Author Topic: CST L-tracx2545-5wx-rc smoothness problem  (Read 3360 times)
Offline Uberperson
« on: Fri, 01 July 2011, 14:26:22 »
Hey guys,
I am new to the forums as well as trackball mice in general. Just ordered one of these bad boys, but i am appearing to have problems with the trackball itself. When i try to move it very slowly in any direction from rest it seems to have a slight stick before it gets going. I can sort of feel it catching lightly. I cleaned the metal bearing inside with alcohol and have even tried loosening and tightening the cover, but can't seem to find a solution. Only had it for 1 day so far btw.
Thanks for any insights and help
-Uberperson
Edit: Also if i move it to the left too fast it becomes unseated momentarily.
Offline ironman31
« Reply #1 on: Sat, 02 July 2011, 15:18:35 »
Quote from: Uberperson;371426
Hey guys,
This seems to happen if you grab the ball from near the edge of the hole. It happened to me the first few days I used it, but I learned to use the top two-thirds of the ball when tracking. Now the only problem I have with the CST trackball is the unergonomic angle it makes your hand rest at. Hopefully they come out with a wrist rest sometime.
Keyboards:
IBM Model M Space Saving Keyboard (Used), HHKB Pro 2 (White, Lettered), Realforce 87U all-45g in White, Filco Majestouch 2 TKL with Cherry MX Browns, Model F PC/AT,  Noppoo Choc Mini (MX Browns), Model F XT, IBM Model M 1397735 (bought NIB), (2) Siig Minitouch (GHSS) one with XM, one with complicated ALPs (modded),2 Dell AT101W, Cherry G80-11900HRMUS (modded with MX browns)
Pointing Devices:
Offline Uberperson
« Reply #2 on: Sun, 03 July 2011, 13:50:55 »
ok, so i picked up some dry lube with PTFE in it(to avoid damaging the plastic mounts) and it is now MUCH smoother. I believe I may have removed the factory lube when cleaning it like an idiot.
Problem solved.
