Author Topic: That G80-8113HRBUS you stripped the doubleshots off of.  (Read 1949 times)
Offline Mr. Perfect
  • Trade Count: (0)
« on: Tue, 28 June 2011, 21:51:22 »
Does anyone has a G80-8113HRBUS2 (the black model) that they stripped keycaps off of but left the switches on? I was thinking about getting one with lasered caps off of Ebay to fill up with group buy keys, but if anyone has a black hull going to waste I'd rather resurrect that.  It seems like most people also removed the switches from the boards, so this is more of an availability check then anything.
Mr. Perfect - A name fraught with peril.
G80-8113HRBUS MX Clears, FC200R MX Clears, RK-9000v2 MX Blues.
Offline BiNiaRiS
  • Trade Count: (0)
« Reply #1 on: Wed, 29 June 2011, 01:26:33 »
is this a keyboard you are looking at actually using? Or just something you want to hold/store your keys?
KMAC 2 w/ErgoClears
Offline Mr. Perfect
  • Trade Count: (0)
« Reply #2 on: Wed, 29 June 2011, 16:43:06 »
I'm planning on using it, so it would have to be a functional board.
If I where to buy another HRBUS(already using one at home) with Cherry double shots on it, I wouldn't be able to bring myself to remove those key caps. They're just to damn good. But, if I where to get on that was capless, or had wimpy lasered keycaps like those Ebay boards, there wouldn't be a problem. :wink:
