Author Topic: Ringing Filco Majestouch-2 Plus Expanding Polyurethane Foam  (Read 65634 times)
Offline dannyp
« Reply #100 on: Sun, 19 June 2011, 22:34:23 »
mine rings too, it's worst with the keys in the middle :( especially jjjkkkkkhhhll;    (space)    jnnnn.
Offline sordna
« Reply #101 on: Mon, 20 June 2011, 01:17:24 »
Quote from: lucas;363618
This isn't the best reproduction--I used a Nikon D90 and Youtube. But it's still noticable, albeit pretty quiet. (I included a WhiBal card in honor of Ripster.)
http://www.youtube.com/watch?v=N54eusgrtoM
This is very good, thank you Lucas! Also I'm noticing that the ringing noise is much higher pitch that what we've seen so far, this is a high A note, 880Hz. At least you can tune your guitar or violin with it :-)
Offline Wallach
« Reply #102 on: Mon, 20 June 2011, 01:33:21 »
Quote from: ripster;363762
Somebody try their Ducky with this arpeggio trick.  Aluminum backplates should dampen this effect more than the steel plate my Kinesis/Filcos have.
Do you know if the Das Keyboard uses steel or aluminum for their plate? I don't believe a Das Keyboard S would reproduce this either.
Offline sordna
« Reply #103 on: Mon, 20 June 2011, 01:55:54 »
Ripster, I can get a Kinesis contoured keyboard to ring if I do the arpeggio/strum thing, or if I just knock the side of the keyboard, and there's no metal plate.
So it may or may not be the plate on that Filco. It could simply be the springs, and the higher pitch on the Zero can be explained by the fact that it does not wear Cherry MX switches.
Offline lucas
    • lucasreddinger.com
« Reply #104 on: Mon, 20 June 2011, 02:12:39 »
hm.
i'll see if i get used to the sound while typing normally. at first, i was avoiding typing on it because i hated the sound so much.
then if we can land a solid hypothesis, i'll test it on my board.
this was another larz post written on ambien. good night!
Offline redpill
« Reply #105 on: Mon, 20 June 2011, 09:26:47 »
Quote from: ripster;363849
Try it.  I bet it's steel on the Das.
My Kinesis keypad is steel and does the same thing so I would think the Das would too if you draw your fingers over the keyboard like that.
My Topre Realforce makes more of a duller sound but still vibrates.  Sort of a washboard sound.
So you've moved on from denying the sound exists to insinuating all keyboards make a similar noise.   You even mentioned a Topre!  Please stop the ridiculous comparisons.
^ Current Favorite ^  Topre Realforce 87UB 55g  |  Topre Realforce 103UB 55g | KBC Poker/Browns/Sanded KeycapsDucky 1087 | Filco MajesFoam-2 | IBM Model M 1390131 Feb '87 | Still Love: Microsoft Trackball Explorer x3 | Now Unused:  Microsoft Natural Ergo 4k x2
Offline redpill
« Reply #106 on: Mon, 20 June 2011, 09:46:50 »
Quote from: ripster;363964
Never said it was the SAME.  Just a difference in DEGREE.
Anyway, I wanted to show Findcanor that indeed I can change and be open minded.
After all your BS about the "McGurk Effect", and "sound samples or it didn't happen", and how your Gen 2 Cherry doesn't ring, oh wait then it does, but it's not the switches because the Riporuster doesn't do it, blahblahblah.  You haven't changed because you're still Filco shilling.  If you want to be open minded, why not take what multiple people have to say who have experienced it at face value instead of trying to discredit them.
The question is why is the Filco plate resonating so loudly?  My $100 KBC Poker should not sound better than my $150 Filco.  They can't have designed it that way purposefully, and it's clearly not something that is a widespread issue to this degree or there would be more about it.
Offline redpill
« Reply #107 on: Mon, 20 June 2011, 09:49:12 »
Oh and btw I looked it up on the other thread, and I believe it was alaricljs that deserves credit for first making the zany suggestion of expanding foam.
Offline redpill
« Reply #108 on: Mon, 20 June 2011, 10:15:56 »
Quote from: ripster;363980
And these are some of the Chemicals I plan on using for Filco Key Testing, plus a few new ones.  Assuming you are not so mad you won't send me the keys.
I'm not mad, just keeping you honest :)  Keys should be out in a couple days, would have sent them on Friday but things got hectic at the office.
Offline gimpster
« Reply #109 on: Mon, 20 June 2011, 12:01:33 »
Quote from: redpill;361266
It would be easy for the manufacturer to add dampening during the manufacturing process of course at relatively small cost.  Even on non-ringing boards I would think it would help provide a more solid sound/feel (cue ripster claiming Filcos are perfect as they are and can't possibly be improved upon).
Maybe some strips of Dynamat. It's primarily used in U.S. for car stereo installations to keep the bodywork from rattling. It's pretty easy to cut up and apply with your hands.
http://www.dynamat.com/
-Ryan
Offline greyhounds
« Reply #110 on: Mon, 20 June 2011, 12:14:35 »
I was going to chime in regarding Dynamat as well. We use it in car restoration all the time, but they also apply it to computers etc:
http://www.dynamat.com/products_computers_and_more_introduction.html
It's adhesive backet and relatively thin, so you could cut some strips and add them to the face of the metal plate. I'd expect they'd add enough mass to change the resonant frequency of teh plate and stop the ring.
My das board rings only slightly when I hit it real hard, so whatever they do works about as good as you can hope for.
Offline lucas
« Reply #111 on: Mon, 20 June 2011, 12:15:30 »
i have gaffing tape. how would one use it in this case?
Offline gimpster
« Reply #112 on: Mon, 20 June 2011, 12:30:58 »
Quote from: lucas;364073
I would expect that for the Cherry MX keyboards, you'd just cut it into strips and apply it to the face of the metal plate. But if you were talking about Model M's then I'm not sure because I'm not that familiar with how they're designed.
-Ryan
Offline gimpster
« Reply #113 on: Mon, 20 June 2011, 12:33:37 »
A paper trimmer would probably be very helpful in making the strips quicker and with a more uniform width.
-Ryan
Offline The Solutor
« Reply #114 on: Mon, 20 June 2011, 13:14:31 »
Quote from: gimpster;364078
This will likely helps to dampen the filcos resonating plate but unlikely helps with the pinging switches, btw a self adhesive caoutchouc mousse roll, should be way more effective than the gaffer tape for this purpose.
Offline morethanless
« Reply #115 on: Mon, 20 June 2011, 13:24:36 »
Yes I use the black cellular rubber in conjunction with orange sponge rubber to reduce vibrations of HDDs an water pumps. (google for "shoggy sandwich")
EDIT: But I think actually you'd have to dampen the springs of each switch like this
[video=youtube;CJnAbPrmJNA]http://www.youtube.com/watch?v=CJnAbPrmJNA[/video]
« Last Edit: Mon, 20 June 2011, 13:33:00 by morethanless »
Filco Majestouch 2 Tenkeyless LineaR
(Cherry MX Red)
Offline redpill
« Reply #116 on: Mon, 20 June 2011, 13:30:17 »
The plate rings with any vibration, whether it be the springs or knocking on the desk next to it.  So you can try to treat the vibration in the springs in hope that it causes less to be carried to the plate, or you can dampen the metal plate directly so it doesn't ring regardless of the springs/knocking/earthquakes, etc.  Or, both.
But I'm more hesitant to try to modify the switches themselves because it's 1) hard and 2) likely to negatively impact the keyfeel.
Offline The Solutor
« Reply #117 on: Mon, 20 June 2011, 13:40:20 »
Quote from: ripster;364115
My Kinesis keypad rings like a bell if I hit the key hard enough.
Since I bought the switches new from Mouser and soldered the plate myself with remarkable skill I am not an adherent to your theory.
You know, no theory here, resoldering the switches was tested and retested, btw as I already said likely the led will helpto coupling tightly the switch to the PCB.
The only cheap keyboard I have with just two pin connection per switches is the BW (which is natively not pinging because it's blue) anything else have a led, a diode or a jumper.
Offline redpill
« Reply #118 on: Mon, 20 June 2011, 13:40:40 »
Quote from: ripster;364121
My / key rings like a bell.
Keys ping.  Boards ring.
Good material for a haiku in there I think.
Offline redpill
« Reply #119 on: Mon, 20 June 2011, 13:44:20 »
I think ripster ate some bad eggplant parmesan once and has never forgiven Italy.
Offline sordna
« Reply #120 on: Mon, 20 June 2011, 13:48:20 »
Quote from: The Solutor;364128
Soluter, I believe your solution will work for some switches, but for the OPPOSITE reason you are mentioning. A tight coupling increases sound transfer. It's not the switch body that vibrates but the spring inside the switch. Think guitars. the better mounted the bridge, and the higher the bridge height (more force on the soundboard) the louder the sound.
I bet if you desolder the switch (remove all solder so the switch is completely loose), the noise level will go down.
Offline The Solutor
« Reply #121 on: Mon, 20 June 2011, 13:52:03 »
Quote from: redpill;364132
He just suffers of what we call "the two cock on one hen-house syndrome", likely sounds bad in english, but I'm sure you got the point.
Offline sordna
« Reply #122 on: Mon, 20 June 2011, 13:52:19 »
There are some cool iPhone/iPad apps like Audio Tool / AudioTools with SPL meters and sound frequency generators. Not the most accurate but very handy.
Offline The Solutor
« Reply #123 on: Mon, 20 June 2011, 13:55:52 »
Quote from: sordna;364134
Think guitars.
On guitars is not the whole string that is coupled with the resonance chamber, and materials are calculated to resonate.
Think to the one or two euro coins instead.
Offline sordna
« Reply #124 on: Mon, 20 June 2011, 14:06:58 »
On the euro coins, the metals ARE the sound source. On keyboards, the possible sound sources are the springs and the plate. The other components (switch shells and PCB) act as coupling materials. In any case, theories don't matter so much as long as the solution works. Anyway, resoldering is a good solution for an isolated switch, and the foam is good if the entire keyboard has a pinging problem.
Ripster, you mentioned earlier that you don't have a pinging switch issue before to try the soldering on. Now that you discovered your "/" numpad key, can you please try resoldering it and provide before/after sound samples ?
Offline redpill
« Reply #125 on: Mon, 20 June 2011, 14:09:21 »
Quote from: sordna;364146
I don't know if I'd call it good, but it was effective in reducing the noise and making a mess.  I'd be interested to see if people have success with less messy/permanent foam and/or alternative solutions like padding on top of the metal plate.
Offline The Solutor
« Reply #126 on: Mon, 20 June 2011, 14:20:30 »
I can speak for the switch not for the whole plate, because I don't have the problem.
BTW I'm sure that my plate is not resonating like on filcos because the plate doesn't have any clearance with the switch border with a tightly soldered switch I mean.
Looks like on filcos the plate is placed slightly in lower position, so I can't say if a resolderd switch makes any difference for the plate ring. And buying a filco just to test this is out of discussion altough I'm used to test in first person what I'm saying.
Back to the filco problem, I'm sure that any usual dampening method will work, from the rubber foam to the dampening paint (the one used on the underside of the cars).
I used the latter for ages to improve the sound of my line of acoustic boxes, when i was used to build and sell them.
« Last Edit: Mon, 20 June 2011, 14:24:53 by The Solutor »
Offline sordna
« Reply #127 on: Mon, 20 June 2011, 14:24:49 »
I was gonna suggest soldering the switch while squeezing it or pulling it, so it creates different tension on the metal plate. It's not the actual solder points that matter IMO.
Offline The Solutor
« Reply #128 on: Mon, 20 June 2011, 14:28:34 »
Quote from: sordna;364159
Obviously is not.
On every keyboard I tried when the soldering points were melt the switch made a definite "tock" and made a little travel in the PCB direction.
Offline The Solutor
« Reply #129 on: Mon, 20 June 2011, 14:29:44 »
Quote from: ripster;364162
This is getting complicated.  I don't think the robo picking machines do any of that stuff on anybody's keyboards.  Dump it on the plate/PCB and run through the wave soldering machine.
Exactly.
Is what I'm saying in the last month.
Glad you finally realized it.
Offline The Solutor
« Reply #130 on: Mon, 20 June 2011, 14:34:23 »
Quote from: ripster;364165
From this piece of factual data you concluded it was a Filco manufacturing problem.
I concluded that any industrial process can't be good as a relatively expert hobbyist's hand.
Likely filco has greater problems because the larger tolerances, that's all.
Offline keyboardlover
« Reply #131 on: Mon, 20 June 2011, 14:35:40 »
Are you guys still arguing about this?
Talk about the ping heard round the world...
Offline redpill
« Reply #132 on: Mon, 20 June 2011, 15:10:41 »
Couldn't handle the EK soft landing pads, they kill the switchfeel too much.  Mushy.
Offline sordna
« Reply #133 on: Mon, 20 June 2011, 15:30:57 »
Yes, that's why artificially creating some tension/pressure on the metal plate, may have a dampening effect.
Offline sordna
« Reply #134 on: Mon, 20 June 2011, 15:44:24 »
Quote from: redpill;364190
I did the same. I couldn't stand the black pads, but gave the gray ones a few weeks, and finally removed them last Friday. Dental-bands didn't do it for me either. The medium-soft o-rings are much better though, they are almost perfect, it's incredible that the cheapest/easiest solution happened to be the best... once you find the right o-ring part number that is! I spent almost $80 trying out various alternatives :-)
« Last Edit: Mon, 20 June 2011, 15:47:35 by sordna »
(Cherry MX Red)
Offline sordna
« Reply #136 on: Mon, 20 June 2011, 15:55:39 »
Quote from: morethanless;364236
Which shore number or rubber type?
Is NBR70 ok?
http://www.hug-technik.com/shop/product_info.php?info=p2357_praezisions-o-ring---5-50-x-2-00-mm--nbr70.html
Nope, shore 70A is too hard. 40-50 is perfect, material doesn't really matter since you're not sealing any fluids in your keyboard. Rubber/silicone/neoprene should all work. The o-rings you pointed to are too big however, they are metric 5.5mm x 2mm. For metric, you want 5mm x 1.5mm.
See comments near the end of the relevant thread: http://geekhack.org/showwiki.php?title=Island:5450
« Last Edit: Mon, 20 June 2011, 16:08:17 by sordna »
« Reply #137 on: Mon, 20 June 2011, 16:10:09 »
Thank you. But finding shore 40-50 seems impossible in german online shops.
They only have shore 70.
(Cherry MX Red)
Offline The Solutor
« Reply #138 on: Mon, 20 June 2011, 16:21:23 »
Quote from: ripster;364211
If true the OCN trick of baking your graphics cards may work by relieving stress points on the steel plate.
Or maybe not.
Is not an OCN trick and often works,  go back to the lead free soldering alloy post, to understand why...
Offline lucas
« Reply #139 on: Mon, 20 June 2011, 19:31:08 »
can someone link me to a threads that tell me how to open a filco tkl and how to pull fukka caps? i can only search every 30 seconds
i'll void my warranty on my overly-expensive board
Offline sordna
« Reply #140 on: Mon, 20 June 2011, 21:18:26 »
Quote from: lucas;364430
search engine sucks, you can't even search for "pads" (complains it's too short) you have to search for "landing" instead. iMaaaaaaaaaaaaav can you at least allow 4 character words?
Anyway, you can ask google to search geekhack for you, for example:
TKL site:geekhack.org
Offline redpill
« Reply #141 on: Mon, 20 June 2011, 23:26:44 »
Quote from: ripster;364459
The problem is you are searching for "TKL".
I wrote it up using "Tenkeyless".
In fact the Vbulletin search engine kinda sucks so "TKL" is too short.
Vbulletin search sucks anyway, you'll never find much.  Need to use google: "TKL site:www.geekhack.org"
Quote from: ripster;364460
I think I'll open up a "Mod Your Kinesis Keypad To Stop Ringing" post tomorrow.
But it will be in the Mods subforum.
I got a mostly-full can of expanding insulation foam I can sell you for cheap!
Offline MissileMike
« Reply #142 on: Wed, 22 June 2011, 15:32:42 »
Here is typing on a Ducky 1087.  Do you hear a ping?
[video=youtube;saUOK60t5Tg]http://www.youtube.com/watch?v=saUOK60t5Tg[/video]
BS: 5 Space Savers  ||  9 42H  ||  10 1391401 or similar  ||  1x 1390131  || AT&T 305b  ||  Dell Model M
Cherry: Leopold FC200RC/AB  ||  3 Ducky 1087  ||  PLU ML87 ||  Cherry G80-8113LUVEU-2  browns
Alps: Filco Zero Tenkeyless (fukka)  ||  ABS M1  ||  3x Dell AT101w  ||  Ancer KF-191  ||  6 Vivanco Compact
Misc: NMB RT6855T+  ||  NMB RT101 Space Invader  ||  Dell Quietkey  ||  Ge Fanuc Industrial Metal
Offline redpill
« Reply #143 on: Wed, 22 June 2011, 15:44:57 »
Quote from: MissileMike;365450
I hear springs, but I don't hear a plate ring.  Do you hear one in person?
Offline alaricljs
  • I be WOT'ing all day...
« Reply #144 on: Wed, 22 June 2011, 15:47:41 »
I hear the normal Cherry MX spring ping if I crank the volume.  I haven't heard a single ringing Filco sample yet, since that's what all the complaining is about how come no one has recorded it?
Filco w/ Imsto thick PBT
« Reply #145 on: Wed, 22 June 2011, 16:03:09 »
If I put up the volume high I can hear the springs.
Especially when you come closer at the end.
But on my normal volume level I can only hear the plastic keycaps
(Cherry MX Red)
Offline redpill
« Reply #146 on: Wed, 22 June 2011, 16:05:46 »
Quote from: alaricljs;365459
I recorded it, link in sig, but doesn't come across very well due to iphone microphone.
« Reply #147 on: Wed, 22 June 2011, 16:06:55 »
If I put my ear up to my kalrykh-krusted shorts I can definitely hear ringing.
I plan to consult a doctor.
Offline alaricljs
« Reply #148 on: Wed, 22 June 2011, 16:11:19 »
Yeah, there's a bit of sustain there but again I had to crank the volume to get much of it.  The way certain other users were describing it I was expecting something more obtrusive and painful.
Offline redpill
« Reply #149 on: Wed, 22 June 2011, 16:25:44 »
Quote from: alaricljs;365474
Well it's not something that happens loudly on every board, so if yours doesn't do it, that's a good thing :)
