Author Topic: Need a keyboard for work.  (Read 13513 times)
Offline N8N
« on: Fri, 01 July 2011, 18:15:26 »
OK, I know that this topic has probably been done to death, but I still don't see any viable off the shelf options out there.  I am definitely a devotee of the One True Keyboard, AKA the venerable IBM Model M.  I have two of them sitting next to me as I type this; I used to have one of the cool 1391401s - the original with the detachable cord - and IMHO it feels just like a keyboard should.  That one got lost in a move and that made me a very Sad Panda.  I'll probably pick up another one of these days when I go on a bourbon-fueled eBay shopping spree as I could actually tell the difference between it and the "lesser" later boards, but that's not what this post is about.
I loathe most keyboards.  The crap that passes for a keyboard that is shipped with a new PC is embarrassing and I'd rather that they just didn't send it at all because then I'm presented with the conundrum of having to discard a brand new, unused piece of equipment if I can't find some sucker to pawn it off onto.  So obviously whatever I'm given to type on at work I don't use; it sits on the shelf until someone spills coffee on their keyboard and ask me if I have any spares.  For a while I was using a Model M at work, but apparently my machine-gun typing style combined with the unique sound of the buckling spring switches drove the admins to drink (more.)  So that's not an option.  Currently a coworker, in a genuine attempt to be helpful, found a Cherry brand tenkeyless at a job site NIBN and unused; he gave it to me thinking it would be an acceptable replacement for the Model M but it just isn't.  It's a M81 series and it feels like buttered ****e.  It's evidently a quality product, but I just can't type well on it - I need the lightness and tactility that I've grown used to with my IBM boards.
Question is, what to use?  I'm currently typing this post on a Compaq MX11800 that I picked up off the 'bay just to get a feel for the Cherry Browns.  I think that this keyboard is still way too loud, as I'm constantly bottoming out on it and not "floating" like I can with the Model M.  Action is just too light (at least for what I'm used to - which means there'd be a learning curve to type more quietly on this thing,) although other than that my only quibble with it is the hideous layout of the thing - which means I'd probably like a Filco or Das Silent, but my cow orkers still wouldn't, at least until I learned to float on it, which could take a while.  I've also got a Dell AT101W coming so I can try the Alps Blacks.  Through my obsessive compulsive web searching I've discovered that the old SGI Granite keyboards are essentially a AT101 with extra rubber dampers on the key switches.  Do those really make a difference?  does anyone make them so I could retrofit an AT101W?  or would I have to actually search out a used SGI board?  (that actually would be pretty cool, as I'm sure none of my coworkers ever actually used a SGI workstation before)
Am I missing something?  Topre probably isn't in the budget, nor am I sure that I'd really like a board that *required* me to bottom out each switch.
Oh, and BTW, what the hell is up with the grey switch for the space bar on the Compaq?  The extra force required to activate the space bar compared to the alphanumeric keys is driving me ape****.  can I just replace it with another Cherry Brown?
Has anyone tried the "landing pads" from elitekeyboards on a Cherry Brown board?  Do they significantly affect the feel, or do they only come into play after you pass the tactile point?
I think what I really would like is something that felt as close as possible to the Model Ms that I know and love, just without the clickiness.  I can deal with Cherry Browns but am just concerned that if I add the landing pads that it'll mess up the feel.  I also am used to the standard 101/104 key layout so something conforming to that standard as closely as possible would be ideal.
Thanks much for any feedback...
Offline strum4h
« Reply #1 on: Fri, 01 July 2011, 18:17:32 »
My previous co-worker used a rosewill rk-9000 at work and I brought my GHSS with me one day. It was awesome when all you could hear was clicking.
OT: I use my filco with browns mostly for gaming but they really are just fantastic to type on. Also they are quiet and not very stressful on your fingers.
[SIGPIC][/SIGPIC]
Filco Tenkeyless with Browns  - SIIG minitouch GHSS
Offline sordna
« Reply #2 on: Fri, 01 July 2011, 18:33:28 »
The landing pads only affect the feel on the last .5mm of the key travel, well after the actuation point. The gray ones are ok, they black ones are thicker and affect the feel too much. I tried everything, and for me proper o-rings are the best. See my sig for the exact part number to get.
Perhaps a keyboard with cherry blues (tactile/clicky) and o-rings might be a good solution, if you don't mind the click sound. At least bottoming out will be quiet.
Offline N8N
« Reply #3 on: Fri, 01 July 2011, 18:39:10 »
I'll have to try that, thanks!  Only problem is whenever I order from McMaster I'm tempted to rummage through my drill bits, taps and dies, etc. and throw whatever is missing onto the order so I never get an inexpensive order :)
Seriously, I am def. going to try that on this Compaq... if that works then maybe a Das or Filco is the answer.  I guess nobody's ever decided for certain which of the two is better? :)  I don't think I would like a Leopold because I would miss the numpad.
I don't give a rodent's rosy red rectum about the sound.  however it apparently bothers others in the office who see my keyboard snobbery as an affectation and not simply my desire to do my job in the most efficient, comfortable manner possible...  (now I'm typing this on my laptop and that's just AWFUL!  gotta hook the M back up...)
Offline sordna
« Reply #4 on: Fri, 01 July 2011, 18:44:55 »
You could simply go down to a store and buy a Razer Blackwidow with blue switches for around $90. Lots of computer stores have them in stock. It's worth going just to try these switches out.
Offline N8N
« Reply #5 on: Fri, 01 July 2011, 18:52:26 »
I dunno... unless Best Buy (ptui) stocks 'em I don't have a really *good* B&M computer store around...  hence my searching online, buying cheap boards on the bay, etc...
Offline DaemonRaccoon
« Reply #6 on: Fri, 01 July 2011, 18:57:47 »
The last time I went to Best Buy there was a choice between Logitech chicklets and MS ergo boards. I laughed and walked away.
122-Key Model F 6110345 1985-03-01 | Model M SSK 1391472 1991-01-22 | Rosewill RK-9000 v1 | KBC Poker X | Filco FKBN87M/PWE2
Offline ch_123
« Reply #7 on: Fri, 01 July 2011, 18:58:45 »
You mention that you don't like the browns because they bottom out easily and make too much noise. You've basically described the Black Alps too :P. Cream Alps, the switches used in SGI AT101 boards dont make as much racket, but they feel kinda mushy because you're bottoming out hard onto rubber dampners. Both switches rate pretty low on the scale of things.
Cherry Clears could be an option here, if you were able to find an appropriate keyboard - they're somewhat rare.
Offline N8N
« Reply #8 on: Fri, 01 July 2011, 19:41:24 »
hmm... didn't even know there was a Cherry Clear...
http://www.alvio.com/xABK_PID713341_G80-3000LPCEU-0_cherry_lt-grey-usb-ps-2-combo-us-104-layout-mx.html&referrer=froogle
http://www.misterinterface.com/category/tags/cherry-clear
looks like this is on the table?
if it has a heavier feel with a more pronounced tactile bump than the browns that would be perfect but per the video I think it is still too loud for the orifice so I might have to do the o-ring mod...
I do have a SIIG board w/ what I believe are the black Alps (can't actually pull a key off with my fingers?) and it feels OK to me and I like the distinct tactile bump, but it's LOUD and the keys are a little wobbly...  Compaq w/ browns would be OK if it didn't make noise when bottoming, had a more pronounced tactile bump, and required a little more effort to actuate.
anyone actually have a board with the clears?  (geez, just when I thought I had a handle on this keyboard thing.)
Offline False_Dmitry_II
« Reply #9 on: Sat, 02 July 2011, 00:29:18 »
Yes, and I'm using one right now.
It CAN be difficult to find them but it isn't currently. There was a different one. I'm considering getting one of these too, just because...
I'm sure there could be other auctions, but this seller still has some.
http://cgi.ebay.com/QTY-Cherry-MX-8000-POS-PS2-Keyboard-Credit-Card-Swiper-/320722040204?pt=LH_DefaultDomain_0&hash=item4aac85f58c
I type pretty hard, so I still bottom out while typing on them so they could probably stand the o-rings to make them silent since that is the goal.
Honestly, though it sounds like either these or ergo clears (clears with brown springs. While on that subject, yeah you could totally change the spacebar one out) will be your best bet. Possibly with o-rings either way. Or both ways, if you get two of these clears.
Offline The Solutor
« Reply #10 on: Sat, 02 July 2011, 07:24:44 »
I started with the idea of going clears, but I found ergo clears a way better option, btw is easy to test what you like more when you have a clear board.
They are pretty common on cherry production, and they are available at the starting price of 40€ for the German layout and (a bit more for the us-international), in a zillion of German stores and ebay sellers .
German layout, if you need just the switches
US international (us+ euro symbol) if you need the whole keyboard
The ugly deck legend is also available in the clear variant
« Last Edit: Sat, 02 July 2011, 07:53:01 by The Solutor »
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« Reply #11 on: Sat, 02 July 2011, 07:41:22 »
I actually have TWO boards with clears - well, admittedly they're easier to come by on this side of the pond. If you're used to a Model M but need something that won't drive people crazy, they're not a bad compromise. Same force class, not as sharp tactility of course, not easily bottomed out. A bit like a scissor-switch board with some more travel tacked on.
The only thing you'll want to do is swapping out the stem and spring in the spacebar for something else (say, Scroll Lock). Piece o' cake with PCB-mounted switches as Cherry boards have them.
« Last Edit: Sat, 02 July 2011, 07:47:22 by keyb_gr »
Offline N8N
« Reply #12 on: Sat, 02 July 2011, 07:53:34 »
Thanks guys.  Ordered one of the POS boards to try out the clears.  In a week or so I ought to have a complete set of all the keyboard types I think I "might" like...  once this is over I'll likely have a massive cheap vintage keyboard sell off.  If I really like the clears I might just use the POS board @ work w/ o-rings, it's not like I really care what my cow orkers think of my sense of style (they already know it's questionable.)
Offline Tony
« Reply #13 on: Sat, 02 July 2011, 09:25:53 »
I use a Filco brown at work at leave my old Compaq MX 11800 at home.
If you find that the Compaq one too loud, then the Filco brown is even louder. Maybe you should consider a scissor switch keyboard, I think it is quieter.
Offline theferenc
« Reply #14 on: Sat, 02 July 2011, 09:34:00 »
You could get a set of dampened ALPS sliders from an Apple Extended Keyboard II. You can swap them in to the Dell quite easily, which would give you a readily available, easily useable dampened ALPS keyboard (the SGIs have issues sometimes with converters).
I actually rather like the Dell that way, personally. You could also look in to the Matias Tactile Pro: it's not as loud as the IBM and is lower pitched, but still has a satisfying click sound. The keys do have a bit of wobble to them, but that's just the nature of ALPS switches.
Personally, I'm an IBM person myself, but ALPS and Topres are not far behind in terms of feel preference. Cherry MX switches are sitting right at the bottom, for me. Just never liked them, for many different reasons.
Offline N8N
« Reply #15 on: Sat, 02 July 2011, 12:16:29 »
I'm guessing, from perusing the interwebs, that the Apple KB was only available in ADB and there's no cheap currently available ADB to PS/2 or USB adapters available?  (that is, no easy way to just hook it up to a PC running Windows or Linux and see if I like it?)
Offline mmmty
  • bang! bang!
« Reply #16 on: Sat, 02 July 2011, 12:25:44 »
Good deal on Griffin iMate ADB adapter on ebay right now. $30 shipped - http://cgi.ebay.com/Griffin-iMate-ADB-USB-adapter-/220807135637?pt=LH_DefaultDomain_0&hash=item3369218195#ht_500wt_1413
I bought one and it works fine.
You can use S-Video cable if you don't have ADB cable. Thanks, theferenc!!
http://geekhack.org/showthread.php?19144-25-Griffin-iMate-ADB-to-USB-adapter-on-Ebay
« Last Edit: Sat, 02 July 2011, 12:39:22 by mmmty »
Keyboardless
Offline N8N
« Reply #17 on: Sat, 02 July 2011, 12:36:22 »
did not know that.  still, that'd be around $70 for a keyboard (figuring a board will be $30-40 shipped)... since i seem to be buying these in bulk, I'm trying to keep the purchase prices low so that when I put 'em all back up for sale I don't lose my shirt... which reminds me, I need to get off my butt and replace the cord on the Model M... need to go get my tools out of storage.  Thanks for the tip on ADB = S-video, that's excellent to know (because I do have a pretty well stocked cable junk box, but no Apple stuff)
Offline theferenc
« Reply #18 on: Sat, 02 July 2011, 12:41:27 »
I've got an AEKII you could have for $10+shipping, if you want to give it a try. It's dirty, but it's on my list of keyboards to clean up. I paid $10 for it at a local store though, so if you're interested in it, I'm happy to just pass it along, rather than cleaning it up. That way it's only about $50, shipped, if you purchased the $30 adapter.
Let me know.
Edit: Oh, and I have an actual ADB cable for it you can have with it, as well. 2, actually, one coiled, one straight.
« Reply #19 on: Sat, 02 July 2011, 15:18:27 »
Just don't try to use an adb cable as an svid cable.
Offline N8N
« Reply #20 on: Sat, 02 July 2011, 15:48:46 »
Well thanks to theferenc it looks like I am going to have another data point to try...  so far I've got
(several) IBM Model M - buckling springs - these are perfect in every way except they are too LOUD for work.
SIIG mechanical keyboard - simplified Alps white? - this one isn't as nice as the M and is even louder, if that is possible (acceptable feel tho)
Compaq 11802 - Cherry Brown - feels OK, a little light, loud b/c I keep bottoming out on it.
On the way:
Dell AT101W - Alps Black (I hope?)
Dell QuietKey - I remember these being not too awful as far as rubber domes go.  Maybe I can live with this one.
Apple Extended Keyboard II - Alps???
Cherry POS 'board w/ clears
hopefully I will like at least one of them, and find it quiet enough, with or without o-rings, enough to use at work...!
Offline Chobopants
« Reply #21 on: Sat, 02 July 2011, 16:12:54 »
I'm surprised no one has mentioned cherry blacks in here. They're easily my quietest cherry board.
Realforce 87UW 45g - Filco Blue 87 - Filco Linear R - Filco Brown 104
Offline N8N
« Reply #22 on: Sat, 02 July 2011, 16:31:03 »
aren't blacks linear though?  I don't know that I would like that - and I would *definitely* be bottoming those out all the time.
Offline Chobopants
« Reply #23 on: Sat, 02 July 2011, 17:38:28 »
Quote from: N8N;372110
They are linear but have a LOT more resistance than browns. If you're bottoming out the browns they probably feel effectively linear to you anyway.
Offline theferenc
« Reply #24 on: Sat, 02 July 2011, 17:58:58 »
The AEK2 is ALPS, yes. Basically the same switch as in the Dell, but dampened, so quiter, with a different feel. I really like them, honestly. The only ALPS switches I like better are the ones in the Tactile Pro.
Offline N8N
« Reply #25 on: Sat, 02 July 2011, 18:09:59 »
I thought that the Tactile Pro used the same switches as the AEK2?  I'm so confused now :)
The other board that I would still like to try before I settle on a switch type is a SGI Granite...  haven't found one of those for a "don't care" price yet.
I'm switching back and forth between the Model M and the Compaq now...  I'd forgotten how loud the M was because I haven't had a proper desktop set up at home for something like six months now.  While the Compaq is loud, it's still nowhere near as loud as the M.  Maybe it'd be OK without the O-rings but I kinds doubt it... some of my coworkers are excessively whiny.
Well, anyway, I guess this thread's kinda dead for now until the next round of shipments shows up and/or I actually find a SGI board to try...
Offline theferenc
« Reply #26 on: Sat, 02 July 2011, 18:23:15 »
The Tactile Pro uses simplified Alps, rather than complicated as in the AEK2. The AEK2 and the SGI use the same switches though, as far as I know.
« Reply #27 on: Sun, 03 July 2011, 01:56:11 »
The SGI is whites with dampeners. In other words, what you'd get if you put click leaves from a focus into an AEKII. I don't think that even has an official name because of it.
Offline keyb_gr
  • Cherrified user
« Reply #28 on: Sun, 03 July 2011, 15:12:53 »
Bottomed-out MX blacks feel even heavier to me than BS.
And black Alps are bleeargh (my opinion). I guess those in my AT102DW could use a greasing job, but they feel like typing on the metal plate. Poor ol' tendons. Quite noisy, too.
Offline domin8r
« Reply #29 on: Mon, 04 July 2011, 08:02:30 »
Have a Dell AT102W at home and I kinda like the switch.. but not as much as my Model M or Laser (feel like cherry blue). And to be honoust, the Dell seems to feel best when you're typing at full speed and then it is pretty noisy actually :D
Compaq MX-11800, Ergo Clear/Brown/Ghetto Red
Ducky 1087XM
Laser SX-25 , White SMK
Black Dell AT101W
IBM Model M 1390120 (\'86)
Cherry G80-1000, Panda Clears
Offline N8N
« Reply #30 on: Wed, 06 July 2011, 16:57:07 »
another board showed up today... NOS Dell QuietKey.  (I think I paid something like $15 shipped for it.)  It's a museum piece, I can't type on it.  As I feared, it is better than most rubber domes, but I still hate it - it's got a bit of snap to it which is nice, and it's lighter than the Cherry G81, but the activation point is so low that it's really not much of an improvement.  So my old work keyboard years ago that I actually liked must have been an AT101(W) or AT102(W).
Took the Compaq board (browns) to work today - did a lot of paperwork yesterday and my hands were hurting.  Nobody complained today so maybe I was anticipating that its noise would carry farther than it actually does.  My hands feel happier, but I can't use this particular board long term because I tend to use the Delete, Home, PageUp, PageDown keys quite a bit and the non-standard locations are slowing me down.
Still waiting on a couple more to show up, guess it's going to be between Alps , browns ,and clears as to what I end up using.  So far I've only tried the browns though... come on Mr. UPS man! :)  (it'd be nice if I ended up liking the browns, 'cause a Filco is way cheaper than a Deck...  'course if I like the Alps I could just use the AT101W assuming it's not too loud.  or swap the sliders from the AEK2.)
Offline theferenc
« Reply #31 on: Wed, 06 July 2011, 19:15:53 »
The slider swap is actually pretty easy to do, it just takes patience and attention to detail. I tend to end up having to do it twice, as I realize that the sliders are in backwards...but it's still pretty nice. I prefer the AT101 to the AT101W, but I like the space between my windows key and alt (caps lock is control, control keys become windows).
Offline N8N
« Reply #32 on: Fri, 08 July 2011, 17:03:49 »
Well, two more keyboards showed up today...  the POS board with the Cherry clear switches and the AEK2 (thanks theferenc)
This is what I was afraid would happen...  so far these are the two that I like the best; and I'm going to give a slight edge to the clears.  I guess I will take the POS board to work for a couple days and see if my opinion changes; but so far I think it's The One.  (keep in mind that I am used to my Model Ms so I like a slightly heavier feel and distinct tactility.  I can actually float pretty well on the clears without any adjustment period.)
Of course, the only new, standard-layout board of which I'm aware that has clears are the Deck Legend "tactile" and the Cherry G80-3000LPCEU.  Neither one of which is particularly inexpensive.  I suppose I could swap some of the keycaps onto the POS board from my MX11800 (to get rid of the clear tops on the arrow keys, f-keys, etc.) and use it like that for a while...
Any opinions on the Cherry board w/ clears vs. the Deck?  I know the Deck is backlit, but I really could care less about that...  I'm assuming that being a "gaming keyboard" it is probably 6KRO while the Cherry is likely 2KRO.  Any other major differences in favor of spending the big bucks for the Deck?
I am still waiting for a Dell AT101W to show up, but based on the feel of the clears vs. the AEK2 I think I will likely still prefer the clears.  We'll see though.
Offline theferenc
« Reply #33 on: Fri, 08 July 2011, 17:10:08 »
The Deck is very very well built, but with an odd design of the keycaps. They often have light bleed around the seams on the top, which is kind of annoying for a lot of folks.
If you aren't going to use the backlight though, you can just swap in other key caps if you don't like the provided caps.
I'm glad you like the AEKII, though. I really like the feel of it, but it's annoying to make work on a modern system, as the adapters tend to be expensive. But you can always swap the sliders in to the Dell, as I mentioned before. The Dell, for whatever reason, often feels grittier than the Apple keyboard, even if they are the same age, and saw similar use. I assume that's due to the damping.
« Reply #34 on: Fri, 08 July 2011, 17:11:20 »
If the cherry board with clears is the one that I told you about, it has NKRO. All the ones with clear tops are like that so you can add custom labels and icons, and are all fully programmable. It even keeps whatever macros or shortcuts or whatever you assign them on the board itself, rather than in software on the computer. So as far as pure ability goes, it eats most boards alive. It just happens to be an excellent deal at the moment.
Offline N8N
« Reply #35 on: Fri, 08 July 2011, 17:26:57 »
the POS board is NKRO?  No wai!  The board that I'm typing this on right now is a G80-8200LPBUS-2 and I don't remember if it was you or not but someone on GH tipped me off to it.  It's a POS board with some extra F-keys and a credit card swiper.  Bought one of the ones on fleaBay and it jsut arrived today and I think my fingers are in love; it feels right to me and yet it is even way quieter than the browns because I'm floating much better so it's actually quite quiet even without O-rings (although those showed up today as well; but I don't think I need them on this one and may not bother trying them on the browns because those just feel too light.)  The one thing that I may try is the "tacto clears" since I have a board with browns right here and neither that one nor this one is particularly valuable.  But even so I think that I might remain a better typist with the stiffer springs of the stock clears because that's just what I'm used to.
maybe I should give this one a good scrubbing and just keep on rollin' then?  The credit card swiper does look a little odd though :)  I think I would swap some of the keycaps; e.g. the numpad doesn't have the arrows on it and that bothers me a little.  Also if I were to have custom labels on the F-keys it would not be for POS type stuff but for the AutoCAD functions (actually that's not a bad idea.  Maybe I can whip some up?)  Finally I am not nuts about the enter and pipe keys but that is a minor quibble, but my dream keyboard would use the bone stock standard IBM 101 key layout (windows and menu keys optional) because that's what I'm used to.
edit: dang, you might be right.  just opened an OpenOffice document and started holding down keys and tried about 10 different random combinations of holding keys down, each time the first six registered.  (using a PS/2->USB adapter, so I didn't expect any better.)  Not a real rigorous test, but promising.  This ain't a bad board, overall.  Still don't like the enter key but still.  For $33 shipped it makes a hell of a backup board and the credit card swiper might come in handy for my future life of crime :)  Might even make a good gaming board, I don't know, don't really game.
« Last Edit: Fri, 08 July 2011, 17:33:09 by N8N »
Offline theferenc
« Reply #36 on: Fri, 08 July 2011, 17:29:43 »
There was some review around here somewhere that had the exact dimensions and a template you could use to print the labels. I can't find it offhand. Anyone know what I'm talking about? They labeled some of the keys with the firefox logo, the pidgin logo, etc.
Edit: Found it!
« Last Edit: Fri, 08 July 2011, 17:32:42 by theferenc »
« Reply #37 on: Fri, 08 July 2011, 17:35:07 »
Yeah, it does bug me with the iso enter, but I'm willing to put up with it when I'm using it because of how much cheaper it is. I checked, and yeah, it was me.
Like I said, it's programmable. Check out this review:
http://geekhack.org/showwiki.php?title=Island:10034
The card swiper does work, it's nice to have so you don't have to type that number in when buying things of the internet.
Edit:... Stop that.
Offline theferenc
« Reply #38 on: Fri, 08 July 2011, 17:37:35 »
Hahaha, sorry Dmitry.
Offline theferenc
« Reply #39 on: Fri, 08 July 2011, 17:41:49 »
So, I was looking at it, and with it being PCB mounted, it might just be possible that we could move switches, and wire jumpers back to where they came from. Buy an ANSI enter key that is MX compatible with the correct stabilizer system, a \| key of the appropriate size, and away you go. I may have to give this a try, now that I'm thinking about it.
Offline N8N
« Reply #40 on: Fri, 08 July 2011, 17:54:24 »
well thanks!  Now I'm going to have to track down that software, I am not a *huge* fan of media keys but I'm starting to get into the idea of playing with this thing.  I think I may have found my new favorite keyboard; I'm going to have to do a back to back with a Model M to see which one wins the showdown; and there just might be a Deck in my future just to get the standard layout, but you've convinced me that I might as well give this one a bath first.  good thing it's Friday - otherwise I'd be taking this thing to work tomorrow to make my fingers happy.  Let's see if I can get all the keycaps off without busting anything - no, I don't have a key puller.  You can pull the keys off a Model M with just your fingers :)
I might also have to whip up some AutoCAD templates for the clear top keys...  since I know CAD and have a color printer available to me at work, this shouldn't be rocket surgery :)
Did I mention that I'm really, really diggin' the clears?  My roommate thinks I'm nuts - first because when his keyboard died I handed him a Model M to tide him over until he got a new one (he thought it was a clackety old tank - some people have no taste) and secondly because since I got on my mission to find an acceptable keyboard for work I now have a stack of "pre-enjoyed" keyboards taking up space on my desk...  I'll give it a few months before I do the sell off though.  He's still happy with is Microsoft rubber dome thing, and in his defense, I tried it and it feels pretty good for a RD board, but I just can't get used to a board that requires me to bottom out the keys to register them.
I do have the start of a good "try before you buy" typist's (as opposed to gamer's - I knew without trying that I didn't want any linear switches) set of keyboards.  Maybe there might be some interest in keeping the collection together as a larger, more expensive to ship version of the switch try numpad?
Please excuse the long winded reply...  I'm actually enjoying typing this all out! :)  (and I'm not making my usual clackety racket either.)  I'm actually quite glad that there's people like those on this forum that are nuts for keyboards because I would have absolutely never have found this board through normal retail channels, but it feels so much better than anything that I can remember typing on save for of course the obvious one.
Offline N8N
« Reply #41 on: Fri, 08 July 2011, 17:59:10 »
Quote from: theferenc;376482
that's a great idea.  I don't have the Compaq board in front of me to look at (left it at the office,) but I think I already saw someone mention that its keycaps were compatible...  I see a soldering iron in my future...  only downside that I see looking at pics online is that the shift keys on the Compaq look shorter, and all the non-alphanumerics on the Cherry board are grey, so I'd have an odd looking white enter key.  RIT dye it and try to match the other Cherry keys?
Alternately, I have the Cherry G81 (also at the office) with a full set of *black* keys...  are the RD Cherry keycaps MX compatible?  I haven't pulled one off to look.
Offline theferenc
« Reply #42 on: Fri, 08 July 2011, 18:07:31 »
They are compatible, and they are compatible, respectively.
Personally, I would prefer non-matching keys to the ISO enter, but that's just me, which is why I started thinking about this anyway. I had an 8113 with browns at one point, which is when I discovered I didn't like them (too light, similar to your opinion), and played with the credit card reader a few times. One cool think you can do with it, if you have access to a card writer as well, as store you login information on a random mag strip card, with a tab between user name and password. It does actually switch fields, as least on the version of redhat we have in the office. I didn't try to put a carriage return at the end, but if you could do that, you could have a swipe to login system.
I wish I could find one of these (cheaply) that had both the magstrip reader and a smart card reader. With clears, since those are the only Cherry switches worth using (to me!).
« Reply #43 on: Fri, 08 July 2011, 18:10:30 »
They aren't rubber dome, but yeah they should be. Unless it really is a rubber dome, and not just the lesser thing g81s normally come with.
Keep me updated if either of you are successful in turning it ansi. This is the one time I would care about doing so.
Speaking of, what is the condition of the clear board you got N8N? I'm more interested in permanent stuff like shiny keys instead of dirt, because I always give stuff a thorough cleaning when I get it.
Sounds like a good idea for that password thing, you could have a super long something too. I like the clears well enough, but when gaming they are too heavy because you have to hold the spring down too much.
« Last Edit: Fri, 08 July 2011, 18:12:55 by False_Dmitry_II »
Offline N8N
« Reply #44 on: Fri, 08 July 2011, 18:41:04 »
I'll have to clean it up before I can give you an idea of condition - it is kinda filthtastic.  Seriously.  But it seems to work well, and honestly, keycap condition is irrelevant to me at this point because I was really just looking to try out some switches that I had no way of obtaining other than buying keyboards.  They still have a detectable pebbly feel, if that helps any.  But I don't know if they will show visible wear after I clean them up or not.  (after I use it for a few months it will anyway...  I tend to use the sides of my pinkies a little bit, and my fingernails make women jealous - they're harder than your average keycap and I usually cut 'em at least once a week.)
I may disappear for a while and create some templates in AutoCAD.  Because that's the kind of thing that I think is cool to do.  (for the products that I deal with at work, I did sort of the same thing, although I did those in Excel because our techs don't all have AutoCAD loaded on their laptops - but in AutoCAD I can get the sizes right the first time w/o test printing and refining.)
I know, I really need to get out more.
Offline N8N
« Reply #45 on: Fri, 08 July 2011, 22:09:57 »
update: enter key is a little shiny, rest are actually not bad at all.  Still obviously used/worn though.  Doesn't bother me a bit.  Don't know if it bothers you.  I'll try to get some pics after I get it back together - still have to run case through dishwasher and don't want to power it up until everything is dry (soaked key caps to get the board chow off of them and also q-tipped around the switches w/ some windex... it was naaaaasty.)
In other news, if anyone's harvesting clears off these and has some of the clear top keys they don't know what to do with, I could use a handful of the clear bits - my roommate's cat, affectionately known as Tweedledumba$$, thought that they made spiffy cat toys and I managed to retrieve all but three of them :/  I'll hold off on posting a WTB until I verify that I didn't hork this up by cleaning it though :/
I am in fact thinking of making labels for the F-keys for the AutoCAD functions...  that would turn a weird feature into something eminently useful.
« Reply #46 on: Fri, 08 July 2011, 22:52:59 »
There are quite a few extra keys on it.
Offline N8N
« Reply #47 on: Sat, 09 July 2011, 07:42:16 »
right, but the f-key shortcuts already exist.
F1 - Help
F2 - Text Window
F3 - OSNAP
F4 - Tablet
F5 - Isoplane
F6 - Coordinates
F7 - GRID
F8 - ORTHO
F9 - SNAP
F10 - POLAR
(stolen from Autodesk's web site)
So simply making new labels for the F-keys would help quite a bit.  e.g. I use F3, F8, and F9 a lot but don't remember all the others.  And I'm old school, I hate using the buttons on the screen and Autodesk changes them every other rev anyway, I still use the keyboard a lot because I learned on R12 (I think?  may have been earlier.)  Probably back in the day they had a template that you could lay over the keyboard but I don't recall seeing one.
Anyone know how I can test the card reader w/o installing the software?  I have the bare board back together and everything works except for that; just waiting for the case to finish running through the dishwasher.  (couldn't do it last night, had a full load of dishes that needed to be run first.)
Offline theferenc
« Reply #48 on: Sat, 09 July 2011, 08:41:59 »
I think you need to install Cherry Tools to make it work in windows. In linux, I believe it just works.
Offline theferenc
« Reply #49 on: Sat, 09 July 2011, 09:11:47 »
Just to toss this out there, you could also go for some arrow keys or navigation keys, and then use the clear caps from those to replace the missing ones.
