Author Topic: HACKING PROFESSIONAL KEYBOARD PRO KB300NL $180shipped  (Read 2886 times)
Offline BiNiaRiS
KMAC 2 w/ErgoClears
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #1 on: Tue, 05 July 2011, 17:12:20 »
Except that the early ones didn't use topre, but are rubberdomes like the lite. When you compare it to a lite ($70) it is not a good deal at all.
Offline isp
« Reply #2 on: Tue, 05 July 2011, 17:17:59 »
Well this is a "pro" KB300NL so it should be topre.
hhkb
Offline BiNiaRiS
« Reply #3 on: Tue, 05 July 2011, 17:43:42 »
Quote from: isp;373969
Correct. You can reference the model number her. It shows it as a "capacitive" model.
http://en.wikipedia.org/wiki/Happy_Hacking_Keyboard
KMAC 2 w/ErgoClears
Offline JAMM0N
« Reply #4 on: Wed, 06 July 2011, 01:31:30 »
whats the diff between this and the pro 2?
Computer: Filco Linear Cherry MX RED XBOX: HHKB Pro
Incoming: KBC Poker BROWN
Offline noodles256
  • le legendary
« Reply #5 on: Wed, 06 July 2011, 01:32:12 »
no usb ports on hhkb 1
AF | Ducky YOTD |
Offline JAMM0N
« Reply #6 on: Wed, 06 July 2011, 01:36:27 »
boo. isn't there an adapter to use it to usb? so component to usb?
Offline noodles256
  • le legendary
« Reply #7 on: Wed, 06 July 2011, 02:54:18 »
no extra usb ports
AF | Ducky YOTD |
« Reply #8 on: Wed, 06 July 2011, 15:23:37 »
My bad. I think the same seller had an older rubberdomes one up before, and I probably just assumed it was the same one.
