Author Topic: Ringing Filco Majestouch-2 Plus Expanding Polyurethane Foam  (Read 70242 times)
Offline alaricljs
  • I be WOT'ing all day...
« Reply #150 on: Wed, 22 June 2011, 17:07:59 »
I've got 2 that don't do any more than the standard spring-ping, and I don't type hard enough in normal usage for it to be detectable at all.
Filco w/ Imsto thick PBT
Offline morethanless
« Reply #151 on: Wed, 22 June 2011, 17:57:17 »
I heard you giggle!
Obviously you realized how funny it is to do arpeggio on a numpad. :happy:
Filco Majestouch 2 Tenkeyless LineaR
(Cherry MX Red)
Offline The Solutor
« Reply #152 on: Wed, 22 June 2011, 18:14:08 »
It's clearly not a soldering or a Cherry MX individual switch defect problem
Is clearly not a single switch problem, soldering could be still involved.
The only way to exclude it is resoldering all the switches, as i did.
Offline The Solutor
« Reply #153 on: Wed, 22 June 2011, 18:39:33 »
I already did that. See the Kinesis Mod in my sig.
Ok
Quote from: ripster;365567
Rang before.
Rings still.
Its also strange that rings with blue switches, usually are the brown ones more prone to the problem.
BTW I found this video of Xarmor in the mod section altough not meant for this pourpose the owner pushes the keys pretty hard and no pinging is present, I used mine for just few hours before the switches change so I was unsure about the original sound, even with the original switches Xarmor's ound is still one of the better parts of this keyboard.
[video=youtube;rk6tVsFcBrE]http://www.youtube.com/watch?v=rk6tVsFcBrE&feature=player_embedded[/video]
Offline The Solutor
« Reply #154 on: Wed, 22 June 2011, 18:51:54 »
Quote from: ripster;365583
Actually if my hypothesis is correct and this is mainly spring sound amplified by a metal plate then the underlying switch should matter little.
I think your hypothesis is correct on this board and maybe on filcos.
I think the main variable should be the plate height.
Likely in those cases the plate has more clearance from the switch border so no matter how you push the switch the plate is still free to vibrate (and the switch too).
While in my case the switch (if correctly soldered) touches tightly the plate, and they dampen each other.
Offline The Solutor
« Reply #155 on: Wed, 22 June 2011, 19:22:56 »
Quote from: ripster;365637
You ever heard of The Law Of The Instrument.
No never heard, looks like is aimed to the new continent
BTW exceptions (if any) are useful to confirm rules
Offline Dwipster
Any success on getting rid of Filco ringing?
« Reply #156 on: Thu, 11 August 2011, 15:27:40 »
Anyone had any further success on getting rid of the Filco ringing, except for that injectable-foam mod that I respect someone for having done but have no intention of doing? I just got a new FKBN87M/EB2 tenkeyless and it rings like crazy. My older FKBN87M/EB (note: original series, while new keyboard is series 2) has no ring at all. The new keyboard has some keys that ring a tremendous amount, especially the equals sign, space bar, x key, and backspace. Other keys have hardly any at all, such as the h key, v, c, e, and others.
It really is pretty annoying. Any success stories fixing it?
Offline litster
  • rare caps?! THAT'S A SMILIN
« Reply #157 on: Thu, 11 August 2011, 15:33:13 »
I LOL'ed at your name, Dwipster!  Welcome to GH!
Offline keyboardlover
« Reply #158 on: Thu, 11 August 2011, 15:34:53 »
Weird, I thought Ripster said only me and Redpill found the ringing annoying.
« Reply #159 on: Thu, 11 August 2011, 15:36:48 »
What exactly does the dental floss mod?
Do you wrap around the cherry mx stems? Like the o-ring mod?
(Cherry MX Red)
Offline The Solutor
« Reply #160 on: Thu, 11 August 2011, 15:49:37 »
In the exact moment you open a cherry switch, the ping is fixed, no need to add any dental floss.
« Reply #161 on: Thu, 11 August 2011, 17:37:50 »
So, for dental floss you need to desolder the switch too. Because without that, you can't open it. Right?
(Cherry MX Red)
Offline The Solutor
« Reply #162 on: Thu, 11 August 2011, 17:40:20 »
Right.
BTW I'm not sure the dental floss will work nicely on springs meant to be compressed as happen on springs meant to be flexed.
« Reply #163 on: Thu, 11 August 2011, 17:44:51 »
Btw: how do I remove my left shift key? It rattles. I want to pull the keycap but I can't do it.
I already looked there http://geekhack.org/showwiki.php?title=Island:12649
SO I'm lost, without desoldering
« Last Edit: Thu, 11 August 2011, 17:50:30 by morethanless »
(Cherry MX Red)
Offline The Solutor
« Reply #164 on: Thu, 11 August 2011, 17:51:56 »
just remove the neighbor keycaps and use your fingers, when the stem is freed, slide the keycap on one side until the stabilizer is disengaged, then slide in the opposite side to free the other half of the stabilizer.
« Reply #165 on: Thu, 11 August 2011, 18:26:31 »
I can't do it. If I pull up, nothing happens. I can see the metal wire and part of the right stabilizer. on the left, the keyboard case does bother me.
PS: I added a smartphone camera picture.
PPS: gn8, I'll try again tomorrow. it is 1.30am
(Cherry MX Red)
Offline The Solutor
« Reply #166 on: Thu, 11 August 2011, 18:32:17 »
Remove also the CTRL and Capslock Keycaps, and use both hands if needed.
Surely you have a keycap little tighter or a switch stem slightly larger than normal, but other than exceptional cases nothing to worry about, just more force needed.
« Reply #167 on: Thu, 11 August 2011, 18:38:31 »
One last question for today
Did I understand corectly that when the switch is up (neutral non-pressed position) I have to pull up, even though it feels like the metal stabilizer would hold it down?
(Cherry MX Red)
Offline The Solutor
« Reply #168 on: Thu, 11 August 2011, 18:42:02 »
No the stabilizer, being hinged, has enough clearance to let you free the keycap from the stem, half cm or so, try to remove th other shift or backspace, maybe they are less tightly coupled and you can practice with them.
Offline Pacifist
  • on hiatus
Re: Ringing Filco Majestouch-2 Plus Expanding Polyurethane Foam
« Reply #169 on: Wed, 29 January 2014, 19:26:21 »
where can i get these engraved caps?
« Reply #170 on: Wed, 29 January 2014, 19:28:47 »
You gotta use the foam stuff first.
Offline BucklingSpring
« Reply #171 on: Wed, 29 January 2014, 20:06:31 »
You necro revivers.
I thought for a moment that someone redid the Epic 2011 foam experiment.
Boards I own, click ->
« Reply #172 on: Wed, 29 January 2014, 20:07:57 »
You necro revivers.
report them, only way to stop them. if the mods care.
Offline litster
« Reply #173 on: Wed, 29 January 2014, 20:10:08 »
Ah, the good old days...
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #174 on: Wed, 29 January 2014, 20:49:49 »
Insulation foam in a keyboard....... only in america  ;) .  I suppose when your car engine rattles spraying some foam in there would solve that problem too?
« Reply #175 on: Wed, 29 January 2014, 21:36:17 »
Some of my keys rattle when I run my hand across the keyboard, maybe I could spray some of that stuff under the keycaps to hold them a bit firmer?
Offline Elrick
  • Hype Master
« Reply #176 on: Wed, 29 January 2014, 22:03:43 »
Okay Rowdy, break out a can of foam and go whupass on that Filco.
I just thought of this, instead of going mad with expanding foam, why not use a standard clear tube of silicone.  That way you can surgically implant some silicone into your board for that special feeling  ;) .  If it's good enough for pornstars and streetwalkers it should be good enough for your keyboard.
« Last Edit: Thu, 30 January 2014, 01:13:09 by Elrick »
« Reply #177 on: Thu, 30 January 2014, 01:10:21 »
Depending on key cap material hot glue might be an option.
« Reply #178 on: Thu, 30 January 2014, 01:20:00 »
I wonder if injecting such silicone under the dones of a Thorpe keyboard would enhance the oneness with cup rubber ...
A combination of ABS and PBT, mostly ABS.
Offline wrwhoami
« Reply #179 on: Thu, 30 January 2014, 04:39:28 »
filco..
I like sounds this ;D
