Author Topic: Tenkeyless keyboard bag  (Read 3940 times)
Offline litster
  • rare caps?! THAT'S A SMILIN
« on: Thu, 30 June 2011, 20:12:57 »
Any suggestion on purchasing a carrying bag or case that fits a Filco-sized tenkeyless keyboard?  Where can I buy one?  Thanks.
Offline reaper
« Reply #1 on: Thu, 30 June 2011, 20:20:11 »
What's your budget?  EK has them for $50 and it fits all TKL (Filco, Leopold, Realforce, etc).
][/URL]
See, Brian.  I help you sell. lol
« Last Edit: Thu, 30 June 2011, 20:25:38 by reaper »
Din Eli
Offline Akachei
« Reply #2 on: Thu, 30 June 2011, 20:41:09 »
Do you want just a keyboard bag specifically or would laptop messenger bags (would be larger) fit the deal as well?
I got one of these - http://www.buy.com/prod/jansport-modus-small-messenger-computer-brief/q/loc/16234/201526488.html - for a laptop a few years back and it fits my Filco tenkeyless very well.  Anything around the same size (for 13" laptops) should fit a tenkeyless as well, I think.
Edit: Changed link on edit because it was linking to the wrong thing.
« Last Edit: Thu, 30 June 2011, 20:54:14 by Akachei »
Offline litster
« Reply #3 on: Thu, 30 June 2011, 23:17:49 »
Thanks guys.  The EK one is nice.  Have you seen any hard cases that could fit?
Offline alaricljs
  • I be WOT'ing all day...
« Reply #4 on: Thu, 30 June 2011, 23:20:14 »
Find a pelican with the right dimensions?
edit:  nevermind, pelican doesn't make those dimensions any more... They used to have stuff in that general size.  It's a shame.
« Last Edit: Thu, 30 June 2011, 23:23:05 by alaricljs »
Filco w/ Imsto thick PBT
Offline alaricljs
« Reply #5 on: Thu, 30 June 2011, 23:29:32 »
Multi purpose? ;)
Nearest size?  $23+ship
I'm just going by interior size, and those were the closest matches I've found
Offline litster
« Reply #6 on: Thu, 30 June 2011, 23:39:31 »
Thanks again!  The plasticase one would be perfect, height and depth would work, but it is too narrow to put a tenkeyless in.  Let me dig around the that site to see if there is anything a tad larger.
Offline alaricljs
« Reply #7 on: Thu, 30 June 2011, 23:47:39 »
That's what I get for rounding to 14"  ;)
Offline litster
« Reply #8 on: Fri, 01 July 2011, 00:20:10 »
Model 612 should work; http://www.plasticase.com/productdetails.asp?node=185&country=
just a tad not enough to put 2 Filco tenkeyless keyboards.  But one would fit fine.  Let me study it some more.
Offline ironman31
« Reply #9 on: Fri, 01 July 2011, 00:38:27 »
I vote for the case from elitekeyboards. A lot better deal than the HHKB case... has a lot more pockets.
Keyboards:
IBM Model M Space Saving Keyboard (Used), HHKB Pro 2 (White, Lettered), Realforce 87U all-45g in White, Filco Majestouch 2 TKL with Cherry MX Browns, Model F PC/ATNoppoo Choc Mini (MX Browns), Model F XT, IBM Model M 1397735 (bought NIB), (2) Siig Minitouch (GHSS) one with XM, one with complicated ALPs (modded),2 Dell AT101W, Cherry G80-11900HRMUS (modded with MX browns)
Pointing Devices:
Offline litster
« Reply #10 on: Fri, 01 July 2011, 00:39:53 »
It does look nice.  ironman21, do you have one?  do you feel it have enough padding?
Offline ironman31
« Reply #11 on: Fri, 01 July 2011, 00:42:25 »
Yes. I think it has good padding. The front pocket is also big enough for my M570 and my Kindle
Keyboards:
Pointing Devices:
Offline litster
« Reply #12 on: Fri, 01 July 2011, 00:45:15 »
Maybe I will go with that.  I am not sure if I want to cut the foam in the hard case, and mess it up!
Offline ironman31
« Reply #13 on: Fri, 01 July 2011, 00:49:23 »
The only major problem I have with the bag is when I use it for my Realforce. Since I have the cable coming out the side, it either has to be bent awkwardly to fit in the case. Hopefully Realforce's lower gauge copper will prevent it from shorting out in the future
Keyboards:
Pointing Devices:
