Author Topic: Where to buy MX Red switches?  (Read 2817 times)
Offline SecrtAgentMan
« on: Mon, 27 June 2011, 15:29:48 »
I've been looking at mouser and digikey...nothing :/
Does anyone know of a site that sells them individually?
Offline dreamingftw
« Reply #1 on: Mon, 27 June 2011, 17:00:06 »
Join the qtan groupbuy and get yourself a plu-87 red switch unless you were looking for a brand in particular.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #2 on: Mon, 27 June 2011, 18:27:43 »
You could buy up to 5 from this ebay listing. Perhaps they could get more?
Offline reaper
« Reply #3 on: Mon, 27 June 2011, 18:33:44 »
Quote from: dreamingftw;369090
I think OP is looking for switches itself and not the keyboard but I could be wrong. =P
Din Eli
« Reply #4 on: Mon, 27 June 2011, 19:13:41 »
Yep, just looking for switches and not a keyboard.
If I take a brown switch, take out the brown stem and replace it with a red stem would that work?
I'm just interested in replacing the spring, and seeing as how both red/brown take 45g of force I wanted to make sure it would work without a hitch.
« Last Edit: Mon, 27 June 2011, 19:17:32 by SecrtAgentMan »
Offline Torgee
« Reply #5 on: Mon, 27 June 2011, 19:21:49 »
to my knowledge, and i'm pretty sure about it,
you could use either mx brown or mx blue spring with a red stem.
brown/blue/red springs are supposed to b the same.
black stems are close, if not the same as red stems, so black stem/blue spring should work,too.
refered to as ghetto reds.
im too sleepy right now to grab some links, but the are some for according threads :P
« Reply #6 on: Mon, 27 June 2011, 19:23:46 »
Blue or brown springs on a black stem would give you a red more or less. Hope you're doing a pcb mount so you don't have to desolder / solder a bunch of switches to swap springs and stems. If its a plate mount you need to be sure before going to all that work.
« Last Edit: Mon, 27 June 2011, 19:27:22 by lysol »
« Reply #7 on: Mon, 27 June 2011, 19:26:39 »
I already have the red stems, so getting blue/brown switches and taking out the stem and swapping it with the red stem should be fine then?
Thanks guys :)
Offline The Solutor
« Reply #9 on: Mon, 27 June 2011, 19:49:22 »
Thanks Solutor for the link, do you know what currency they use?
I forget if it's New Taiwanese Dollar (NTD) or Taiwan Dollar (TWD)
Offline keyboardlover
« Reply #10 on: Mon, 27 June 2011, 19:51:21 »
Quote from: SecrtAgentMan;369167
Thanks guys :)
That's correct. Check out how I modded my "kustom keyboards" in my sig.
« Reply #11 on: Mon, 27 June 2011, 19:53:37 »
Quote from: keyboardlover;369177
Just what I wanted to hear, thanks.
Offline The Solutor
« Reply #12 on: Mon, 27 June 2011, 19:57:10 »
Quote from: SecrtAgentMan;369175
From wikipedia.
In English usage the New Taiwan Dollar is often abbreviated as NT, NT$, NT Dollar or NTD, while the abbreviation TWD is typically used in the context of foreign exchange rates. Subdivisions of a New Taiwan Dollar are rarely used, since practically all products on the consumer market are being sold at whole dollars.
Offline litster
  • rare caps?! THAT'S A SMILIN
« Reply #13 on: Mon, 27 June 2011, 20:42:19 »
« Reply #14 on: Mon, 27 June 2011, 21:15:00 »
@OP - if you need more red stems let me know; I have some.
« Reply #15 on: Mon, 27 June 2011, 22:31:44 »
I'll let you know, as of now I'm just considering replacing the springs and re-soldering switches.
