Author Topic: New Turntable  (Read 3725 times)
Offline ironman31
New Turntable
« on: Thu, 23 June 2011, 22:38:47 »
I might be getting a new turntable soon. Any suggestions? I'd like to keep it under 6 or 700 USD.
I've been looking into the Rega RP1 so far.
Keyboards:
IBM Model M Space Saving Keyboard (Used), HHKB Pro 2 (White, Lettered), Realforce 87U all-45g in White, Filco Majestouch 2 TKL with Cherry MX Browns, Model F PC/AT,  Noppoo Choc Mini (MX Browns), Model F XT, IBM Model M 1397735 (bought NIB), (2) Siig Minitouch (GHSS) one with XM, one with complicated ALPs (modded),2 Dell AT101W, Cherry G80-11900HRMUS (modded with MX browns)
Pointing Devices:
Offline alaricljs
  • I be WOT'ing all day...
New Turntable
« Reply #1 on: Thu, 23 June 2011, 22:46:15 »
When you finish this collection stage if you could please send similar portions of your 'burning cash' to my address I will be sure to provide you with photographic proof that it was appropriately burned.
I speak as someone with young children on the verge of requiring massive expenditures for tuition and the like.
Filco w/ Imsto thick PBT
Offline ironman31
New Turntable
« Reply #2 on: Thu, 23 June 2011, 22:48:04 »
Quote from: alaricljs;366670
lol, I like your response. I've just decided to shift the money I have in my assets somewhere else besides keyboards.
Keyboards:
Pointing Devices:
Offline audioave10
New Turntable
« Reply #3 on: Thu, 23 June 2011, 23:10:04 »
Gee, its been so long since I had a turntable, I don't know what to recommend!
(I used to know back in the 70's and 80's)
DECK Legend "Toxic" - SOLD
96 IBM Model M 82G2383- 95 IBM Model M 92G7453 - SOLD
Cherry G80-3000/Blues
new: MechanicalEagle Z77 RGB/Blues
Offline chuckading
New Turntable
« Reply #4 on: Fri, 24 June 2011, 03:09:22 »
I've been considering the rega rp1 as well. I may go the way of all music hall components and turntable, but that Rega sure looks nice.
Offline Mayor Winters
New Turntable
« Reply #5 on: Fri, 24 June 2011, 05:15:51 »
Technics MK2 SL1200 or SL1210 in case you want it black.
Or, if thats too expensive, a Stanton makes the job.
The more keyboards we have, the more keyboards we want.
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
New Turntable
« Reply #6 on: Fri, 24 June 2011, 06:50:59 »
^ This.
Hard to go wrong with a '1200/1210 really. From what I remember the older Mk2 is preferable though, since it comes with a dust cover and a thicker turntable mat. With the thinner mat on the Mk5/M5D it may be impossible to get the tonearm levelled (it would be too high).
Some don't like the Technics' tonearm, but it isn't a bad mid-weight job (you can tweak moving mass by using different headshells btw). You can still put on another if you really want to.
If the '1200/1210 is too spendy, I'd look at older (near-)TOTL direct drives from the '70s and '80s. (These Technics have some semi-automatic and automatic cousins, too.) Usually the things you (may) need to do to get them up and running again are pretty well-documented. OK, maybe I'd stay away from Sony Biotracers, these tend to be very complex and not exactly a joy to fix.
The Rega is an entry-level "boutique" 'table. You need to take off the platter in order to swap the belt to another pulley if you want to switch speeds (c'mon, which century is this?!), and I can see neither pitch control nor strobo.
In terms of '1210 "clones", the Stanton ST.150 isn't too bad AFAIK. The Audio Technica AT-LP120-USB seems to be very good for the price, too.
« Last Edit: Fri, 24 June 2011, 07:03:55 by keyb_gr »
Offline chuckading
New Turntable
« Reply #7 on: Fri, 24 June 2011, 06:59:26 »
It's not about how it sounds, it's about how it looks. The Rega is just sexy.
New Turntable
« Reply #8 on: Fri, 24 June 2011, 07:31:20 »
Technics MK5 SL1210 is the sexiest in the world IMO, got 2 of this :P
Offline IvanIvanovich
  • Mr. Silk Underwear
New Turntable
« Reply #9 on: Fri, 24 June 2011, 07:36:44 »
If you're wanting something thats a good turntable, but also more of a functional art piece, maybe take a look at the Pro-Ject RPM 1.3 OM3e as well.
Otherwise I second keyb_gr's reccomendations.
Offline ironman31
New Turntable
« Reply #10 on: Fri, 24 June 2011, 10:12:58 »
Well one of the reasons I'm getting a turntable is I have a nice collection of records I'd rather not rebuy as CD's.
And I definitely care about the sound more than the looks. I'll look into the Technics as well.
Keyboards:
Pointing Devices:
Offline alaricljs
New Turntable
« Reply #11 on: Fri, 24 June 2011, 10:43:05 »
My only vinyl collection is wearable.  :bounce:
Offline xargos
New Turntable
« Reply #12 on: Fri, 24 June 2011, 12:56:10 »
Who needs a new turntable?  I have a Pioneer PL-1000A linear tracking table that was restored by the last owner.  Granted you need to have it perfectly balanced to have it track properly at all, but you only need to do that once.  If you can find one I would easily recommend it!
