Author Topic: Are all Cherry MX boards keys interchangeable?  (Read 11035 times)
Offline TacticalCoder
« on: Fri, 24 June 2011, 10:25:09 »
For example, can I take the key from a G8?-????H... and put them on a Cherry MX 5000?
Say I buy a G81-7910HPBUS with double-shot keys "white letters on black keys", would the keys fit an MX 5000?
In general (and for similar layouts) can all MX boards keys be swapped or do MX keys sometimes vary in "shape"?
Offline alaricljs
  • I be WOT'ing all day...
« Reply #1 on: Fri, 24 June 2011, 10:43:57 »
The shape difference is purely between PCB mount and plate mount keys.  plate mount keys don't have the nubs you need to PCB mount, PCB mount have nubs that most plate mounted PCB's don't have the holes for.
Then there is whether the switch has a jumper lead, diode or LED installed.  The PCB you are installing into would need to support the same item or it would need to be left out, which is not difficult.
Filco w/ Imsto thick PBT
Offline gilgam
« Reply #2 on: Fri, 24 June 2011, 10:50:01 »
you are talking abouyt kecaps aren't you ?
they are quite different but keycaps are interchangeable as far as they go on cherry mx switches. Size matters though, with some keycaps differents from others (i'm not talking about the rows)
Realforce 105 FR, HHKB Pro 2 black, 1 Raptor K1 Black Cherry and 1 Raptor K1 Red Cherry , Compag MX 11800  tBrown Cherry, G80-3000 Clear Cherry , G80-1000 Blue Cherry / Ghetto red, Lexmark 1992 SSK Buckling spring, Unicomp 2011 Customizer 102 Buckling spring
and a few rubber dome/scissors keyboards from Apple/Logitech
« Reply #3 on: Fri, 24 June 2011, 10:51:23 »
Quote from: alaricljs;366954
Ah, I'm confused now : )
You mean that the shape of the keycaps depends on how the switch is attached to the keyboard?  If you see one "MX" keycap, you can tell which type of mount the keyboard has?
« Reply #4 on: Fri, 24 June 2011, 10:54:23 »
Quote from: gilgam;366955
You again! (I saw that our little "french" group buy is on its way, thanks!)
Yup, I'm talking about keycaps...
Damn, you type fast Gilgam, "about keycaps" became "abouyt kecaps" (the 'y' managed to appear in the wrong word! ; )
Offline alaricljs
« Reply #5 on: Fri, 24 June 2011, 10:55:08 »
Quote from: TacticalCoder;366956
Since I thought the keycap question was obvious, I assumed you meant the entire switch.  Ignore me :)
« Reply #6 on: Fri, 24 June 2011, 10:58:09 »
Quote from: alaricljs;366961
nah, the information you gave is very interesting too.  My bad.
Offline alaricljs
« Reply #7 on: Fri, 24 June 2011, 11:00:18 »
Well, in regard to keycaps as long as they are Cherry MX compatible and the same size then they are interchangeable except for spacebars.  There are differences in spacing of the levelling mechanism between some manufacturers (see Leopold).
Offline Parabellum
« Reply #8 on: Fri, 24 June 2011, 11:07:15 »
Different keyboards use different methods of attaching and stabilizing bigger keycaps. As you can see in the picture below taken by.. ripster, the three spacebars are mounted differently and are not interchangable. Same goes for other larger keys.
Offline gilgam
« Reply #9 on: Fri, 24 June 2011, 11:11:26 »
Quote from: TacticalCoder;366958
Good no email to send :-)
I switched to my cherry ghetto red and at the beginning i mistype a lot...
you can see in the wiki that there are some differences beetween keycaps for the same row. Some are taller, some wider and can't fit on some keyboards etc...
Edit : i forgot the space bars, it's very annoying to have to mod them...
« Last Edit: Fri, 24 June 2011, 11:48:47 by gilgam »
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #10 on: Fri, 24 June 2011, 12:03:34 »
The other one that can be a nuisance on Cherry brand keycaps is off center stems on certain keys. I know capslock especially, but if I am not mistaken some others had them too on some modifiers.
Offline The Solutor
« Reply #11 on: Fri, 24 June 2011, 13:23:23 »
PCB mount switches can be easily mounted on plate mount keyboards (just cut/break the nubs, and remove the jumper), the opposite is a bit more difficult but still feasible.
BTW as the switch housings can be easily swapped there's no problem at all.
