makes it easy to take care of these kinds of things.
I am also working with trying to re-map a 122-key model F.
KeyTweak worked for all but a couple of keys, and it is free.
« Last Edit: Sun, 09 October 2011, 12:07:04 by fohat.digs »
- D Trump 2026-10-24
Offline hglazm
« Reply #11 on: Mon, 10 October 2011, 01:16:10 »
Quote from: hawkwind;427866
http://geekhack.org/showthread.php?8731-Broken-spring&p=156128&viewfull=1#post156128
Right, thats what I've been using to take it on/off.  But when I put it back on, it doesnt seem to go on right.  There's no actuation, though the spring is definitely on.
Offline slueth
« Reply #12 on: Mon, 10 October 2011, 01:23:33 »
You have to twist the spring in, make sure u push it in and compress the spring onto the sping holder thingy. I used a sharpened pencil and put the spring on the pencil point and insert and press into the ^ point.  Or take apart the board and put the hammer spring into the correct spot, if the hammer is out of place you can't use the pencil trick.
Offline hglazm
« Reply #13 on: Mon, 10 October 2011, 01:55:03 »
Alright, I got the P key back on and its working fine.  The E key is FUNCTIONAL, however its insanely mushy (to the point where I don't even notice its actuation).  Do I just need to replace that spring or?
Offline slueth
« Reply #14 on: Mon, 10 October 2011, 01:56:05 »
It is mushy because its not in properly.  It might come to the point of having to take it all apart to fixating the spring properly, iono thats such a hassle, keep trying to get it on.  Try twisting it in. best of luck.
woody
  •  Guest
« Reply #15 on: Mon, 10 October 2011, 07:34:00 »
I had a board that due to shipping brutality had a key which clicked much softer and could be described as "mushy".
As suggested by Ripster, I tried Sandy's chopstick method and after some attempts (and failures) I got it right. Guess it takes some practice initially.
EDIT: Take some neighboring keycaps off and compare spring direction - that should give you a clue. Also follow the advice of keeping the board in a certain position while re-seating the spring.
