Author Topic: Keyboard pixel art things.  (Read 2503953 times)
Offline sordna
« Reply #350 on: Wed, 20 July 2011, 16:43:48 »
Quote from: TexasFlood;384248
Nice :thumb:
All thanks to you mate, for the brave, excellent start! Feel free to improve. For one thing, it came out too dark overall. By the way, I'm using GIMP on Linux, with zoom at 800%
Offline TexasFlood
« Reply #351 on: Wed, 20 July 2011, 17:16:45 »
Quote from: sordna;384255
Hah, exactly what I'm using!  Well, zoom varies, sometimes 200%, 400%, even 1600% at times but for this 800% has seemed the most useful zoom setting.  You can certainly see the dual tone bezel more clearly in your last version.  Shouldn't be too hard to lighten it up.  It's difficult to tell what colors are going to look right until you're done with a pass & look at it.  Sometimes doesn't turn out like you'd expect and needs tweaking.
« Last Edit: Wed, 20 July 2011, 17:19:14 by TexasFlood »
Offline TexasFlood
« Reply #352 on: Wed, 20 July 2011, 17:19:43 »
Hah, exactly what I'm using!  Well, zoom varies, sometimes 200%, 400%, even 1600% at times but for this 800% has seemed the most useful zoom setting.  You can certainly see the dual tone bezel more clearly in your last version.  Shouldn't be too hard to lighten it up.  It's difficult to tell what colors are going to look right until you're done with a pass & look at it.  Sometimes doesn't turn out like you'd expect and needs a bit of creative tweaking.
Offline RiGS
« Reply #353 on: Wed, 20 July 2011, 18:04:30 »
Quote from: keyb_gr;384174
Man, you guys have been busy on here. A Kinesis Contoured? Whoa.
Here's the blue-keyed 87U with a tweaked front lip for better accuracy:
(Attachment Link) 21556[/ATTACH]
I have kept my hunger for perfection busy, and I thought there was a little room for improvement, but then I quickly realized it is not possible to make this better.
The line around the F-keys, and near the arrows should be 1,5x wider, but since it is 1 pixel wide it is not possible to make it 1,5 pixel, and it would also stretch the key area.
The area between the Realforce sticker and the Esc is currently 2 pixel wide. It should be wider, but by adding 1 pixel there would make it just as wide as the distance between the Esc and F1 keys, which is not correct and
that would also mess the key area.
I concluded this was already as perfect as a pixel art can be.
Well done TexasFlood!
Offline TexasFlood
« Reply #354 on: Wed, 20 July 2011, 19:16:28 »
Quote from: Slarg;382379
Now for a challenge, a M15! (which I don't have)
I had such good luck with getting help improving the Kinesis Contour (thanks to sordna) that I thought I'd go ahead and post my first take at an M15 and see what suggestions for improvement come out of it.
« Last Edit: Wed, 20 July 2011, 19:28:48 by TexasFlood »
Offline litster
  • rare caps?! THAT'S A SMILIN
« Reply #355 on: Wed, 20 July 2011, 19:40:48 »
Quote from: TexasFlood;384363
Very nice!!!
Offline Oqsy
« Reply #356 on: Wed, 20 July 2011, 20:05:13 »
Damn fine work here in the last few days. I didn't think the more complex case designs would make it as pixel art!  :thumbsup:
[sigpic]Currently in use: Rosewill RK9000 and CH DT225[/sigpic]
"Private misfortunes make for public welfare."
Offline TexasFlood
« Reply #357 on: Wed, 20 July 2011, 20:21:59 »
Quote from: litster;384378
Very nice!!!
Thanks.  And in case you were wondering, splitting it at this size ended up messy looking ever way I tried it.  If someone else can figure it out that would be cool.  I only found one clean way to split it which is pretty silly, :wink:
Offline litster
« Reply #358 on: Wed, 20 July 2011, 20:24:16 »
Quote from: TexasFlood;384410
That is totally not ergonomical!  LOL!  I need to try this setup for real to see how painful it really is.
Offline TexasFlood
« Reply #359 on: Wed, 20 July 2011, 21:51:48 »
Pixel drawing replacement for the Rosewill RK-9000 image I've been using in my sig.
« Last Edit: Fri, 22 July 2011, 08:19:55 by TexasFlood »
Offline TexasFlood
« Reply #360 on: Wed, 20 July 2011, 22:18:22 »
Quote from: sordna;384240
Since I have both black and white ones, can't leave the latter be left out:
Not sure what the color should be, here's a possible alternative.
Offline sordna
« Reply #361 on: Wed, 20 July 2011, 22:21:50 »
That's a definite improvement!
Offline TexasFlood
« Reply #362 on: Wed, 20 July 2011, 22:46:31 »
Quote from: litster;384412
So yes I think it looks messy but maybe I'm just being too picky, here is what it looks like with the same angle split as the earlier image from the photograph I posted some pages back from the link you provided.
« Last Edit: Thu, 21 July 2011, 00:19:39 by TexasFlood »
Offline litster
« Reply #363 on: Wed, 20 July 2011, 23:01:43 »
Quote from: TexasFlood;384509
Super nice!!!  Is it possible to close them up a little bit, a smaller gap?
Offline TexasFlood
« Reply #364 on: Wed, 20 July 2011, 23:09:19 »
Offline TexasFlood
« Reply #365 on: Wed, 20 July 2011, 23:13:22 »
Quote from: litster;384515
The previous one is total angle of about 56 degrees. If you can describe what you're looking for I can see how it comes out but I'm not going to try and guess what you want again and again, :wink:
Offline litster
« Reply #366 on: Wed, 20 July 2011, 23:14:32 »
Let me take a picture and post it here.  hang on.
Offline litster
« Reply #367 on: Wed, 20 July 2011, 23:20:42 »
Like this:
Offline TexasFlood
« Reply #368 on: Wed, 20 July 2011, 23:44:57 »
Quote from: litster;384525
Like this:
Smaller angle seems to have increased the jaggies a bit. Maybe could be cleaned up, I'm just honestly not motivated to try but if anyone else wants to, have at it, :biggrin:
Offline litster
« Reply #369 on: Wed, 20 July 2011, 23:48:11 »
Quote from: TexasFlood;384536
This looks good.  Thanks!
Offline TexasFlood
« Reply #370 on: Wed, 20 July 2011, 23:54:26 »
Quote from: litster;384538
OK, I couldn't leave it alone, thought there might be some easy tweaks worth trying, any better? After my own compare, I'm sure it is better so going to remove the previous image. This one is a bit messy if you look close but maybe usable in a signature.
« Last Edit: Thu, 21 July 2011, 10:55:56 by TexasFlood »
Offline Input Nirvana
« Reply #371 on: Wed, 20 July 2011, 23:55:04 »
There are 3 Kinesis model colors, black, white, and silver (silver has black keys). The first "white" Kinesis you did is almost the silver model with a tweak or two being needed.
Those look really good. I'm impressed.
« Last Edit: Wed, 20 July 2011, 23:57:18 by input nirvana »
Offline r4pture
« Reply #372 on: Thu, 21 July 2011, 00:07:54 »
Not as impressive as some, but I editted a Northgate Omnikey 101 (w/o Windows Key, like mine is) out of the OPs original Ultra.  Hope you guys like.  :)  Can anyone add real transparency to it (or the AT101W in my sig)?  I cheated and just took the boards background colors and added it, haha.
[sigpic]http://geekhack.org/signaturepics/sigpic12085_2.gif[/sigpic]
~ Dell AT101W~ ~ ~ ~IBM Model M2~ ~ ~Northgate Omnikey 101 ~
Offline quadibloc
  • Layout Fanatic
    • John Savard's Home Page
« Reply #373 on: Thu, 21 July 2011, 00:11:22 »
I tried to close up the angle from the original image of an M15, but I didn't close it up as far. Here's what I achieved:
[ Attachment Invalid Or Does Not Exist ] 21682[/ATTACH]
I used the angle that made for lines being stepped three pixels at a time, instead of two pixels, as in the original one with a wide split. The choices that provide a possibility of a passable result are limited - and the fact that the keys are four pixels wide make using a three pixel step risky already.
I corrected the image because I didn't use transparency properly around the rounded corners originally...
« Last Edit: Thu, 21 July 2011, 00:19:28 by quadibloc »
Offline quadibloc
  • Layout Fanatic
« Reply #374 on: Thu, 21 July 2011, 00:12:44 »
[ Attachment Invalid Or Does Not Exist ] 21681[/ATTACH]
I split it at the angle that made the lines step in units of 3 pixels, unlike the original, which stepped in units of 2 pixels.
Offline litster
« Reply #375 on: Thu, 21 July 2011, 00:16:20 »
Quote from: quadibloc;384546
(Attachment Link) 21681[/ATTACH]
Thanks quadibloc!
eyesnine, would you apply some of your sub pixel anti aliasing magic to the M15's diagonal lines?
Offline TexasFlood
« Reply #376 on: Thu, 21 July 2011, 00:21:31 »
Quote from: litster;384551
Thanks quadibloc!
OK, I can no longer resist. What's a sub pixel? Inquiring minds want to know! :biggrin: And FYI, I posted a revision of the smaller gap version above in case you missed it.  I think it's better although could be better.
Offline TexasFlood
« Reply #377 on: Thu, 21 July 2011, 00:25:51 »
{Attachment removed}
Wow you put some work into that. Certainly looks better than my first attempt.
Nice work.
Offline litster
« Reply #378 on: Thu, 21 July 2011, 00:29:08 »
Quote from: TexasFlood;384557
eyesnine did one pixel art of a Dell keyboard with sub pixel anti aliasing here: http://geekhack.org/showthread.php?19113-Keyboard-pixel-art-things.&p=371547&viewfull=1#post371547
You can get a little more resolution out of the LCD screen.  I don't know how he does it though.
Offline TexasFlood
« Reply #379 on: Thu, 21 July 2011, 00:44:02 »
Quote from: litster;384568
Thanks, I was sceptical but I can see it in the Dell Logo in the linked post.  Now I'm just confused as seeing it's real still leaves me clueless as to how to take advantage of it.  Did some quick googling, looks like it leverages the RGB layout which is very cool, but can you depend on that to always be the same as seemingly there are multiple types of pixel geometry used?
« Last Edit: Thu, 21 July 2011, 00:48:54 by TexasFlood »
Offline TexasFlood
« Reply #380 on: Thu, 21 July 2011, 00:49:20 »
Thanks, I was sceptical but I can see it in the Dell Logo in the linked post.  Now I'm just confused as seeing it's real still leaves me clueless as to how to take advantage of it.  Did some quick googling, looks like it leverages the RGB layout which is very cool, but can you depend on that to always be the same as seemingly there are multiple types of pixel geometry in use?
Offline litster
« Reply #381 on: Thu, 21 July 2011, 00:53:14 »
Quote from: TexasFlood;384586
I think this works fine with all desktop LCDs.  It may not work with OLED screens that are used on smartphones.
Offline TexasFlood
« Reply #382 on: Thu, 21 July 2011, 00:57:43 »
Quote from: litster;384593
Or the big ass dinosaur CRT in my office! Hah, wonder why that thing isn't dead yet, it's old as dirt but big and still sharp.
Offline eyesnine
« Reply #383 on: Thu, 21 July 2011, 02:03:55 »
Basically, how it works is you can divide each pixel three ways horizontally: R, G and B, because a full color square pixel is actually three vertical, rectangular, monochromatic bars.
So, what you do is you have a background color, say {1, 2, 3} and a foreground color {100, 101, 102}. Your pixels may be aligned something like this, for a three pixel horizontal line:
{1, 2, 3} {100, 101, 102} {100, 101, 102} {100, 101, 102} {1, 2, 3}
You can make this line look like it's one third of a pixel longer by changing the color of the last pixel:
{1, 2, 3} {100, 101, 102} {100, 101, 102} {100, 101, 102} {100, 2, 3}
...Or, the first pixel:
{1, 2, 102} {100, 101, 102} {100, 101, 102} {100, 101, 102} {1, 2, 3}
Basically all modern full color monitors have the same R, G, B pixels (it is the standard), but it is true that this technique won't look right on a rotated monitor. Also, it only increases the horizontal resolution.
It is a technique that is used mostly for font rendering, since fonts (Latin fonts especially) really benefit from the extra horizontal resolution. Though, it can definitely be used in pixel art as well.
Here's an example of a tilted line done using subpixel anti-aliasing, at a normal resolution, then at 8x zoom.
« Last Edit: Thu, 21 July 2011, 03:12:15 by eyesnine »
Offline RiGS
« Reply #384 on: Thu, 21 July 2011, 06:16:56 »
Wow, this is cool!
Offline HybridCore
« Reply #385 on: Thu, 21 July 2011, 06:35:48 »
Cool.
Offline TexasFlood
« Reply #386 on: Thu, 21 July 2011, 07:09:17 »
Quote from: r4pture;384545
Nice.  So there were really only a few pixels on that Norghgate that really needed to be transparent. How's this?
Oh and your signature with transparency added...
« Last Edit: Thu, 21 July 2011, 07:23:27 by TexasFlood »
Offline TexasFlood
« Reply #387 on: Thu, 21 July 2011, 07:28:11 »
There is a info on Wikipedia on Subpixel rendering.  Interesting stuff, thanks for the primer eyesnine.  I've heard of this before just never used it, makes my brain hurt, :wacko:
Offline nagisa.F
« Reply #388 on: Thu, 21 July 2011, 10:28:08 »
cooooooool.
Offline TacticalCoder
« Reply #389 on: Thu, 21 July 2011, 11:21:35 »
Disclaimer: I've got a monitor using a DVI cable (typically giving a better image than analog cables) and using very crisp pixels.  I have also very good eyesight.
Am I the only one seeing the 'E' in the "subpixel" rendered DELL logo as green?  Looking at both Linux and Windows ClearType rendering, they're mostly using red'ish pixels to AA what's at left and blue'ish pixels to AA what's at right (even on light gray background).  I think the green component is too flashy in the 'E' on the various DELL keyboards in this thread (is green usage even correct at all?)
For example (right is correct subpixel AA):
[ Attachment Invalid Or Does Not Exist ] 21724[/ATTACH]
you need to see the picture at its regular size or it doesn't make any sense
On-topic: when's the G80-5000 (in a split state) coming?  : )
Offline TexasFlood
« Reply #390 on: Thu, 21 July 2011, 11:29:19 »
I can't see it with my naked eye when at normal size, but broke out a magnifying glass and yes I see green shading on the E in the Dell logo, on my Thinkpad laptop LCD screen.
« Last Edit: Thu, 21 July 2011, 11:31:20 by TexasFlood »
Offline TexasFlood
« Reply #391 on: Thu, 21 July 2011, 11:31:41 »
Offline RiGS
« Reply #392 on: Thu, 21 July 2011, 12:39:53 »
It is green on my Dell U2311h as well.
Offline guilleguillaume
« Reply #393 on: Thu, 21 July 2011, 12:51:07 »
Quote from: RiGS;384784
Me too.
Offline 7bit
  • MX1A-G1DW
Terminal space saver
« Reply #394 on: Thu, 21 July 2011, 14:30:43 »
104 key terminal keyboard (space saver):
more stuff:
post373277
« Last Edit: Thu, 21 July 2011, 14:37:35 by 7bit »
Buy key caps here: Round 5
Buy switches here: CherryMX
Offline TexasFlood
« Reply #395 on: Thu, 21 July 2011, 15:29:25 »
Quote from: TacticalCoder;384747
As long as it takes you to open mspaint and draw it? :wink: That's how I got my Rosewill image, decided to do it myself. I might try the G80-5000, if I have time, we shall see. But it would be nice if more folks gave it a shot.  You can get reference images and usually cut/paste at least parts from earlier work of others to get going. I use GIMP on Linux as I'm used to it and, well, mspaint is difficult to run on Linux, unless you have wine or something set up, which I don't on this box.
« Last Edit: Thu, 21 July 2011, 15:33:38 by TexasFlood »
Offline TexasFlood
« Reply #396 on: Thu, 21 July 2011, 15:33:55 »
« Reply #397 on: Thu, 21 July 2011, 15:38:20 »
Quote from: TexasFlood;384872
Everybody loves a comedian......unless you're in the crosshairs.
I looked through the whole thread, and there are some borderline amazing renditions (accurate!). Very fun, very cool. Maybe someone who is motivated will set up a "pixel art wiki page" as a source for people to pull from.
I'll try a Datahand this weekend. I use Mac so MS Paint won't be my tool of choice. Maybe Paintbrush, which is a Mac equivalent, plus whatever other software...
« Last Edit: Thu, 21 July 2011, 16:04:01 by input nirvana »
Offline TexasFlood
« Reply #398 on: Thu, 21 July 2011, 15:53:24 »
Well I didn't mean to be "target" anyone in particular. Apologies if it came off that way.  I actually did start on a G80-5000 but it's a work in progress.  Pixel stuff isn't terribly difficult.  It's like any computer drawing, just tricky working with stuff that small.
I'd never done pixel art or even really knew what it was. There actually are some pixel art web sites out there which I looked at but I really didn't pick up a lot there, most of it seemed very geared to doing sprites for games or really serious artists who just happen to use mspaint.  There are some amazing, intimidating examples of what can be done on youtube.
I was a little hesitant but finally just dove in and got started.  I started with the Kinesis Advantage which may have been a mistake since I wasn't really able to "borrow" anything from existing work, had to do it all new.  Well technically my first effort was coloring the SIIG keys green to make a GHSS, hah.  The Kinesis Advantage was a bit more ambitious.  But it turned out pretty well.  It did take a while, working on it here and there a I had time, but I learned a lot.  By comparison, for example the recent Rosewill RK9000 wasn't nearly as difficult as a) I had learned a lot and b) there was work I could borrow from.
Offline TexasFlood
« Reply #399 on: Thu, 21 July 2011, 15:59:13 »
Well I didn't mean to be "target" anyone in particular. Apologies if it came off that way. Apologies if it did TacticalCoder. I actually did start on a G80-5000 but it's a work in progress.  Pixel stuff isn't terribly difficult.  It's like any computer drawing, just tricky working with stuff that small.
I was a little hesitant but finally just dove in and got started.  I wanted certain images and didn't want to wait around for someone to maybe do them for me.  If sealcouch was still around and whipping stuff up on demand I probably never would have tried it myself. So if you can pick it up then you can make whatever you want without depending on others and collaboration can be fun as well.
I started with the Kinesis Advantage, for a challenge, which may have been a mistake since I wasn't really able to "borrow" anything from existing work, had to do it all new.  Well technically my first effort was coloring the SIIG keys green to make a GHSS, hah.  On the other hand, it turned out pretty well and although it did take a while I learned a lot.  By comparison, for example the recent Rosewill RK9000 wasn't nearly as difficult as a) I had learned a lot and b) there was work I could borrow from.
« Last Edit: Thu, 21 July 2011, 16:01:51 by TexasFlood »
