Author Topic: Keyboard reliability at work  (Read 3283 times)
Offline herfalerf
« on: Thu, 23 June 2011, 13:33:58 »
yesterday i was given a tour of a certain railroad company headquarters located in fort worth, tx.  specifically i was shown the NOC (networking operations center - aka rail traffic control center.) its hurricane and tornado proof, probably bomb proof too since its a part of HLS.  my tour guide was stressing the absolute importance that they put on safety and the fact that mistakes can kill people.  they seemed to take their work seriously, so i was very surprised to see that their dispatchers were using dell rubber dome keyboards.  to me this seems like a big risk considering the emphasis that they put on safety and reliability with their workers.  i know the first time i heard about mechanical keyboards it was in regards to the fact that airlines use them because keyboard failure could be catastrophic.  to me this seems like a similar sitauation and i am kind of amazed at this oversight.
i guess i dont really know what im expecting you guys to say about this, i dont really have any questions it just seemed really odd to me that they would use POS rubber dome's for a job where mistakes with a keyboard could kill people.
woody
  •  Guest
« Reply #1 on: Thu, 23 June 2011, 13:36:46 »
They can do mistakes with any sort of keyboard, so it has to be included in the equation.
Offline PlayerZero
« Reply #2 on: Thu, 23 June 2011, 13:51:24 »
Unfortunately, hardly anyone realizes that rubber domes suck, and that there is an alternative.  According to Wikipedia, the most reliable technology is the Hall-effect switches (skip to that part on the entry).  They are used in airplane cockpits and nuclear power plants.  This doesn't really make up for operator error, which is probably more likely than keyboard error, even in rubber domes.
Extensive research has found your statement to be of inferior quality.  Please revise it.
KEYBOARD:  Leopold FC200RC/AB with Cherry MX Blues
MOUSE:  Logitech G400
Geekhack:  A wiki is worth 1000 threads.
Offline phillip
« Reply #3 on: Thu, 23 June 2011, 15:05:45 »
the BNSF headquarters? :)
Offline The Solutor
« Reply #4 on: Thu, 23 June 2011, 15:07:36 »
Quote from: herfalerf;366304
Durability and reliability are two different beast.
Microswitches keyboards could be more durable but are definitely less reliable for a number of reasons
Offline DaemonRaccoon
« Reply #5 on: Thu, 23 June 2011, 15:12:39 »
Quote from: The Solutor;366399
Care to back up your claims?
122-Key Model F 6110345 1985-03-01 | Model M SSK 1391472 1991-01-22 | Rosewill RK-9000 v1 | KBC Poker X | Filco FKBN87M/PWE2
Offline Adhesive_X
« Reply #6 on: Thu, 23 June 2011, 15:28:22 »
Lets start a collection to send them a couple Xarmor's. Lets save some lives people!
Offline ironman31
« Reply #7 on: Thu, 23 June 2011, 15:36:44 »
I've heard of more mechanical keyboards failing than rubber domes.
Keyboards:
IBM Model M Space Saving Keyboard (Used), HHKB Pro 2 (White, Lettered), Realforce 87U all-45g in White, Filco Majestouch 2 TKL with Cherry MX Browns, Model F PC/AT,  Noppoo Choc Mini (MX Browns), Model F XT, IBM Model M 1397735 (bought NIB), (2) Siig Minitouch (GHSS) one with XM, one with complicated ALPs (modded),2 Dell AT101W, Cherry G80-11900HRMUS (modded with MX browns)
Pointing Devices:
Offline The Solutor
« Reply #8 on: Thu, 23 June 2011, 15:40:58 »
Quote from: DaemonRaccoon;366402
I supposed that the reasons are so evident, that no further explanation was needed...
BTW The basic reason is the number of components and soldering points
Look at the single key: keycap, stem, upper and lower switch housing, two metal contacts, a spring, on blue switches there's an additional piece, then the diode or the led required on some keyboards.
This mean from 7 to 9 pieces per key, so from more than 700 to more than 900 single components per keyboard and from 300 to 600 soldering points.
Now compare this with a basic rubber dome keyboard : 103 keycaps, a dome menbrane, the three layer contact membrane, zero soldering under the keycaps, maybe less than 100 on the whole keyboard.
What do you think is statistically more prone to fail ?
Then the higher protection against liquids and dust.
Then the lower weight which protect the RD keyboard from accidental falls
Then the number of the keyboard produced that helping to iron out the early production defects and the evenness of the whole production.
I can continue, but I think you should have the idea.
P.S. just to be clear I mentioned microswitches keyboards for a reason, Model F (switchless), Model M (membrane) and Topre (switcheless rubber domes) are obviously not included, they are usually both reliable and durable.
Offline Chobopants
« Reply #9 on: Thu, 23 June 2011, 15:46:43 »
Yeah, I've actually seen mechanical switches fail twice during a life GSL match that had to be paused and replaced. The good thing about these cherry switches is that they can be individually replaced and there is no risk of rubber wearing out, effectively killing the whole board.
If hitting a certain key at a certain time determines whether 1000s of people live or die I'm taking a Model M or some crazy Hall-effect board. :)
Realforce 87UW 45g - Filco Blue 87 - Filco Linear R - Filco Brown 104
« Reply #10 on: Thu, 23 June 2011, 15:57:19 »
The Soultor, thank you for backing up your claims.
Offline The Solutor
« Reply #11 on: Thu, 23 June 2011, 16:03:39 »
You are welcome :)
Offline Tony
« Reply #12 on: Fri, 24 June 2011, 01:30:42 »
Mechanical keyboards are good for personal use, only with people who appreciate its quality.
For companies, they replace computer equipments every 2 or 3 years, so the purchasing departments choose rubber dome keyboards since they are a lot cheaper. In the 90s they replace all IBM model Ms and Compaq MX 11800 with brandnew rubber domes.
Imagine we geekhackers now have to replace Filco and Topre keyboards every two years. Sounds silly isn't it?
« Last Edit: Fri, 24 June 2011, 01:52:28 by Tony »
Offline Hydroid
    • http://justin.tv/hydr0id
« Reply #13 on: Fri, 24 June 2011, 02:17:36 »
Haha, most of us don't replace every two years, but a lot of us will grow our collections multiple times within two years.
Intel Core i7 870 @ 2.93GHz | Corsair H50 | 16GB G.Skill DDR3 | Asus P7P55D-E Pro | Galaxy nVidia GeForce GTX 460 SLI
OCZ 60GB SSD | 2x 1TB Seagate Barracuda RAID-0 | Samsung Blu-Ray Burner | Corsair HX-850W | 2x BenQ G2420HD 24"
Leopold FC200R Tenkeyless Blue | Ducky DK9008(B) Blue | Qsenn DT-35 Black PS/2 Rubber Dome |2x Razer Lycosa USB | Microsoft 500 PS/2
Help me support and grow e-sports below!!!
What Happens in Starcraft -- Vlogs -- Twitter
Offline The Solutor
« Reply #14 on: Fri, 24 June 2011, 02:30:50 »
Quote from: Tony;366750
Many companies aren't used to replace keyboards and mice when replacing computers, rubber dome are usually preferred because the price, because are silent, because are reasonably durable and highly reliable, when aesthetic is  a concern scissor boards are usually preferred.
All in all there isn't a single valid reason to go mechanics for a company.
