Author Topic: 122 Key Model M  (Read 1611 times)
Offline LTR
122 Key Model M
« on: Thu, 07 July 2011, 11:03:09 »
I won what I thought was just a 108 key model M with a PS2 connector on Ebay and when it arrived yesterday it turned out to be a 122 Key model with what I believe is an AT connector. The part number is 1386887 it was manufactured on February 6, 1995. I can't find much about this anywhere else online, so maybe someone here has some info.
Will this keyboard work normally if I get the proper adapters, or is this some kind of terminal model that won't work well with Windows 7?
Thanks for any information you can provide!
Offline theferenc
122 Key Model M
« Reply #1 on: Thu, 07 July 2011, 13:06:44 »
That is a terminal board, and it can work, with appropriate changes.
Go find a post by Kishy, or PM him for the details. He is quite knowledgeable about making these work with modern systems.
There's also a teensy based adapter in the mods section to make it work, if you prefer that route.
