Author Topic: Model M: some keys don't register at all. Ideas?  (Read 2436 times)
Offline DesktopJinx
« on: Thu, 09 June 2011, 10:30:09 »
I've acquired a lightly-used M. Alas, several keys don't work at all. They don't feel any different from working keys, the computer just doesn't detect when they're pressed. Esc, F4-F6, DFGB. Thoughts?
M15 for life
Offline DesktopJinx
« Reply #1 on: Thu, 09 June 2011, 16:10:39 »
Is a bad trace fixable? Not by me I know, but practically?
Is it likely that Coke or other contaminants would kill contacts this dead but be cleaned well enough to feel the same as the neighbors? I've never actually killed a key with food or drink before, or tried to save one so killed.
« Last Edit: Thu, 09 June 2011, 16:27:35 by DesktopJinx »
M15 for life
Offline Ascaii
« Reply #2 on: Sat, 11 June 2011, 11:37:46 »
It could just be a couple broket rivets near the trace...first thing id do is open up the sucker and check for broken rivets.
Offline DesktopJinx
« Reply #3 on: Sat, 11 June 2011, 14:18:10 »
Well, the thing is, this is an M15, which was sold to me as a fully-functioning keyboard. I want to return it; I'm waiting for the seller's response. With my lack of mechanical dexterity I can't risk opening it now.
M15 for life
Offline Ascaii
« Reply #4 on: Sat, 11 June 2011, 14:50:29 »
thats a whole different story...you should have told us its an M15, the traces are completely different on it.
Offline DesktopJinx
« Reply #5 on: Sat, 11 June 2011, 15:00:11 »
Maybe not completely different -- Esc-F4-F5-F6 is an interesting coincidence :)
M15 for life
Offline ch_123
« Reply #6 on: Sat, 11 June 2011, 15:05:58 »
I'm calling membrane failure.
Silver trace repair pen to the rescue!
Offline ch_123
« Reply #7 on: Sun, 12 June 2011, 05:03:04 »
Wait, this is an M15?
I wanna see pics of the insides :D
If it's constructed anything like an M2, it should just be a case of ripping out the keycaps, and start easing open the tabs that hold the top to the bottom. Just be careful not to break anything while doing it. There are no rivets in the M2/M15 because they have no backplates.
« Last Edit: Sun, 12 June 2011, 05:07:10 by ch_123 »
Offline DesktopJinx
« Reply #8 on: Fri, 12 August 2011, 21:19:05 »
So, I ended up sending it to Unicomp, who fixed it (I don't know how; they're great folks but not exactly an everybody-uses-email organization), and now Mark Goldstein's old M15 is my spare.
Eventually I'm going to open an M15, when I can afford to break one, but not this one.
M15 for life
Offline REVENGE
« Reply #9 on: Fri, 12 August 2011, 22:20:52 »
Quote from: DesktopJinx;398017
Cool, good to know your expensive warez can still be serviced by Unicomp.
