Author Topic: Anyone tried using Novus plastic polish or other products on the Das keyboards?  (Read 2054 times)
Offline spitfire6000
http://geekhack.org/showwiki.php?title=Island:6300
Anyone tried doing this? I want to remove some blemishes and some very unsightly scratches off my das professional s silent keyboard.
Also is there any way to remove the black acryllic covering without voiding the warranty?
Offline Atenacius
I think he just means the top glossy part of the housing
I'm not sure how they can tell but opening the housing voids the warranty, period.
Keychron Q6 GATERON G PRO YELLOW
Vortex Pok3r CHERRY MX RED
Das Keyboard Model S CHERRY MX BLUE
IBM Model M
1391401 09 MAR 93
Offline Atenacius
It's strange because that whole upper right corner is translucent to a degree but directly over the LEDs, it's opaque with the Num, cap and scroll lock symbols transparent. You can see it if you look at it at a steep angle
IBM Model M
1391401 09 MAR 93
Quote from: ripster;365651
What do you mean remove the black acryllic covering?
ripster did the acryllic finish have anything left on it after you used the polish? Like did it still leave behind scratches or blotches?
I am only asking because I dont have novus at home, and it would mean I would be ordering it specifically for this purpose.
Offline Atenacius
Might as well just sand down the gloss finish. No point if you can't enjoy the keyboard for what it is.
IBM Model M
1391401 09 MAR 93
Nah i dont wana sand it down, just wana get rid of my scratches :)
