Author Topic: Can you hook two keyboards at once on a computer?  (Read 21452 times)
Offline TacticalCoder
« on: Sun, 26 June 2011, 11:39:17 »
From a theoretical point of view, is it possible to hook two computers on a PC?
For example, could I build a super-ghetto split-mechanical IBM Model M by chain-sawing two Model Ms?  It would be a bit like the ghetto-mini but more extreme.
But for this to work you'd need to fold two membranes and use two controllers.
Would this work? Would it work with two USB keyboards or one PS/2 and one USB or ?
Would you then be able to type, say, "CTRL+k" by hitting CTRL on the left Model M and 'k' on the right one?
Would that be possible? I'm not saying I'm going to do this, I just want to know if it would be possible.
woody
  •  Guest
« Reply #1 on: Sun, 26 June 2011, 11:41:03 »
Quote from: TacticalCoder;368460
Yes. Same with mice.
Offline keyboardlover
« Reply #2 on: Sun, 26 June 2011, 11:41:34 »
Yes. Geekhackers do it all the time.
Offline reaper
« Reply #3 on: Sun, 26 June 2011, 11:42:49 »
I hooked up 3 keyboards into one computer (2 with USB and 1 with PS/2) and they all work perfectly.
][/URL]
Din Eli
Offline alaricljs
  • I be WOT'ing all day...
« Reply #4 on: Sun, 26 June 2011, 11:43:51 »
Yes - More involved answer: I just tested shift/ctr/alt/win combos across 2 KBs on 2 different hubs and all the combos I tried worked.
Filco w/ Imsto thick PBT
Offline The Solutor
« Reply #5 on: Sun, 26 June 2011, 12:06:15 »
I just add that connection can be mixed, you can have, say, a ps/2+ one or more USB + one BT keyboards.
At least on Windows and Linux.
« Last Edit: Sun, 26 June 2011, 12:08:22 by The Solutor »
Offline sordna
« Reply #6 on: Sun, 26 June 2011, 12:28:29 »
Yes, even key combos work. For example you can hold shift on one keyboard, and type letters on the other, and you'll get caps. Guess it's a way to increase KRO :-)
I have however noticed that when I plug in a 2nd keyboard, the repeat rate is different. I have to re-run "xset -r rate" (I'm using linux) to give the new keyboard the desired repeat rate.
HTH.
Offline mmmty
  • bang! bang!
« Reply #7 on: Sun, 26 June 2011, 12:29:36 »
Quote from: reaper~;368463
[/URL]
Can you do CTRL on PC#1, ALT on PC#2, DEL on PC#3 at the same time and get CTRL-ALT-DEL??
Keyboardless
Offline reaper
« Reply #8 on: Sun, 26 June 2011, 12:32:19 »
^ Sorry, that was a while ago.  I had them all packed up now.  Currently I'm only using 1 keyboard at a time (no need for multiple ones).  I did that just to see if it would work. =P
Din Eli
Offline sordna
« Reply #9 on: Sun, 26 June 2011, 12:38:05 »
Quote from: mmmty;368482
Your sig shows you have plenty of keyboards, why don't you try it and post the results.
Offline mmmty
  • bang! bang!
« Reply #10 on: Sun, 26 June 2011, 12:45:45 »
I could that but I thought reaper had it set up and ready to go. I'm trying it now...
I used 2 different models of Dell keyboards and a Poker and CTRL-ALT-DEL works!!
« Last Edit: Sun, 26 June 2011, 12:49:29 by mmmty »
Keyboardless
Offline sordna
« Reply #11 on: Sun, 26 June 2011, 12:48:43 »
Cool! If you have extra hands around, you could try some NKRO testing utilities too, that might be interesting.
Offline reaper
« Reply #12 on: Sun, 26 June 2011, 13:01:09 »
Quote from: sordna;368488
Sorry, laundry day plus I have to run some errands and mmmty has already tried it.
Din Eli
Offline mmmty
  • bang! bang!
« Reply #13 on: Sun, 26 June 2011, 13:02:12 »
No extra hands. I'm all alone at work. I could use my feet. Nobody will know my toes were on their keyboards  :)
Keyboardless
Offline PlayerZero
« Reply #14 on: Sun, 26 June 2011, 13:03:16 »
All this is well and good, but a super-ghetto split keyboard would, I think, be much more awesome.
Extensive research has found your statement to be of inferior quality.  Please revise it.
KEYBOARD:  Leopold FC200RC/AB with Cherry MX Blues
MOUSE:  Logitech G400
Geekhack:  A wiki is worth 1000 threads.
Offline reaper
« Reply #15 on: Sun, 26 June 2011, 13:03:21 »
Quote from: mmmty;368506
lol  Go for it. =D
Din Eli
Offline hoggy
  • * Ergonomics Moderator
« Reply #16 on: Sun, 26 June 2011, 13:44:51 »
Can't resist a chance to plug a previous project...
Offline alaricljs
« Reply #17 on: Sun, 26 June 2011, 13:48:05 »
I find it interesting that the picture includes kitchen cabinets and a potato.  Don't you have a computer to hook it up to, maybe even on a desk?  ;)
Offline hoggy
« Reply #18 on: Sun, 26 June 2011, 13:59:48 »
Sadly, the best light is in the kitchen.
Offline theferenc
« Reply #19 on: Sun, 26 June 2011, 14:00:28 »
I think the potato adds a certain charm to the picture, personally.
Oh, and I'm pretty sure this is only a windows thing, but if you hold down a key on each keyboard that is plugged in, you get an exactly alternating sequence of the keys that are held down.
Offline sinis
« Reply #20 on: Sun, 26 June 2011, 14:02:00 »
try two LAN cable :P
Offline alaricljs
« Reply #21 on: Sun, 26 June 2011, 14:05:32 »
I do like the potato... although I don't think anything perishable would do too well on my desk.  I keep the decorations down to a few minifigs and a rock.  Everything else is just detritus from the days/weeks projects.
« Reply #22 on: Sun, 26 June 2011, 17:45:23 »
Quote from: PlayerZero;368508
Well at least thanks to all the good answers and modifier keys test etc. now I know it's probably doable.  Now that would be one heck of an IBM Model M mod : )
« Reply #23 on: Sun, 26 June 2011, 17:46:55 »
Quote from: hoggy;368522
Looks great.  Do you have a link to some article/thread/website about it? (you should add it to your sig)  (and you should add a sig)
Offline The Solutor
« Reply #24 on: Sun, 26 June 2011, 19:00:03 »
Quote from: mmmty;368493
Maybe better don't ask what you used as a third hand...:happy:
Offline mmmty
  • bang! bang!
« Reply #25 on: Sun, 26 June 2011, 21:32:42 »
I don't use my 3rd hand for typing. It causes a lot of typos because it soooo big  :)
Nah, all 3 keyboards were close enough together. I was able to stretch my hands from 1 keyboard to another. I should have tried Windows Sticky Keys using all 3 keyboards.
Keyboardless
Offline sordna
« Reply #26 on: Sun, 26 June 2011, 22:11:40 »
So, what kind tests did you do? Did all the key combinations work ?
Offline mmmty
  • bang! bang!
« Reply #27 on: Sun, 26 June 2011, 23:37:08 »
I just did CTRL on KBD#1, ALT on KBD#2, and DEL on KBD#3. CTRL-C, CTRL-V worked. I think other key combos should work too. I just tried Sticky Keys and it worked. I turned on Sticky Keys, hit CTRL on KBD#1, ALT on KBD#2, and DEL on KBD#3 and the options came up.
Keyboardless
Offline sordna
« Reply #28 on: Sun, 26 June 2011, 23:44:32 »
Thanks for sharing your findings!
Offline Tony
« Reply #29 on: Mon, 27 June 2011, 06:43:40 »
I am using two keyboards right now, one ps/2 and one usb. I am using multiple-port usb and all extra usb ports work perfectly.
Since the keyboards and mice are not bandwidth intensive, I think that you can attached unlimited number of keyboards and mice through usb ports.
Offline almasy
« Reply #30 on: Mon, 27 June 2011, 06:52:23 »
The sidewinder X4 runs 4 keyboard signals through its USB port for its pseudo-nkro (with ghosting problems on windows)
should work fine with 2 keyboards, they only send a signal for each key pressed, if you hold two keys it two seperate signals not a ctrl-k signal but a ctrl signal and a k signal so there won't be problems with modifier keys from one and pressing non-modifiers on the other.
Offline didjamatic
« Reply #31 on: Mon, 27 June 2011, 06:56:19 »
I ran 2 Realforce 87u's in tandem for a while to test the ergonomics of having a wide split typing position.  They kept up perfectly and never had an issue.
« Last Edit: Mon, 27 June 2011, 07:00:13 by didjamatic »
Offline Lester
« Reply #32 on: Mon, 27 June 2011, 07:02:02 »
[/URL]
A ducky! <3
Offline didjamatic
« Reply #33 on: Mon, 27 June 2011, 07:03:15 »
Oh BTW, many of you have laptops with your mechanical boards and/or numpads so you're already using at least 2-3 keyboards at once.
Offline hoggy
« Reply #34 on: Mon, 27 June 2011, 12:41:32 »
Quote from: TacticalCoder;368609
It's not that special - just two access keyboards programmed up.  There's a few more pictures in this thread - there's more pictures of potatoes too...
Offline Chobopants
« Reply #35 on: Mon, 27 June 2011, 13:18:35 »
I have 3 keyboards plugged into my PC at home and for a long time had 2 of my Filcos plugged in here at work to switch between.
Realforce 87UW 45g - Filco Blue 87 - Filco Linear R - Filco Brown 104
