Author Topic: Loud spacebar on a Filco tenkeyless?  (Read 3918 times)
Offline dannyboy
« on: Fri, 01 July 2011, 10:06:23 »
I just ordered my first mechanical board that I didn't just buy off a friend, a Filco tenkeyless Majestouch 2 with browns.  The keyboard is picture perfect in every way but one.  The space bar is the only key i bottom out and when i do it makes this loud hollow thump sound.  Even when I don't bottom it out it has a loud hollow thump return sound.  Well that and the backspace key rattles a bit but that is likely me simply being oversensitive.  I was wondering if all filco tenkeyless browns had this loud thumping space bar or if it is just mine and I could use any suggestions on how to fix it.  I know there is no better place to turn for keyboard help so assist me in anyway you can, it would be much appreciated.
Offline alaricljs
  • I be WOT'ing all day...
« Reply #1 on: Fri, 01 July 2011, 10:15:35 »
That's the acoustics of a large key on a plate mounted KB.  You can do all sorts of mods to attempt to soften the down stroke (dental bands or O-rings, EK sells foam pads, ... )  but I don't know of a method to soften the upstroke.  The rattling backspace can be alleviated somewhat by greasing the stabilizer bar.
Filco w/ Imsto thick PBT
Offline alaricljs
« Reply #2 on: Fri, 01 July 2011, 10:16:46 »
Oh yeah, different key caps will also modify the sound of your board.  My PBT caps (on a Filco w/ browns) are a lot softer sounding according to my wife.  The only real difference with the space bar however is that it is a deeper tone, not so much that it is quieter.
Offline Chobopants
« Reply #3 on: Fri, 01 July 2011, 11:06:26 »
Yeah, the PBTs will give is a softer clack overall. The spacebar used to bother me a tad but I'm over it. It's a solid TIME FOR ANOTHER WORD button now. :)
Realforce 87UW 45g - Filco Blue 87 - Filco Linear R - Filco Brown 104
Offline dannyboy
« Reply #4 on: Fri, 01 July 2011, 11:19:03 »
Ah, I see now so it is normal and getting a new pbt space bar should help some.  Thanks for the fast assist alaricljs and Chobopants. XD
Offline daerid
    • Rossipedia
« Reply #5 on: Fri, 01 July 2011, 12:06:20 »
I absolutely LOVE the sound of plate-mounted browns. It's actually kind of like therapy for me. My brown MJ2 isn't connected at the moment, and often I'll find myself just typing away on it to relax.
Offline SecrtAgentMan
« Reply #6 on: Fri, 01 July 2011, 12:08:12 »
Welcome to Guitar Hero ^
Offline dannyboy
« Reply #7 on: Fri, 01 July 2011, 18:15:58 »
I agree daerid, I love the sound of all the board but the too loud space bar.  As a space bar is too loud for me you can pretty well intuit how I feel about clickys lol
Offline Titmouse
« Reply #8 on: Fri, 01 July 2011, 19:52:10 »
Quote from: Chobopants;371232
That's how I feel. The "plunks" add nice punctuations to the "pluhs".
"Surprise! We threw away your old ugly keyboard and got you a brand new ergonomic keyboard from Microsoft!"  -- Findecanor
Offline daerid
    • Rossipedia
« Reply #9 on: Fri, 01 July 2011, 21:07:37 »
Although, I don't notice the difference between the normal keys and my spacebar as much on reds. Especially on the Poker. The spacebar on my Poker Red is actually almost silent.
Offline c0rbin
« Reply #10 on: Sat, 22 October 2011, 01:36:22 »
I've noticed this on all the Filco videos I've watched but not on the WASD videos. The WASD sounds more solid and less hollow in general.
Filco Majestouch-2 Tenkeyless Cherry MX Brown w/ PBT caps and O-ring mod
