Author Topic: Interest check for raised legend 'ninja' style keycaps  (Read 21057 times)
Offline IvanIvanovich
  • Mr. Silk Underwear
« on: Tue, 28 June 2011, 11:20:45 »
NO LONGER FOR RAISED LEGEND STYLE. NOW CONSIDERING PAD PRINTED ONLY.
UPDATE 2: Quote from SP is $500 per legend to get JUST the molds made = $51,500 for 103 (space would not have a legend), $43,000 for 86, $18,500 for 37, so this is massively expensive. We would need a LOT of orders, at least 800 to justify this to get the per unit cost down to something reasonable. I think this will not happen. I asked if there was anything to bring the cost down, and the response was pad printing...
UPDATE 3: Since some of you expressed interest in pad printed ninja keys, I followed up. Prices as follows: 30 sets - $96.57 / set, If there is enough interest for more than 30 sets, obviously the price will decrease further. All sets must be the same color combination. Legends can be in the following colors: Black, Gray, Blue, White, Green, Red, and Yellow.
If you are interested in PAD PRINTED ninja keycap set please post. If you have already posted, please post again if you are interested in pad printed set. I will not count you if you do not expressly include "Yes pad printed" in your reply.
« Last Edit: Tue, 05 July 2011, 16:42:43 by lysol »
Offline reaper
« Reply #1 on: Tue, 28 June 2011, 11:28:54 »
I would if it isn't too expensive.
Din Eli
Offline khanable
  • Keyboard Punk
« Reply #2 on: Tue, 28 June 2011, 11:39:54 »
Quote from: reaper~;369463
Me too if they come in black :p
Offline peda
« Reply #3 on: Tue, 28 June 2011, 12:01:00 »
+1 but i like the ninja style quiet a lot and therefore my tolerance for the price might be pretty high... ;)
« Reply #4 on: Tue, 28 June 2011, 12:10:29 »
After several back and forths with Melissa making it clear what needs to be done, it sounds like a mold for every key with the raised legends will need to be made. Hopefully I'll have the quote soon and will update. If there is enough interest in black I see no reason why we couldn't get both or change from white to black. It all depends on who is interested in what, and if we can get enough sets to make it viable so they don't cost $90 a set.
Offline ogreofdakka
« Reply #5 on: Tue, 28 June 2011, 12:13:42 »
Keycaps of Awesomeness
+1 Interest
Keyboards: KBC Poker RED, Noppoo Choc Mini RED, QSENN DT-35
Pointer: Logitech G400
« Reply #6 on: Tue, 28 June 2011, 12:21:47 »
I'm interested if the price is right
Offline onesie
« Reply #7 on: Tue, 28 June 2011, 12:26:56 »
also interested
Ducky 1087-brown/blue mix, Cherry Clears, mx11800 with ergo clears
Offline placebo guy
« Reply #8 on: Tue, 28 June 2011, 17:09:43 »
In for a set, perhaps two if price is good.
07/05/11 - Too rich for my blood.  I'm out.  Sorry.
« Last Edit: Tue, 05 July 2011, 17:24:16 by placebo guy »
Leopold TKL MXRed; RF 103U 55G; WASD MXBlack; Unicomp Spacesaver; AT101W; RK-9000 Blue; various Filco
Offline daerid
    • Rossipedia
« Reply #9 on: Tue, 28 June 2011, 20:08:43 »
Quote from: placebo guy;369640
Ditto
Offline BiNiaRiS
« Reply #10 on: Wed, 29 June 2011, 03:06:08 »
so these will be be molded into the side of the keys and not sticker?
KMAC 2 w/ErgoClears
Offline Nox
« Reply #11 on: Wed, 29 June 2011, 04:12:09 »
I'd be down for a set
Offline Brodie337
« Reply #12 on: Wed, 29 June 2011, 05:47:40 »
If theres a Poker set, Im definitely in, if the price isn't stratospheric.
« Reply #13 on: Wed, 29 June 2011, 07:13:15 »
Yes thats correct, the legend will be in the same part as the key as a single injection mold. Keycaps would be poker compatible, you will just have some extra ones. Still working out some of the details on design to try to keep the cost down. I had originally thought 104 set for highest compatibility, but that might get shaved down to an 87, or even 37 if the price is too high. Since a new mold will need to be made for each key, obviously the more molds that need to be made the more it will cost. Hopefully I'll have some quotes by the end of the day.
Offline siz2rp
« Reply #14 on: Thu, 30 June 2011, 13:51:31 »
I would be in for a full set of these with white text on black keys, or black text on white keys.
Offline MissileMike
« Reply #15 on: Thu, 30 June 2011, 14:01:11 »
In, assuming they're black and Leopold-compatible.
BS: 5 Space Savers  ||  9 42H  ||  10 1391401 or similar  ||  1x 1390131  || AT&T 305b  ||  Dell Model M
Cherry: Leopold FC200RC/AB  ||  3 Ducky 1087  ||  PLU ML87 ||  Cherry G80-8113LUVEU-2  browns
Alps: Filco Zero Tenkeyless (fukka)  ||  ABS M1  ||  3x Dell AT101w  ||  Ancer KF-191  ||  6 Vivanco Compact
Misc: NMB RT6855T+  ||  NMB RT101 Space Invader  ||  Dell Quietkey  ||  Ge Fanuc Industrial Metal
« Reply #16 on: Thu, 30 June 2011, 23:02:53 »
Updated op with quote. Looks like this idea is going to be cost prohibitive.
Offline dreamingftw
« Reply #17 on: Fri, 01 July 2011, 12:09:44 »
crazy expensive...
Offline peda
« Reply #18 on: Fri, 01 July 2011, 12:38:52 »
Quote from: dreamingftw;371278
crazy expensive...
yes, unfortunately...
or anybody willing to buy 780 sets so the rest of us get if for a descend price?
Offline daerid
    • Rossipedia
« Reply #19 on: Fri, 01 July 2011, 14:25:43 »
I for one wouldn't mind pad printing on these caps. The legends won't be getting much wear anyways, so the printing should stay for quite a while.
Offline noodles256
  • le legendary
« Reply #20 on: Fri, 01 July 2011, 16:38:15 »
just around my price range
AF | Ducky YOTD |
Offline JAMM0N
« Reply #21 on: Fri, 01 July 2011, 23:41:18 »
how much would be for a set?
Computer: Filco Linear Cherry MX RED XBOX: HHKB Pro
Incoming: KBC Poker BROWN
« Reply #22 on: Sat, 02 July 2011, 08:46:07 »
Oh only $3500 per set, quite a deal. I don't think pad printing is a good option. Besides there are dyesubed ninja available from KBC which would be better than a pad printed. Why can't I close this thread?
« Last Edit: Sat, 02 July 2011, 08:52:43 by lysol »
Offline Haes
« Reply #23 on: Sat, 02 July 2011, 17:38:33 »
i would be in for one set, if the price is right :)
Daily Driver: Filco Majestouch 2 (MX Blue) with Cherry ABS Doubleshots | Future Gaming Driver: Filco Majestouch 2 (MX Red) with Cherry ABS Doubleshots | Favorite Switches: Cherry MX Blue > Cherry MX Red  > Cherry MX Ergo Clears > Cherry MX Black > Cherry MX Brown | Interessting in: Topre Realforce , Noppoo Choc Mini & KBC Poker[/COLOR]
Offline 7bit
  • MX1A-G1DW
« Reply #24 on: Sat, 02 July 2011, 17:46:42 »
Quote from: lysol;369460
Pad printing to the sides is not that bad. Usually the keys are only touched at their top and experience shows, that keyboards almost never get cleaned until some dude paid a lot of $$$ @ ebay to get an old, used keyboard.
Did you ask for a price?
Buy key caps here: Round 5
Buy switches here: CherryMX
Offline DaemonRaccoon
« Reply #25 on: Sat, 02 July 2011, 17:48:33 »
Just want to point out that those are silver-foil stickers.
122-Key Model F 6110345 1985-03-01 | Model M SSK 1391472 1991-01-22 | Rosewill RK-9000 v1 | KBC Poker X | Filco FKBN87M/PWE2
Offline 7bit
  • MX1A-G1DW
« Reply #26 on: Sat, 02 July 2011, 17:54:20 »
Quote from: DaemonRaccoon;372146
Yes, but as far as I know, SP could not do them in silver.
^^ BTW: whodunit?
« Reply #27 on: Sat, 02 July 2011, 18:01:18 »
All I know is it was done by someone on OTD.
« Reply #28 on: Tue, 05 July 2011, 16:43:40 »
Updated OP with pad printed quote.
Offline Inverted
« Reply #29 on: Tue, 05 July 2011, 23:52:43 »
I'm interested, Ill check back soon
Keyboard: Ducky DK9000,  SteelSeries 6gv2
Mice: Razer Deathadder White, Logitech MX518
Offline reaper
« Reply #30 on: Wed, 06 July 2011, 00:17:36 »
$96.57 per set?  Man, that's a little high for a set of keycaps.
Din Eli
Offline noodles256
  • le legendary
« Reply #31 on: Wed, 06 July 2011, 01:17:33 »
Quote from: reaper~;374323
yea it is. the ones off taobao are only 5
AF | Ducky YOTD |
« Reply #32 on: Wed, 06 July 2011, 08:09:52 »
These could be that cheap too if hundreds of sets were made. Only when you can hit a certain volume does the per set price become reasonable. This price is also based on a 104 set.
Offline Waterdr1nker
« Reply #33 on: Fri, 08 July 2011, 19:00:01 »
Does anyone know if Filco sells Ninja keycaps only? or any manufacturer for that matter?
[Use] Filco Majestouch Tenkeyless Blue . Filco Majestouch 2 Tenkeyless Blue . KBT Race 75% Red
[Sold] Filco Majestouch NINJA Tenkeyless Brown . Leopold FC200R Tenkeyless Blue
Offline reaper
« Reply #34 on: Fri, 08 July 2011, 19:04:53 »
^ Filco doesn't sell them separately.  At least not yet anyway.  There are some Chinese clones on Taobao (btw, they're ABS not PBT).
Din Eli
