Author Topic: POM keycaps?  (Read 1810 times)
Offline wompwomp
POM keycaps?
« on: Sun, 26 June 2011, 18:27:40 »
I was wondering how POM keycaps feel in comparison with ABS and PBT keycaps.
Offline alaricljs
  • I be WOT'ing all day...
POM keycaps?
« Reply #1 on: Sun, 26 June 2011, 18:29:15 »
My Ducky PBTs are very similar to my experience with Noppoo Choc Mini POMs.  ABS is nothing like them.
There's a bit of grain (similar to fine used sandpaper) on POM/PBT whereas ABS is smooth unless the coating is textured.  ABS textured coatings wear out far faster than POM/PBT.
Filco w/ Imsto thick PBT
Offline wompwomp
POM keycaps?
« Reply #2 on: Sun, 26 June 2011, 21:46:30 »
I see.
I also have another question and don't really feel like making another thread.
What exactly does 2KRO mean? Does it mean that you may only press up to 2 keys simultaneously at once? I know NKRO means your allowed to press as many keys at once and they will all register.
Offline alaricljs
POM keycaps?
« Reply #3 on: Sun, 26 June 2011, 21:57:20 »
2KRO is basically what you just described.  So is 3/4/6KRO which are other possibilities.   The exception to this is that generally modifiers also work on top of those number of keys pressed.
