Author Topic: Modification for Steelseries 6Gv2?  (Read 3061 times)
Offline LiMP
« on: Mon, 13 June 2011, 18:46:49 »
Hey guys, I'd like to modify my Steelseries 6Gv2 a bit, atm its the standard version, with printed keycaps. So I was searching the whole day for colored keycaps, but elitekeyboards.com was the only site that gave me a decent result (ordered the Red Esc keycaps there), which is not enough for me :p Now I need you guys to give me a good site where I can keycaps similar to this one:
Also it would be great if someone could tell me how I can get rid of the printing (?) on the keycaps, so that they look like the Non-printed ones.
Big wall of text, but I hope you understand the most and could help me a bit, if anything is wrong in my grammar, sorry for that, english is not my native language ^_^.
Thanks in advance, have a nice day!
Using a Steelseries 6Gv2, atm without any Modifications.
Offline noodles256
  • le legendary
« Reply #1 on: Mon, 13 June 2011, 18:52:27 »
wlcm 2 gh.
credits to ripster for pic
AF | Ducky YOTD |
Offline SecrtAgentMan
« Reply #2 on: Mon, 13 June 2011, 18:56:02 »
Pretty sure the group buy for the double-shot awesome face is done with.
Offline LiMP
« Reply #3 on: Mon, 13 June 2011, 20:49:55 »
Quote from: ripster;360298
Sandblasting or sanding works for removing the lettering but for Steelseries lasered keys it's gonna take quite a while per key.
Fingernail polish remover works but you'd STILL have to sand and the acetone in it is pretty nasty.
I just want to have the printing off, not the whole color :S
Offline Bucky
« Reply #4 on: Mon, 13 June 2011, 22:15:14 »
http://geekhack.org/showthread.php?16260-PBT-104-keycaps
You can buy some engraved ones from imsto, which kind of gives the no letter look, I believe those ones fit the 6gv2 (though maybe someone can confirm).
