Author Topic: Majestouch 2 and Das Professional S, sound difference  (Read 1473 times)
Offline explicit
« on: Fri, 10 June 2011, 15:10:30 »
Anyone who have tried both with blue switches and can tell me if they truly sound different?
I am watching Destiny's (Steven Bonnell II) starcraft 2 stream and his Das Keyboard sounds alot different then my filco majestouch-2 tenkeyless, both with blue switches. At least to my ears his keyboard sounds alot different on stream. Mine sounds alot more high pitched then his as far as i can make out.
Saw the review from Ripster with soundclips, but if that was Majestouch-1 - we have the thread with sound difference between MX brown boards, where people speculated that Majestouch-2 might be the culprit.
You can check his stream on justin.tv and see if your own das, majestouch 1 or 2 sound alike or if its just on his stream.
Offline explicit
« Reply #1 on: Fri, 10 June 2011, 22:48:32 »
Yep, i checked that review and you say yourself they are slightly different. To me they sounded about the same but i agree about filco being slightly higher pitched, but your filco is majestouch-1 right?
My own majestouch 2 sounds alot more high pitched irl, and when i record it/listen to recordings. Basically have nothing in common with the das on the stream i mentioned
