Author Topic: Mouse pad  (Read 2832 times)
Offline SecrtAgentMan
Mouse pad
« on: Thu, 16 June 2011, 19:19:21 »
Okay so I'm in the market for a mouse pad.
Right now I have a G500 so I would like a pad that doesn't screw about with it and make it go all skippy like when doing fast motions.
Offline audioave10
Mouse pad
« Reply #1 on: Thu, 16 June 2011, 23:24:25 »
The Steelseries does have some good mousepads. Check the reviews.
DECK Legend "Toxic" - SOLD
96 IBM Model M 82G2383- 95 IBM Model M 92G7453 - SOLD
Cherry G80-3000/Blues
new: MechanicalEagle Z77 RGB/Blues
Offline Bucky
Mouse pad
« Reply #2 on: Fri, 17 June 2011, 00:37:18 »
Steelseries are generally regarded as pretty good. I have heard great things about Func 1030 mouse pads http://www.performance-pcs.com/catalog/index.php?main_page=index&cPath=53_90_424_431 and artisan mouse pads http://www.amazon.com/gp/search/ref=sr_nr_n_1?rh=k%3Aartisan%2Cn%3A172282%2Cn%3A%21493964%2Cn%3A541966%2Cn%3A172456%2Cn%3A705323011&bbn=172456&keywords=artisan&ie=UTF8&qid=1308288955&rnid=172456
I do not think any of them are going to be significantly better or worse, more of a preference thing.
Offline shortround
  • Scoot jockey, nomad trash.
Mouse pad
« Reply #3 on: Wed, 06 July 2011, 00:33:20 »
FPS people need Glock mats, or they make Sig, 1911 mats etc.
Or get a mini Persian rug.
« Last Edit: Wed, 06 July 2011, 00:37:20 by shortround »
Offline Rafen
Mouse pad
« Reply #4 on: Wed, 06 July 2011, 20:43:21 »
Steelseries makes a really nice glass mouse pad. I have one and the mouse glides so smooth on it. It will run you about 40 bucks. The only drawbacks with are if you sweat a lot when you gaming sometimes your mouse wont read. The other is it only works with optical mice, not laser.
« Last Edit: Tue, 12 July 2011, 20:18:19 by Rafen »
