Author Topic: Logitech G500 gaming mouse, Best settings for 1:1 highest accuracy?  (Read 13717 times)
Offline spitfire6000
what settings do you use in setpoint to get the absolute highest accuracy when using this mouse?
I have windows driver disabled.
5 speed
0 acceleration
But this makes it so that i cant use anyhting higher than like 1600 dpi or its just too fast.
Offline Brodie337
« Reply #1 on: Wed, 06 July 2011, 06:44:15 »
Why not just use 1600 DPI?
DPI these days is basically when manufacturers unzip and say mine's bigger than yours. Pure marketing.
Offline Bilbin
« Reply #2 on: Wed, 06 July 2011, 23:37:38 »
Don't use any drivers.
Filco Majestouch Tenkeyless Blues - Razer Abyssus - PureTrak Talent
Offline Brodie337
« Reply #3 on: Thu, 07 July 2011, 03:27:18 »
Well, you can use the drivers (Logitech drivers aren't too bad), and you've set it right in terms of speed and accelleration. Just use DPI to set your speed.
« Reply #4 on: Sat, 09 July 2011, 04:45:15 »
How high can you get on dpi while using 5 speed 0 accel?
I find that at 1600 it seems just right...but anything higher is too much.
Offline Ink`Eyes
« Reply #5 on: Sat, 09 July 2011, 12:27:27 »
I run the mx518 and my roommate runs the G500. I find with both mice anything over 1600 dpi at max speed and 0 acceleration is a bit unwielding.
Offline Atenacius
« Reply #6 on: Sat, 09 July 2011, 18:33:37 »
I have mine at the default with acceleration turned off. I wasn't aware that the windows drivers aren't disabled with logitech drivers installed.
Keychron Q6 GATERON G PRO YELLOW
Vortex Pok3r CHERRY MX RED
Das Keyboard Model S CHERRY MX BLUE
IBM Model M
1391401 09 MAR 93
Offline avinin1
« Reply #7 on: Sun, 10 July 2011, 03:33:39 »
I would say 1620 [default cpi value for ADNS-9500].
Or any number in the Sequence of 90 - 450, 900, 1800 etc..
