Author Topic: Korean style tenkeyless (without Windows key)  (Read 2684 times)
Offline HaveANiceDay
« on: Fri, 17 June 2011, 21:55:40 »
**** my life!
I want one of those. Big fan of the cherry double shots and dye subs and it drives me crazy that I can't use all the keys.
I don't think there are any other than the limited Korean custom runs.
But here I am, hoping that you(YES YOU <3) may prove me wrong.
Pic stolen from this guy
Filco Tenkeyless Brown with beige cherry doubleshots (home)
Realforce 86U (work)
Get you own Phantom NAO!
« Reply #1 on: Fri, 17 June 2011, 22:01:31 »
Yes they are SP double shots as far as I know, not sure about RGB modifiers.
Whatever! I would kill for that case. Or pay! Depending on the needs of my client.
Offline wanabe
« Reply #2 on: Sat, 18 June 2011, 00:31:59 »
fairly certain those are dolch doubleshot keys.. http://deskthority.net/viewtopic.php?f=8&t=100
the rgb modifiers are vintage cherry as well http://geekhack.org/showthread.php?13956-Cherry-Corp-RGB-sublimation-keys
Offline sixty
    • http://deskthority.net
« Reply #3 on: Sat, 18 June 2011, 04:59:57 »
Quote from: wanabe;362746
This is correct. The keys are Dolch keys, made by Cherry. The RGB keys are made by Cherry two, in this picture its the two-shot variant, which was made once in 1992 and then again in 2007/2008. If you are looking for some more info on the Korean custom boards, I wrote a summary here.
« Reply #4 on: Sat, 18 June 2011, 11:01:09 »
Oh sixty, of course I read that whole thread already <3. Thanks for writing it.
Do you know if there is any possibility for me to get one of those? I know the chances are pretty slim :/
« Reply #5 on: Sat, 18 June 2011, 11:09:14 »
The centered BIGASS font kinda ruins it. Oh, and the Back Space.
