Author Topic: Keyboard pixel art things.  (Read 2490525 times)
Offline TexasFlood
« Reply #500 on: Fri, 29 July 2011, 09:21:14 »
Superfluous Parentheses, added these to the wiki, but not sure about the "corrected key colors" version.  Should I link to both black HHKB Pro 2 images in your post (that's what I did for now) or just the corrected one?
Thanks
« Reply #501 on: Fri, 29 July 2011, 09:22:04 »
KeyTronic ErgoForce KT2001PS2US
KeyTronic Logo: [ Attachment Invalid Or Does Not Exist ] 22662[/ATTACH]
SWITCH Logo: [ Attachment Invalid Or Does Not Exist ] 22663[/ATTACH]
(Fixed border)
« Last Edit: Fri, 29 July 2011, 09:26:57 by Superfluous Parentheses »
Current collection: HHKB Pro 2 black on black, HHKB Pro 2 white/grey blank, [strike]Dell AT101W[/strike] (sold to SirClickAlot), 1992 Model M, Key Tronic Ergoforce KT 2001, BTC 5100 C. Dead boards: MS Natural Elite, MS Natural 4000.
« Reply #502 on: Fri, 29 July 2011, 09:23:29 »
Quote from: TexasFlood;389352
Thanks
I think the corrected version is better. The keys on my Black on Black HHKB are almost the same color as the case, so just leave out the older version
Offline TexasFlood
« Reply #503 on: Fri, 29 July 2011, 09:36:30 »
OK, all added to the wiki.
Offline wupi
« Reply #504 on: Fri, 29 July 2011, 11:04:45 »
I changed the Noppo Choc Mini, now it looks like my own.
 Btw, nice Pixel art ! :)
[ Attachment Invalid Or Does Not Exist ] 22681[/ATTACH]
« Last Edit: Fri, 29 July 2011, 11:21:02 by wupi »
Offline jayfinger
« Reply #505 on: Fri, 29 July 2011, 13:00:52 »
My Realforce 87ub.  I started with some of the others I found in this thread. Then fixed the colors to match my setup.
Then I did sub-pixel edits.  On a standard LCD with RGB stripes (the most common) you'll see that this keyboard shows a smaller gap between the keys.  Most of the images in this thread just show a full black pixel between them.
[ Attachment Invalid Or Does Not Exist ] 22690[/ATTACH]
A lot of early posts in this thread refered to sub-pixel editing, but I'm not seeing them.
I may play with this more.  The consensus in this thread is to show a shadow on the bottom pixel of each key (I guess corresponding to the front of the keycap).  With my office setup I have sunlight coming in behind me, and the front of each key appears lighter than the top.  I may play with that for a while.
Offline sordna
« Reply #506 on: Fri, 29 July 2011, 13:08:11 »
Would you be so kind to apply your sub-pixel editing magic to the Kinesis Advantages? The thumb keys, especially on the white ones really need it, to make the lines smooth:
http://geekhack.org/showwiki.php?title=Keyboard+Pixel+Art#Kinesis
Offline TexasFlood
« Reply #507 on: Fri, 29 July 2011, 13:19:20 »
Quote from: sordna;389465
I assume you're addressing this to eyesnine? Good idea, I know I struggled with this and you improved it but still...  And FYI, above images added to wiki.
Offline sordna
« Reply #508 on: Fri, 29 July 2011, 13:25:52 »
eyesnine or Jayfinger. Whoever knows how to work subpixels, I sure don't :-)
Offline TexasFlood
« Reply #509 on: Fri, 29 July 2011, 13:27:22 »
Quote from: sordna;389472
Yep, obviously me neither, :wink:
Offline jayfinger
« Reply #510 on: Fri, 29 July 2011, 15:25:56 »
I'll try to do something soonish.  If not today then maybe on the weekend.  Probably better would be to describe to people HOW I did it.  I don't have a paint program the deals with it directly.  Instead it's tedious playing adjustments of colors based on looking at RGB values and picking new colors based on averaging color components across them.  Tedious.  And then more tedious.
Offline TexasFlood
« Reply #511 on: Fri, 29 July 2011, 23:02:35 »
Quote from: Superfluous Parentheses;389353
KeyTronic Logo:
SWITCH Logo:
Adaptation of Superfluous Parentheses KeyTronics to coloring of my LT Designer
« Last Edit: Fri, 29 July 2011, 23:55:00 by TexasFlood »
Offline TexasFlood
« Reply #512 on: Sat, 30 July 2011, 07:51:51 »
KeyTronic Logo:
SWITCH Logo:
Adaptation of Superfluous Parentheses recently posted KeyTronic images to my Key Tronic LT Designer.
Offline agor
« Reply #513 on: Sat, 30 July 2011, 12:13:23 »
Could anybody do my realforce with just yellow wasd?
Pic here:
http://geekhack.org/showthread.php?20463-Realforce-88-UB-German&p=389951#post389951
KBD8X II - MX 5000 - Realforce 88UB - Phantom - GH60
Offline TexasFlood
« Reply #514 on: Sat, 30 July 2011, 13:02:46 »
Quote from: agor;389960
Pic here:
How's this?
Offline TexasFlood
« Reply #515 on: Sat, 30 July 2011, 13:22:19 »
Pic here:
How's this?
« Last Edit: Sat, 30 July 2011, 17:32:06 by TexasFlood »
Offline TexasFlood
« Reply #516 on: Sat, 30 July 2011, 17:02:03 »
For die-hard Amiga folks, like "mr_a500", an Amiga 1000 keyboard.
Offline TexasFlood
« Reply #517 on: Sat, 30 July 2011, 17:07:20 »
For die-hard Amiga folk, like "mr_a500", an Amiga 1000 keyboard.
Offline quadibloc
  • Layout Fanatic
    • John Savard's Home Page
« Reply #518 on: Sat, 30 July 2011, 21:14:21 »
Since I happened to see this thread, and have also done a bit of the subpixel stuff, here is the white Kinesis Advantage as I've modified it:
[ Attachment Invalid Or Does Not Exist ] 22825[/ATTACH]
Offline sordna
« Reply #519 on: Sat, 30 July 2011, 21:32:10 »
Wow the thumb keys look SO MUCH BETTER! But you replaced the transparency around the edges with green, can you revert the transparency? And fix the thumbkeys on the black kinesis too, pleeeeze ?
Offline TexasFlood
« Reply #520 on: Sat, 30 July 2011, 23:48:31 »
Quote from: quadibloc;390199
(Attachment Link) 22825[/ATTACH]
Quote from: sordna;390202
The thumb keys really do look much better.  If you save as gif or png instead of jpg, you can retain transparency and the compression is lossless.  I prefer png but gif is OK.
« Last Edit: Sat, 30 July 2011, 23:53:45 by TexasFlood »
Offline sordna
« Reply #521 on: Sat, 30 July 2011, 23:52:10 »
Ok, I trust you will fix it while you move it to the wiki :-)
Offline TexasFlood
« Reply #522 on: Sat, 30 July 2011, 23:53:01 »
Offline TexasFlood
« Reply #523 on: Sat, 30 July 2011, 23:57:55 »
Quote from: sordna;390234
I think you'd be better off having quadibloc update it but I can try if needed.  If I could have done this right in the first place we wouldn't be asking for help to improve it, :wink:
Offline sordna
« Reply #524 on: Sun, 31 July 2011, 00:16:12 »
Ok, let's wait for the improved thumbkeys on the black Kinesis too.
Offline Multiple
« Reply #525 on: Sun, 31 July 2011, 01:33:33 »
I think it would be a lot easier if using a 45degree rotation for the thumbkeys would be OK.
[ Attachment Invalid Or Does Not Exist ] 22839[/ATTACH]
It would be interesting to know if it would be possible to create the appearance of sharp lines using subpixel magic, if there are any optimal angles easier to work with than others?
Offline sordna
« Reply #526 on: Sun, 31 July 2011, 01:38:34 »
Easier yes, but they are rotated way too much. I own a few of these keyboards and it's too obvious.
quadibloc did them almost perfect !
Offline Multiple
« Reply #527 on: Sun, 31 July 2011, 01:46:44 »
Looks pretty nice, I agree, but why is it a jpg, that must take away some of the quality?
Offline kps
« Reply #528 on: Sun, 31 July 2011, 10:19:38 »
Quote from: Multiple;390277
Sadly yes, the compression really does a number on it. We can hope quadibloc has a clean copy.
Offline quadibloc
  • Layout Fanatic
« Reply #529 on: Sun, 31 July 2011, 11:56:50 »
My apologies for the rush job. Here it is cleaned up and with transparency.
[ Attachment Invalid Or Does Not Exist ] 22908[/ATTACH]
Actually, I see that there is still a lot of corruption present that crept into the original image as I did the subpixel part with a higher color depth; so I've remedied that now, I think:
[ Attachment Invalid Or Does Not Exist ] 22912[/ATTACH]
« Last Edit: Sun, 31 July 2011, 12:27:51 by quadibloc »
Offline TexasFlood
« Reply #530 on: Sun, 31 July 2011, 20:44:26 »
Quote from: quadibloc;390430
When viewed at normal size I think your original version of the white one looks best.  When zooming in you can see the jpg compression but only when zoomed in.  On my monitor at least the second white version (in post immediately above) shows some gaps in the coloring of those key clusters.  The silver one (second in the post immediately above) looks good, if perhaps not quite as crisp, at least to my eyes, as the original.  So if I try to take just those key clusters out of your first cut and transplant it to our original, it looks like the attached.  I'm only half sure of what I'm typing, hoping that once I get all of the images in one post and can compare them side by side, it will be clear.  So I'll wrap it up for now, submit and take a look, come back and update this text if needed.
Yup, your original, or the transplant, still looks best to me.  What does everyone else think?  Are we covered for white and silver? Still need black I guess if so.
Thanks for the great work quadibloc!
Original:
My transplant to earlier version:
Offline EverythingIBM
« Reply #531 on: Mon, 01 August 2011, 01:16:10 »
Sealcouch, do one of the poo-board.
Offline DivineWind
« Reply #532 on: Mon, 01 August 2011, 01:31:00 »
Why is there no love for the full size Realforces!
Topre REALFORCE 103UB w/ 3-Star Leather Palm Rest   Logitech G700 Mouse  Logitech G35 Headset
Intel i5 2500K @ 4.4 GHz, eVGA GTX 560 Ti SC, 4 GB G. Skill RAM, ASrock P67 Pro3, Hitachi 1TB HDD, Lite Scribe Disk Drive, 750 Watt Antec power supply, Antec 300 Illusion tower, 23" Asus LED 2 MS monitor
Offline TexasFlood
« Reply #533 on: Mon, 01 August 2011, 08:28:14 »
Quote from: DivineWind;390772
Well I don't have one but how does this look?
Offline TexasFlood
« Reply #534 on: Mon, 01 August 2011, 09:35:43 »
Offline TexasFlood
« Reply #535 on: Mon, 01 August 2011, 09:58:43 »
Offline TexasFlood
« Reply #536 on: Mon, 01 August 2011, 10:06:24 »
Offline daerid
    • Rossipedia
« Reply #537 on: Mon, 01 August 2011, 10:25:33 »
If I may be so bold, I really think that sub-pixel blending, or indeed anti-aliasing of any kind, really takes away from the aesthetic appeal of "pixel" art :-O
Just had to chime in with that.
Offline quadibloc
  • Layout Fanatic
« Reply #538 on: Mon, 01 August 2011, 12:24:20 »
I was hesitant, thinking that there were, after all, the others here who were first to address subpixel techniques, and I didn't feel I could easily do the black keyboard... but I finally made the effort. Here are my latest versions of the three colors:
[ Attachment Invalid Or Does Not Exist ] 22965[/ATTACH]
[ Attachment Invalid Or Does Not Exist ] 22966[/ATTACH]
[ Attachment Invalid Or Does Not Exist ] 22967[/ATTACH]
I think I have them looking reasonably well now, without spoiling what had been done well by the original artist of these images, just adding improved tilted thumb keys.
Offline TexasFlood
« Reply #539 on: Mon, 01 August 2011, 12:29:48 »
Quote from: quadibloc;391003
{images removed}
Well I did the original and sordna improved it, but the thumb keys honestly left to be desired.  Yours look great, thanks for the continued improvement!
Offline sordna
« Reply #540 on: Mon, 01 August 2011, 13:29:23 »
The black's thumb keys need to be made darker to match the rest of the keyboard. I tried to fix it but the subpixel thing is stopping me.
Also the very top of the thumb keys in all of them looks too jagged, looks like a V, I think it's missing a lighter-color pixel in between the 2 top corners of every thumb key (in all of 3 images).
Offline TexasFlood
« Reply #541 on: Mon, 01 August 2011, 13:35:16 »
I'll yield to sordna who knows what these look like "in the flesh" which I do not.
Offline DivineWind
« Reply #542 on: Mon, 01 August 2011, 13:54:30 »
That is great!
Offline The Solutor
« Reply #543 on: Mon, 01 August 2011, 13:56:09 »
For the true purists I worked hard to made the otaku touch screen based keyboard, let me know if you want the ISO version too..
:happy:
[ Attachment Invalid Or Does Not Exist ] 22980[/ATTACH]
« Last Edit: Mon, 01 August 2011, 13:59:03 by The Solutor »
Offline TexasFlood
« Reply #544 on: Mon, 01 August 2011, 14:51:06 »
Quote from: The Solutor;391070
:happy:
Wow how long did that take you? Been working on it since the thread started? :wink:
Offline sordna
« Reply #545 on: Mon, 01 August 2011, 14:58:01 »
Offline The Solutor
« Reply #546 on: Mon, 01 August 2011, 15:02:58 »
Quote from: TexasFlood;391101
Err... more or less :lol:
Offline TexasFlood
« Reply #547 on: Mon, 01 August 2011, 15:27:09 »
Quote from: The Solutor;391111
Very Avante-Garde Otaku, :wacko:
Offline The Solutor
« Reply #548 on: Mon, 01 August 2011, 15:39:34 »
Quote from: TexasFlood;391129
I still prefer the mechanical backlit otaku, and the ninja with the legends on the key's back, but I'm sure the younger users will appreciate the touch screen version... :pound:
Offline Oqsy
« Reply #549 on: Tue, 02 August 2011, 01:29:18 »
Solutor just won the internet!
Gave me a much needed chuckle ;)
[sigpic]Currently in use: Rosewill RK9000 and CH DT225[/sigpic]
"Private misfortunes make for public welfare."
