Author Topic: 170g keys!  (Read 11271 times)
Offline almasy
170g keys!
« on: Mon, 27 June 2011, 06:35:18 »
got a keyboard here with 170cN of force needed to actuate the keys.
anyone beat me?
Offline PlayerZero
170g keys!
« Reply #1 on: Mon, 27 June 2011, 06:56:06 »
Proof?  As in RipOMeter test.  And what keyboard is it?  You could certainly be lying...  I might as well say, "I have a keyboard which requires 500cN of force to actuate...
Extensive research has found your statement to be of inferior quality.  Please revise it.
KEYBOARD:  Leopold FC200RC/AB with Cherry MX Blues
MOUSE:  Logitech G400
Geekhack:  A wiki is worth 1000 threads.
Offline ~Blood~
170g keys!
« Reply #2 on: Mon, 27 June 2011, 07:04:36 »
what kind of measurement is c in cN?
you weird americans, still measuring in body parts
Offline bhtooefr
    • bhtooefr.org
170g keys!
« Reply #3 on: Mon, 27 June 2011, 07:31:31 »
Centinewtons.
Offline The Solutor
170g keys!
« Reply #4 on: Mon, 27 June 2011, 07:33:00 »
Quote from: almasy;368788
anyone beat me?
Likely many ATM tamper-proof keyboards.
Offline The Solutor
170g keys!
« Reply #5 on: Mon, 27 June 2011, 07:33:51 »
Quote from: bhtooefr;368802
centinewtons.
omg
Offline morethanless
170g keys!
« Reply #6 on: Mon, 27 June 2011, 09:57:45 »
centinewton=gram
Filco Majestouch 2 Tenkeyless LineaR
(Cherry MX Red)
Offline The Solutor
170g keys!
« Reply #7 on: Mon, 27 June 2011, 10:06:42 »
Quote from: morethanless;368835
centinewton=gram
Hahah.
I read too fast from the phone.
I interpreted it as centi-new-tons. (so i thought to some obscure imperial unit).
I hope next time gravity will be discovered by John Smith:happy:
170g keys!
« Reply #8 on: Mon, 27 June 2011, 10:14:20 »
Then it would be called centi-smith :bump2:
I still wait for the OP to disclose his keyboard model.
The heaviest key I tested where MX black with end-force of 80g
(Cherry MX Red)
Offline kps
170g keys!
« Reply #9 on: Mon, 27 June 2011, 10:19:34 »
centinewton=gram
If only the meter had been chosen to make g = 10 m/s².
Offline Titmouse
170g keys!
« Reply #10 on: Mon, 27 June 2011, 10:22:15 »
More like "if only the almighty had made the Earth such that g = 10 m/s²".
"Surprise! We threw away your old ugly keyboard and got you a brand new ergonomic keyboard from Microsoft!"  -- Findecanor
Offline The Solutor
170g keys!
« Reply #11 on: Mon, 27 June 2011, 10:23:55 »
Quote from: morethanless;368843
Yes, less misunderstandable...
the heaviest key I tested where MX black with end-force of 80g
The stiffer I tried (other than the tamper proof ones) is the BL82 with the silicon membrane installed I haven't measured it but should be more than 100g, i tested the switches w/o the coiled spring and the keyboard was still usable.
Offline The Solutor
170g keys!
« Reply #12 on: Mon, 27 June 2011, 10:25:55 »
Quote from: kps;368846
I haven't wrote it, as I've been accused of being pedantic...
170g keys!
« Reply #13 on: Mon, 27 June 2011, 10:26:31 »
Pah, that's only details and rounding erros.
centi newton = gram is ok for this thread, we don't make keyboard science (I leave that to Ripster)
(Cherry MX Red)
170g keys!
« Reply #14 on: Mon, 27 June 2011, 10:30:01 »
Here you can calculate your personal G
http://www.ptb.de/en/org/1/11/115/_index.htm
just click on start GIS
(Cherry MX Red)
Offline The Solutor
170g keys!
« Reply #15 on: Mon, 27 June 2011, 10:32:44 »
Quote from: Titmouse;368849
And 1 atm=1 bar...
170g keys!
« Reply #16 on: Mon, 27 June 2011, 10:39:21 »
What is ATM?? automated teller machine?
I know that ATÜ is an old unit equal to n+1 Bar.
And there is hPa = mBar
(Cherry MX Red)
Offline The Solutor
170g keys!
« Reply #17 on: Mon, 27 June 2011, 10:45:43 »
Quote from: morethanless;368863
Yes, at least in Italy we call them Bancomat (just noticed I managed to use the same acronym with two different meaning in the same thread :)  )
Intended as a pressure unit, 1 atmosphere=1.01325 bar, or as you said 101,325 Pascal
or
1 bar = 100 Pascal = 0.98692 atm
« Last Edit: Mon, 27 June 2011, 10:47:44 by The Solutor »
Offline ~Blood~
170g keys!
« Reply #18 on: Mon, 27 June 2011, 10:49:13 »
what.
SI units are superior to americans however
Offline The Solutor
170g keys!
« Reply #19 on: Mon, 27 June 2011, 10:52:06 »
Grams and Newtons are both SI units
Offline HaiiYaa
170g keys!
« Reply #20 on: Mon, 27 June 2011, 13:56:52 »
Offline SecrtAgentMan
170g keys!
« Reply #21 on: Mon, 27 June 2011, 15:10:34 »
Just an American unit for atmospheric pressure
1ATM=760mmHG=760torr
Offline The Solutor
170g keys!
« Reply #22 on: Mon, 27 June 2011, 15:21:24 »
Quote from: SecrtAgentMan;368993
Not really an american unit, just an old international one.
Offline ch_123
170g keys!
« Reply #23 on: Mon, 27 June 2011, 15:27:26 »
I've typed on vintage terminal keyboards where the set-up buttons used a stiffer switch than the normal keys to prevent accidental presses. Probably in the 100g+ region.
Offline Pylon
170g keys!
« Reply #24 on: Mon, 27 June 2011, 15:28:22 »
1 atm = average atmospheric pressure at average sea level = 101,325 Pa = 1.01325 bar = 760 mm Hg = 760mm Torr = 14.696 pounds per square inch
STP = 1 atm at 273 K
170g keys!
« Reply #25 on: Mon, 27 June 2011, 15:28:36 »
Quote from: The Solutor;369003
Oh okay, thought it was something like how we use inches/centimeters whereas the rest of the world uses meters.
170g keys!
« Reply #26 on: Mon, 27 June 2011, 16:01:56 »
Torr is totally new for me.
(Cherry MX Red)
Offline The Solutor
170g keys!
« Reply #27 on: Mon, 27 June 2011, 16:43:39 »
Quote from: morethanless;369044
Torr a unit is dedicated to Evangelista Torricelli the Italian who invented the mercury barometer.
Is still widely used as unit of the human blood pressure although not part of SI
1 Torr = 1mm of mercury (at sea  level) on the one meter long Torricelli's tube, as you may remember from the school time the normal pressure is worth about 76cm of mercury on such tube.
So 760 Torr
Offline eyesnine
170g keys!
« Reply #28 on: Mon, 27 June 2011, 16:46:22 »
I put a spring from a ball point pen in my Caps Lock once. (Using Cherry MX Browns) I didn't measure how much force it took to press it down, but I would think it was well over a kilogram.
First time I pressed it I thought it wasn't going to budge, but sure enough I just really needed to lean on it. It did the job of preventing any accidental presses, but I thought maybe it did too good of a job.
I ended up using an MX Gray in my Caps Lock and an MX Clear on my space bar. I don't like the Gray switch in my space bar. It should be much lighter than that, IMO.
« Last Edit: Mon, 27 June 2011, 16:54:06 by eyesnine »
Offline The Solutor
170g keys!
« Reply #29 on: Mon, 27 June 2011, 16:56:41 »
I have an "ergo gray" on my spacebar  (gray stem, clear spring) in other words it's just a clear, but grey
Offline PlayerZero
170g keys!
« Reply #30 on: Mon, 27 June 2011, 22:45:32 »
Interesting how the OP hasn't posted at all yet...  But those metal domes look pretty awesome :)
Offline HaiiYaa
170g keys!
« Reply #31 on: Tue, 28 June 2011, 13:26:22 »
Quote from: PlayerZero;369242
Imagine the 500g version... ouch
"Already tested in a diameter of 5.5mm and 280g activation force (2.8 N) or 5mm and 170g force (1.7 N), the product is customized upon request with forces ranging from 100g to 500g and more!"
Offline alaricljs
  • I be WOT'ing all day...
170g keys!
« Reply #32 on: Tue, 28 June 2011, 13:46:20 »
What is the point of a button that you actually have to attack to actuate it?  I mean... there's vandal-proof and then there's daring the vandal to blow **** up.
Filco w/ Imsto thick PBT
170g keys!
« Reply #33 on: Tue, 28 June 2011, 13:54:03 »
The 500g is perfect for him
EDIT: and watch till the end.
[video=youtube;M8pR1rZZHEs]http://www.youtube.com/watch?v=M8pR1rZZHEs[/video]
« Last Edit: Tue, 28 June 2011, 18:16:14 by morethanless »
(Cherry MX Red)
Offline HaiiYaa
170g keys!
« Reply #34 on: Tue, 28 June 2011, 17:44:19 »
Quote from: morethanless;369538
It can only be a razer blackwidow the way the keycaps just fall off like nothing
« Last Edit: Tue, 28 June 2011, 18:00:40 by HaiiYaa »
Offline Mr. Perfect
170g keys!
« Reply #35 on: Tue, 28 June 2011, 21:22:25 »
He won't. At least, not in a serious or helpful way. It's the same guy who popped in a while ago and started the largest troll thread I've ever seen.
Mr. Perfect - A name fraught with peril.
G80-8113HRBUS MX Clears, FC200R MX Clears, RK-9000v2 MX Blues.
Offline Oqsy
170g keys!
« Reply #36 on: Tue, 28 June 2011, 22:16:13 »
He wants you to eat your melted ****. True story.
[sigpic]Currently in use: Rosewill RK9000 and CH DT225[/sigpic]
"Private misfortunes make for public welfare."
Offline FrittenFett
170g keys!
« Reply #37 on: Wed, 29 June 2011, 08:34:50 »
Hey, perfect translation
But you forgot to mention he calls you 12x sonofa*****.
And 8x "I'll kill you all".
So far
« Last Edit: Wed, 29 June 2011, 08:43:16 by FrittenFett »
Offline Oqsy
170g keys!
« Reply #38 on: Wed, 29 June 2011, 14:41:03 »
German hissies are scary.
Five years of german were not wasted ;)
Offline FrittenFett
170g keys!
« Reply #39 on: Wed, 29 June 2011, 14:48:05 »
...but my 5 years of French were, definetely!
