Author Topic: Looking for something like an HHKB  (Read 8231 times)
Offline nick125
« on: Wed, 29 June 2011, 14:36:17 »
Hey everyone,
About a month ago, I bought an HHKB Lite 2 because I really like the layout -- and I still do. However, the keys themselves aren't working for me. I find that I have a lot of trouble using my pinky with the keys, especially the left shift. When you get locked out of your computer because you end up mistyping your password 10 times, there's something wrong -- I think it's the keyboard, since I've never had that issue with other keyboards.
So, what I'm looking for is something with a similar layout to the HHKB, but with better ("lighter") keys. I was pondering the HHKB Pro 2, but I can't spend $270 on a keyboard at the moment. My budget is under-or-around $100. Any suggestions?
Offline mmmty
  • bang! bang!
« Reply #1 on: Wed, 29 June 2011, 14:39:35 »
KBC Poker
Wait! that's not a Poker. But it's still nice.
« Last Edit: Wed, 29 June 2011, 14:45:54 by mmmty »
Keyboardless
Offline Chobopants
« Reply #2 on: Wed, 29 June 2011, 14:40:57 »
I like this recommendation.
Realforce 87UW 45g - Filco Blue 87 - Filco Linear R - Filco Brown 104
Offline mmmty
  • bang! bang!
« Reply #3 on: Wed, 29 June 2011, 14:43:31 »
Probably the only option.
KBC Poker vs HHKB Pro 2.
« Last Edit: Wed, 29 June 2011, 14:46:43 by mmmty »
Keyboardless
Offline nick125
« Reply #4 on: Wed, 29 June 2011, 14:51:39 »
I'm not too terribly concerned about the key layout being exactly the same -- I'll definitely look at other "compact" keyboards that might have a slightly different layout. I'll take a look at the KBC, although it does seem hard to get a hold of one in the US. Thanks for the suggestions so far!
Offline reaper
« Reply #5 on: Wed, 29 June 2011, 14:55:00 »
Quote from: mmmty;370142
KBC Poker
^ Nice keyboard!
And that's a Leopold brown btw. ;)
« Last Edit: Wed, 29 June 2011, 15:03:18 by reaper »
Din Eli
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #6 on: Wed, 29 June 2011, 14:56:28 »
Poker is the closest, then there are ones like Noppoo Choc Mini, Siig Minitouch, TG3 aka Data911 which are compact, but not really that close.
Offline mmmty
  • bang! bang!
« Reply #7 on: Wed, 29 June 2011, 14:58:44 »
You can also look at Noppoo Choc Mini. There are also a lot of tenkeyless keyboards like the first picture.
It's not hard to get KBC Poker. There are 6 on ebay right now. You can also check GeekHack classifieds and groupbuys.
http://shop.ebay.com/i.html?_from=R40&_trksid=p5197.m570.l1313&_nkw=kbc+poker&_sacat=See-All-Categories
Keyboardless
Offline reaper
« Reply #8 on: Wed, 29 June 2011, 15:00:15 »
Yup, just so OP can get an idea...   HHKB on top and Poker on the bottom.
][/URL]
Din Eli
Offline mmmty
  • bang! bang!
« Reply #9 on: Wed, 29 June 2011, 15:01:03 »
Quote from: reaper~;370168
^ Nice!  Is it yours? =P
Haha, it's mine! the keycaps anyway. I thought it was a Filco at first but then I saw the lettering.
Keyboardless
Offline reaper
« Reply #10 on: Wed, 29 June 2011, 15:04:32 »
^ Hehe, thanks for those keycaps.  They turned out great! =)
Din Eli
Offline Input Nirvana
« Reply #11 on: Wed, 29 June 2011, 15:17:15 »
Brings me back to my thoughts of a black Kinesis with orange keys or an orange Kinesis with black keys....
