Author Topic: KBC Poker PBT Keycaps  (Read 3107 times)
Offline REVENGE
« on: Mon, 04 July 2011, 21:08:39 »
Has anyone ordered a Poker with a "PBT" cap set? If so, did you receive an engraved set, or a Ducky style brown infilled lasered set?
Offline Dali
« Reply #1 on: Mon, 04 July 2011, 21:16:39 »
No, but now I'm curious where one could get a set of engraved or lasered keycaps for the KBC Poker?
My keyboard journey: KBC Poker X, KMAC 2, Realforce R2 PFU, F77 Model F
Offline REVENGE
« Reply #2 on: Mon, 04 July 2011, 22:40:48 »
Quote from: Dali;373492
A relative just picked up a Poker with PBT caps and Blue switches from this seller in Shanghai: http://item.taobao.com/item.htm?id=9907464470&ad_id=&am_id=&cm_id=&pm_id=
I was hoping for engraved PBT caps, but instead they are Ducky style lasered caps with brownish lettering. According to the seller, these are the currently available factory standard PBT cap set with Poker specific legends.
But anyways, Pokers turn out to be really cheap over there. You can forgo delivery fees and pay cash if you do a local pickup. That means an ABS Blue switch Poker can be had for less than $60. The engraved key caps (without Poker legends) are also really cheap.
« Last Edit: Mon, 04 July 2011, 22:43:39 by REVENGE »
Offline kaiserreich
  • HHKB Elite
« Reply #3 on: Tue, 05 July 2011, 00:07:13 »
Would you care to post pictures of the PBT versions when you get them?
Offline reaper
« Reply #4 on: Tue, 05 July 2011, 00:15:46 »
Quote from: REVENGE;373518
If your relative still there, tell them to pick up another set and I'll drive over with cash to pick it up.  =P
Din Eli
Offline REVENGE
« Reply #5 on: Tue, 05 July 2011, 02:12:48 »
Quote from: reaper~;373539
Doh! He's coming back tomorrow, so I'm not sure he'll have time to go and pickup another board. :-/ However, some more relatives might be over coming back in the next two months, so future board purchases might be doable.
Quote from: kaiserreich;373535
That's the plan!
