Author Topic: Filco 87 Cherry Reds popping up on ebay  (Read 13019 times)
Offline jnsjr
« Reply #50 on: Fri, 17 June 2011, 23:03:57 »
I got mine as well.  I would recommend this seller.
Current Keyboards
Unicomp Space Saver (white) ~ HHKB2 ~ White Filco Red Cherry Limited Edition (Imsto Grey on White PBT + Group 3 keys + Awry keys)  ~ Realforce 87U 45g + Realforce 87U Variable + Realforce Numpad :biggrin1:+ MJ2 White Blue Cherry 87key
Keycaps
ClickClack Red Eye Skull *(2)* *(3)* *(4)*~ Black Eye Skull *(2)* *(3)* ~ Closeup ~  Topre WASD (Thanks Yak & DB!)
WTT & WTS
WTS White Filco Red Cherry Limited Edition (still deciding!)
Sold ~ Filco Blue Cherry; Majestouch 104 nonprinted keycaps; Noppoo Choco Mini 茶轴 (brown switches);  Topre 87u Variable ; Topre 87u 55g ; MY7000 Doubleshots ; Round 1 Doubleshots
[/FONT]
[SIGPIC][/SIGPIC]
Offline litster
  • rare caps?! THAT'S A SMILIN
« Reply #51 on: Fri, 17 June 2011, 23:56:41 »
just like the first red I got, both new reds are the same.  If you put your ear next to the keyboard and hit the key normal to hard, you hear some high Hz ping sound from the key bottoming out, and with a few keys you can hear the spring makes the springie noise when the key comes back up.  But that is like trying to stab yourself to verify that you can bleed.  Having your ear next to the keyboard make it very hard to type and look at the screen at the same time, even if you are awesome at touch typing.  And you look like a complete dork while doing this.  So really, why do it?  I only hear the normal bottoming out sound when I type while sitting upright, my normal typing position.
