Author Topic: Stenography machine  (Read 2013 times)
Offline Parak
Stenography machine
« on: Mon, 27 June 2011, 19:57:45 »
Datahand too mainstream for you? Want to rewire your brain? Now's your chance
Offline REVENGE
Stenography machine
« Reply #1 on: Mon, 27 June 2011, 20:11:04 »
Quote from: Parak;369182
So what exactly does this thing do?
Offline Parak
Stenography machine
« Reply #2 on: Mon, 27 June 2011, 20:19:18 »
Quote from: REVENGE;369186
It's used for fast transcription into shorthand format. One would need to be specifically trained to do that, but it's generally the fastest means of typing "plain" text out (after translation) [ymmv]
Offline eyesnine
Stenography machine
« Reply #3 on: Mon, 27 June 2011, 20:50:07 »
Correct me if I'm wrong, but don't stenographers type using phonetics? In other words, this is not a character-accurate input method, is it?
So, it's useless for anything but spoken words. For example, it can't be used for games, apps, programming, even forum posting beyond the basics.
I have often wondered if there was a modern stenography machine that could be used for character-accurate input.
« Last Edit: Mon, 27 June 2011, 21:14:21 by eyesnine »
