Author Topic: About to pull the trigger on a Filco. Advice?  (Read 5429 times)
Offline uurrnn
« on: Tue, 05 July 2011, 19:22:28 »
I've been lurking all day, and I quickly bonded to the Filco tenkeyless. I just love the way it look.
I think I've decided on cherry brown switches, because I will be playing a lot of starcraft 2 with this, and I've read that brown is a good middle ground for that.
This: http://www.amazon.com/Majestouch-2-Tenkeyless-Keyboard-FKBN87M-EFB2/dp/B004ZJPSGI/ref=cm_cr_pr_product_top Seems to be the only one I can find for sale. If you could find one cheaper somewhere else then that would be great.
I'm also assuming ninja is the closest thing they have to blank keys? I switch keyboard layouts quite a bit (used dvorak on my laptop using qwerty on this old dell kb, because I'm too lazy to switch it atm.)
Either way, I just want to get a pass by you guys or make sure I'm doing this right.
edit: I've seen filcos with a red escape key, is that just a custom key someone bought or do they sell them like that?
« Last Edit: Tue, 05 July 2011, 19:24:37 by uurrnn »
Offline daerid
    • Rossipedia
« Reply #1 on: Tue, 05 July 2011, 19:26:18 »
Advice? Do it. Honestly, they're great boards. You won't regret it.
If you want blank keys, you can always order them through The Keyboard Co, or you could get a set through one of the various group buys.
Offline uurrnn
« Reply #2 on: Tue, 05 July 2011, 19:29:57 »
I just feel like I haven't done much looking around. I'm the type of person to look at literally every piece of merchandise before buying, but I want to get this shipped before the weekend, so I'm in somewhat of a rush.
Just didn't want to end up missing a great keyboard, but I've read a lot of places that Filco are some of the best and favorite. I originally was going to get a DasK, but I like the more slim, professional look of the filco compared to the glossy, sleek look of the Das.
Offline keyboardlover
« Reply #3 on: Tue, 05 July 2011, 19:29:57 »
Welcome to Geekhack!
Here's my advice:
Offline Astounding
« Reply #4 on: Tue, 05 July 2011, 19:30:00 »
This is GH.  When it comes to Filco advice expect:
"go with the filco."
Offline mmmty
  • bang! bang!
« Reply #5 on: Tue, 05 July 2011, 19:32:27 »
Red ESC key should be included. You can also replace all the keys with engraved PBT keycaps and make it look even more blank.
Keyboardless
Offline daerid
    • Rossipedia
« Reply #6 on: Tue, 05 July 2011, 19:33:17 »
Red escape key is not included, unfortunately, when ordering from Amazon. I've ordered 3 Filcos from there, not a single red esc :(
Offline uurrnn
« Reply #7 on: Tue, 05 July 2011, 19:34:37 »
Quote from: daerid;374081
Anywhere else to order from?
Offline Titmouse
« Reply #8 on: Tue, 05 July 2011, 19:37:18 »
Elitekeyboards, or the qtan group buy if it's not closed yet.
"Surprise! We threw away your old ugly keyboard and got you a brand new ergonomic keyboard from Microsoft!"  -- Findecanor
Offline scribble
« Reply #9 on: Tue, 05 July 2011, 19:38:27 »
i just want you to consider blues :D
Filco Majestouch Tenkeyless Cherry MX Blue | PLU ML-87 Cherry MX Red
Offline BiNiaRiS
« Reply #10 on: Tue, 05 July 2011, 19:39:10 »
you could also wait 2 weeks and grab a leopold with browns and blank keys. it's initially cheaper and also saves you the hassle of having to order another set of keys. if you can't wait, you could contact leopold directly and ship one over from japan. not sure what the cost on that would be, but i don't think it is too bad.
KMAC 2 w/ErgoClears
« Reply #11 on: Tue, 05 July 2011, 19:41:03 »
Quote from: uurrnn;374083
You can always get nice doubleshot red esc keys from Signature Plastics here:
http://www.keycapsdirect.com/redesc.php
Crappy image. They look nice in real life.
« Last Edit: Tue, 05 July 2011, 19:44:04 by keyboardlover »
Offline flaming_june
« Reply #12 on: Tue, 05 July 2011, 19:45:49 »
You can always view the classified section on GH here and see if any other type of switch or keyboard you may like.  Or you can buy that above second hand.
Offline The Solutor
« Reply #13 on: Tue, 05 July 2011, 19:49:17 »
Quote from: Astounding;374078
Just from the users w/o too fantasy...
Offline uurrnn
« Reply #14 on: Tue, 05 July 2011, 19:57:04 »
Quote from: scribble;374087
Blues and browns are almost similar aren't they? I almost went with blue, but I figured brown would be better for gaming?
« Reply #15 on: Tue, 05 July 2011, 19:58:31 »
Quote from: uurrnn;374100
No...blues are clicky and tactile (you feel a click before you bottom out). Browns are non-clicky and tactile; they have a very slight bump before bottoming out.
Offline uurrnn
« Reply #16 on: Tue, 05 July 2011, 19:59:09 »
Quote from: BiNiaRiS;374088
So you're saying that the leopold is the same as a filco but cheaper?
Offline uurrnn
« Reply #17 on: Tue, 05 July 2011, 20:00:26 »
Quote from: keyboardlover;374102
Oh. I want clicky. :D
I thought browns were just less clicky. So blues are the only ones that click?
Offline calavera
« Reply #18 on: Tue, 05 July 2011, 20:01:13 »
Filco and Leopolds are virtually the same, with minor differences in key caps and case shape. But I prefer Filco.
« Reply #19 on: Tue, 05 July 2011, 20:01:37 »
Well blues aren't the ONLY switches that click. But they're the only ones on a Filco or Leopold that click.
Leopolds are similar to Filco but not exactly the same. Designed by the same guy though.
Offline uurrnn
« Reply #21 on: Tue, 05 July 2011, 20:04:40 »
Yea...if you can wait I'd probably go for that one.
Offline uurrnn
« Reply #22 on: Tue, 05 July 2011, 20:06:54 »
Should I consider anything other than brown or blue?
Offline The Solutor
« Reply #23 on: Tue, 05 July 2011, 20:11:49 »
Quote from: uurrnn;374115
Should you consider buying a good PCB mounted brown keyboard and a bunch of clear switches to quickly mod it to ergo clears and use the remaining money to have a pizza with a nice girl.
« Reply #24 on: Tue, 05 July 2011, 20:12:05 »
I don't play Starcraft so I'll let someone else handle that question...
Offline spitfire6000
« Reply #25 on: Wed, 06 July 2011, 02:10:17 »
I have that same keyboard...except the full version, filco ninja black switch linear.
I got it for 160 off amazon from the same UK keyboards vendor, they are a great retailer.
All I can tell you is this is the greatest keyboard I have ever owned, for gaming and typing as well. Black switch is much better than brown switch for gaming in my opinion, and filco is 100% worth the money. The mechanical keyboards i got before this filco ninja, I returned back once the filco came in because it really is just better in a lot of ways.
Offline winterbear
« Reply #26 on: Wed, 06 July 2011, 02:50:18 »
Quote from: uurrnn;374107
You got it right: unless you can completely master not bottoming out, the browns will click.
May I suggest to compare the sounds:
http://youtu.be/ou3O2uPLXlU
http://youtu.be/JggEpECGXn8
Incidentally, I think if you game, you might prefer the browns. There is a "togetherness" of the actuation point and the "bump" which is less confusing in a way? Personal opinion, though, don't really game.
Current:
Realforce 87U, Niz Plum Atom 68 (35g), CM Storm QF Blue
Previously Owned:
Leopold Tenkeyless Brown, Leopold Tenkeyless Blue, HHKB Pro 2 (Blank, Charcoal), Poker X Red
Offline BiNiaRiS
« Reply #27 on: Wed, 06 July 2011, 03:06:00 »
It's a pretty personal decision and whatever you choose, you may want to switch at a later date.
I went with browns and I use them for SC2. I think they are the best all around switch.
My buddy also went with browns and he is Diamond in 2s and platinum+ in the rest.
KMAC 2 w/ErgoClears
« Reply #28 on: Wed, 06 July 2011, 03:07:17 »
I had blues as my first mechanical keyboard, DO NOT GET THESE FOR GAMING! its annoying as heck when the activation point and the bump are so far apart, plus that click is annoying after a while.
Browns are okay, but i feel theyre too light and dont help much with typing since youll be bottoming them out...they are just too light. If you rest your hand on the keyboard like I do while gaming, you will press the keys down with the weight of your fingers.
This is NOT the case with blacks, I can rest my hands on the keyboard while not hitting any keys because it takes more force, and dont let anyone mislead you, blacks are totally fine to type on. In fact I find that I type faster on blacks because i have a heavier typing style.
Offline Astounding
« Reply #29 on: Wed, 06 July 2011, 03:10:28 »
Quote from: spitfire6000;374394
Why do you say blue is bad for gaming? It seems like people are split on this issue.
Offline AndrewZorn
« Reply #30 on: Wed, 06 July 2011, 03:11:25 »
I'm not trying to get too excited over my new Noppoo Choc Mini with Brown switches, which I've used for less than 1000 characters... but I'll say Brown is the best all-around, after having used many.
I tend to like some character in the keystroke for Starcraft 2. For that, I actually prefer the game-dreaded Brown to linear Red or Black. There is some truth in the Blues-for-gaming hatred, they are kind of weird for FPS and the like. It isn't the repetition, there's plenty of redundant presses in SC2. For me, it feels like I'm rolling over keys easier with a linear switch, as if the keyboard is an extension of my body and I'm just moving around on it. Games like SC2, on the other hand, have me knowing I am pushing A to make mArines, and I welcome the clickiness and keyboard feel.
Oh, and don't worry, a Brown Filco was my first. Now I know what I've been missing out on.
« Reply #31 on: Wed, 06 July 2011, 03:35:35 »
Quote from: Astounding;374395
I just didn't like it at all. When I had to double tap keys it felt really weird, and just in general it felt weird to game on...plus all the clicking was too distracting for me. I wanted to focus on the game, not be distracted by clicky noises or tactile bumps.
For me, black switch is the ultimate gaming switch. Brown is nice, but its just too light.
« Reply #32 on: Wed, 06 July 2011, 03:42:16 »
Quote from: AndrewZorn;374397
I agree 100% with this statement, and it is the reason I will always use a black switch linear. There is no reason to have a tactile bump when gaming, and for many others including myself its very distracting.
Linear is smooth and QUIET, most importantly QUIET! ^_^
If I need to, I can game at night with my girlfriend sleeping a few feet away, and not wake her up using a blackswitch linear. This was never possible when I had a blue or even a brown, as these two are much much louder than a black.
Offline Zhuni
« Reply #33 on: Wed, 06 July 2011, 03:50:21 »
Quote from: spitfire6000;374412
Are you tempted by the reds?
I prefer the blacks over the reds for FPS
[sigpic] [/sigpic]
KBC Poker
Offline uurrnn
« Reply #34 on: Wed, 06 July 2011, 06:12:06 »
Right now I'm just stuck between the leopold and the filco. My brain is telling me to wait for the leopold. It's $40 cheaper, supposed to be basically the same keyboard, and I can get blank keys ordered with it.
But my heart is telling me to just buy the filco right now. :|
Offline Zhuni
« Reply #35 on: Wed, 06 July 2011, 06:15:01 »
Quote from: uurrnn;374465
Go with the heart......otherwise it will just eat away at you till you crack :p
[sigpic] [/sigpic]
KBC Poker
Offline uurrnn
« Reply #36 on: Wed, 06 July 2011, 06:54:01 »
Yeah, I think I might just do so. I know they look almost exactly alike, but I still feel like the filco looks better.
