Author Topic: Do Cherry Switch Number Pads Exist  (Read 7796 times)
Offline liist
« on: Sat, 18 June 2011, 23:56:52 »
I'd figure I'd love to get a tenkeyless if I could have a separate numberpad, that way I have the best of both worlds, and especially since I'm going to switch into accounting, I could use one.
Update: I found one of these: http://www.bonanza.com/listings/DSI-Brown-Switch-Modular-Mac-Number-Pad-Keypad-mod-kp-br/12161580
Are they what I'm looking for? Does anyone own any of these things?
« Last Edit: Sat, 18 June 2011, 23:58:54 by liist »
Kinesis Advantage, Filco Majestouch-2 104, Unicomp Spacesaver with blank keys, Several IBM Model M\'s, two Microsoft keyboards (forever retired)
Offline Ascaii
« Reply #1 on: Sun, 19 June 2011, 01:07:20 »
yes, plenty. Ask ripster where he got his switch try numpad from, they pop up on ebay once in a while. Also, there are the classic Cherry g80-3700 and g80-5700 numpads.
On ebay.com, look for the goldtouch ergonomic numpad, it uses cherry brown switches and pops up once in a while. One sold for 12$ a few days ago.
http://cgi.ebay.com/NEW-GOLDTOUCH-ERGONOMIC-NUMERIC-KEYPAD-/300567504374?pt=PCA_Mice_Trackballs&hash=item45fb3825f6
I hear the seller has been selling these over and over, you should pm him and see if he has any left that arent registered yet.
good luck!
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #2 on: Sun, 19 June 2011, 09:34:01 »
Here is an expensive Cherry numpad.
« Reply #3 on: Sun, 19 June 2011, 10:06:12 »
Quote from: lysol;363323
That numpad has Cherry ML switches, not the nice Cherry MX that the others have.
Offline morethanless
« Reply #4 on: Sun, 19 June 2011, 10:49:11 »
Besides Cherry pads, there are Filco mx brown pads
http://www.keyboardco.com/keyboard_details.asp?PRODUCT=620
Filco Majestouch 2 Tenkeyless LineaR
(Cherry MX Red)
Offline reaper
« Reply #5 on: Sun, 19 June 2011, 10:51:18 »
Yup, Filco's num pad is great if you don't mind the price.  I got one. =D
][/URL]
Din Eli
Offline RickyJ
« Reply #6 on: Tue, 21 June 2011, 16:16:22 »
Adesso makes one with Cherry blues.
Currently GMMK Pro: lubed 68g U4T, FR4 plate, extra gaskets, etc
Offline nhwhaup
« Reply #7 on: Wed, 22 June 2011, 04:18:28 »
I also have the Filco number pad. For me it's okay. My favorite switches are reds and the number pad, I believe has brown switches.  So if I had a choice I would have preferred a Filco number pad with red switches.
Current in order of preference:  RealForce 87U Silent White with variable weighted keys X 2, Filco Majestouch 2 Tenkeyless with Linear Reds, Filco Number-pad, Poker with Linear Reds
Sold or returned:  Multiple Microsoft and Logitech keyboards, Das Keyboard Silent, Cherry 6140, RealForce 103UB, RealForce 86U, Filco Majestouch 2 full sized with Linear Reds
« Reply #8 on: Wed, 22 June 2011, 04:39:09 »
Is the Filco NumberPad PCB or Plate mounted?
(Cherry MX Red)
Offline Keyboard search
« Reply #9 on: Wed, 22 June 2011, 13:51:18 »
I have a numpad with brown Cherry switches.  Its a Kinesis.
I use my modded Kinesis Advantage (Black).  It has a Kinesis numpad between the halves.
