Author Topic: Double tapping in Cherry MX Brown  (Read 36272 times)
Offline F u r u y á
« on: Thu, 07 July 2011, 14:49:04 »
I'm looking for a new mechanical keyboard. After a few hours google'ing, I decided to choose one with Cherry MX Brown switches (its force-diagram shows very close activation and reset points, so it might be easier to double tap ( henceforth "DT")).
And that's the only thing that started to annoy me a bit in my rubber dome IBM keyboard. I'm struggling a bit to make fast DTs. So for me is really important that DT is considerably easier in a Brown switch than in a rubber dome switch (for playing StarCraft II).
  • Is the Cherry MX Brown switch good for fast double tapping?
I've also read that Browns don't provied a good tactile feedback, but I'm not too worried about that; my main concern at the moment is how it performs with DT.
Also, I measured 55.6g (56.4cN) activation force in my current rubber dome IBM keyboard and I think I will like the 20% lighter activation of MX Brown (smooth and elegant typing :cool:).
Filco 91 | Filco 87* | Filco 105 | PLU 87 | PLU 87 | Cherry 120 | Cherry 120
Offline sordna
« Reply #1 on: Thu, 07 July 2011, 15:12:19 »
Yes, brown as well as black (linear) and red (light force, linear) cherries will be easier to double tap than a blue or buckling spring switch.
Offline noodles256
  • le legendary
« Reply #2 on: Thu, 07 July 2011, 15:12:27 »
ok,
AF | Ducky YOTD |
Offline arc2
« Reply #3 on: Thu, 07 July 2011, 15:31:09 »
In my experience my linear cherry black switches are easier to accurately double tap than either my cherry browns or blues. I would go as far as to say I won't game with my brown or blue switches.
« Last Edit: Thu, 07 July 2011, 15:41:03 by arc2 »
Offline F u r u y á
« Reply #4 on: Thu, 07 July 2011, 16:09:25 »
Quote from: arc2;375584
"accurately double tap" are strong words.
I would switch my choice to MX Black if double tapping is far better in linear Cherry Blacks.
Now I'm wondering whether the tactile feedback makes any difference for RTS gaming.
The only thing that bothers me a bit about Blacks is that they have 60cN actuation point which is 10% higher than the one of my current keyboard (wanted a lighter actuation). Do you think that double tapping is really far superior in Black in comparison to Brown?
« Last Edit: Thu, 07 July 2011, 16:48:06 by F u r u y á »
Offline Chobopants
« Reply #5 on: Thu, 07 July 2011, 17:12:43 »
Check out this thread for really good advice for keys in regards to double tapping:
http://geekhack.org/showthread.php?19529-SC2-RTS-Player-wanting-choc-mini-red-or-brown-switch&p=375616&viewfull=1#post375616
I actually really dislike my Blacks for fast tapping of keys while gaming. I would never recommend them for that at all. The tacility of Browns actually does play a factor once you get used to it.
Realforce 87UW 45g - Filco Blue 87 - Filco Linear R - Filco Brown 104
Offline F u r u y á
« Reply #6 on: Thu, 07 July 2011, 17:21:33 »
Quote from: Chobopants;375657
I've just read that thread, and RayRay post convinced me for now.
Now the problem is which Brown keyboard. Currently, viable options for me (there are stores that ship to Brazil) are Das S Silent, Ducky DK 9008-G2 and ZOWIE CELERITAS. If you have other suggestions (even if you don't know a store that ships internationally) please let me know.
To be honest I don't even need that "high tech" equipment. I'm just Diamond level and my APM is not even high. But, as I said, the double tap in my current keyboard is becoming more and more annoying.
Offline The Solutor
« Reply #7 on: Thu, 07 July 2011, 17:28:08 »
Browns are good for DT , but frankly no mechanical switch can match a decent RD in this specific aspect, maybe just the leaf spring switches can give you a similar performances.
« Last Edit: Thu, 07 July 2011, 17:30:49 by The Solutor »
Offline F u r u y á
« Reply #8 on: Thu, 07 July 2011, 17:35:40 »
Quote from: The Solutor;375665
oh god :eek:
are you sure?
It looks like I'll have to discipline myself to tap not too fast.
« Last Edit: Thu, 07 July 2011, 17:38:31 by F u r u y á »
Offline The Solutor
« Reply #9 on: Thu, 07 July 2011, 17:42:19 »
Nothing is like a first person test, so don't take my opinion as an absolute truth.
But if you ask me what's better to drive off road i don't suggest Ferraris or Lamorghinis and even a say BMW X5 isn't still not a Jeep or a Hummer.
Browns are a good compromise between various factors and surely they perform better than a worn out RD even on DT side, but as any compromise they hardly win in any of the single aspects.
Offline F u r u y á
« Reply #10 on: Thu, 07 July 2011, 17:59:41 »
Yes, I liked it mainly because it has low actuation, slight tactile feedback and the actuation and reset points very close to each other.
Indeed my current RD is very worn out.
Now I'm relieved (or less concerned). :smile:
Offline noodles256
  • le legendary
« Reply #11 on: Thu, 07 July 2011, 18:35:13 »
r2d2
AF | Ducky YOTD |
Offline Chobopants
« Reply #12 on: Thu, 07 July 2011, 19:28:01 »
I'm not really sure what he's saying about double tapping honestly. I can DT just as quickly on my brown as a RD.
Offline hella
« Reply #13 on: Thu, 07 July 2011, 22:56:41 »
Quote from: sordna;375567
Contrary to popular belief double tapping can be done just as fast on a buckling spring keyboard.
Full depression and actuation force can be done in the same amount of time it takes to double tap a linear cherry switch.  I double tap at the same rate on either keyboard with the same amount of effort.
Offline The Solutor
« Reply #14 on: Thu, 07 July 2011, 22:59:54 »
And a couple of physic laws..
Offline theferenc
« Reply #15 on: Thu, 07 July 2011, 23:27:55 »
Which laws would those be, exactly? Be specific, and feel free to be technical. I have a physics degree.
If you're only pushing just past the tactile point, releasing, then pushing it past again, on a BS keyboard that's pretty easy to do. I imagine on a brown, as well, even if the tactile bump doesn't quite match actuation.
Besides, we're talking millimeter distances here. The acceleration your finger can create in that distance is pretty much the same, regardless of switch type, with the exception of rubber dome, simply because with rubber dome, you have to push all the way to actuate, and the back plate stops your travel. But you can do exactly the same thing on a mechanical switch.
Get what you think is comfortable, and you'll be fine.
Offline The Solutor
« Reply #16 on: Fri, 08 July 2011, 06:38:08 »
Quote from: theferenc;375882
I'm always technical when is needed
And there isn't the need to be Albert Einstein to understand that the mechanical hysteresis of a blue switch or a buckling spring, is higher than the one from a brown switch, which is higher than the one of a black switch or a rubber dome.
On a RD the end of the stoke is also coincident with the activation point that makes easier to feel it if compared with a black switch.
On a rubber dome you can (not so) theoretically use a vibrator on top of a key to reach 100 or 200 activations per second, this is just impossible on BS, on a Blue switch and even on a brown one, because the additional travel you have to do to activate and deactivate the contact.
On a black or red you can do it, but you have to carefully calibrate the average point, something that one can get used to, but still way more difficult that what happens on a RD
Yes the acceleration can be roughly the same, but the travel needed is not. On a RD (a membrane based RD I mean) you can close and open the contact with a travel of few microns, while on a BS we are speaking about millimiters.
This is absolutely true but was not the point discussed here.
Offline F u r u y á
« Reply #17 on: Fri, 08 July 2011, 16:22:18 »
Quote from: Chobopants;375731
I'm talking about (in SC2) going to a building through its numbered hotkey. Maybe I'm just trying to double tap too fast but anyways I want a new keyboard.
Any suggestions for Browns?
Currently I think I will go for a ZOWIE CELERITAS because they have a lot of layouts available (some are very similar to Brazilian). US layout is screwed for me because it doesn't have a key between 'Left Shift' and 'Z'.
Also, unlike Razer and SteelSeries, ZOWIE is as a gaming brand that have earned my respect and they must have a reason to pick Browns (other gaming brands put Blacks or Blues).
Offline spitfire6000
« Reply #18 on: Fri, 08 July 2011, 21:02:42 »
I completely support, agree, and also would like to reiterate this comment.
Blacks = the best hands down for gaming
Browns = decent for gaming, but are way too light imo. The tactile bump is almost nonexistant, and for gaming purposes i think its distracting and unnessesary because you will definitely bottom out a brown switch key every single time (guaranteed when gaming)
Blues = no good for gaming compared to the other 2, actuation point is too far from reset, makes double tap weird and uncomfortable. Also, imo the click of blues is distracting when gaming, as is the tactile bump.
Offline F u r u y á
« Reply #19 on: Fri, 08 July 2011, 22:15:29 »
Quote from: spitfire6000;376590
Yea, there must be also a reason for a lot of gaming brands to pick Blacks.
But, I'll be a bit stubborn here and say that that might be true for 'general' gaming or, more specifically, FPS. Perhaps Browns got some nice feedbacks from SC2 players because it's good for this specific game and it might be not that good for other games.
So, for the third time asking (and no answers so far):
Which Brown keyboard do you recommend (or do not recommed)?
Offline BababooeyHTJ
« Reply #20 on: Fri, 08 July 2011, 22:53:36 »
I can game on anything. I've played UT99 with buckling spring and cherry blue boards without any issues.
Offline False_Dmitry_II
« Reply #21 on: Fri, 08 July 2011, 23:43:59 »
I can game on anything too. But I could generally care less about double tapping. Whenever I actually need it I have no actual difficulties doing so.
As to the browns question, I'd vote for das. But then, theirs as a blue is the only modern board I've even seen (of ones listed), so that may not be accurate. I can tell you that there was some kind of thing people were complaining about the zowie for. I'd look up some of those threads before you buy if i was u.
Offline F u r u y á
« Reply #22 on: Sat, 09 July 2011, 00:06:03 »
Quote from: False_Dmitry_II;376679
I was going for ZOWIE mostly because of the layouts available. Initially I was very tempted for Das S Professional but I don't know if I can find it in layouts other than US.
Do you know if there's a store that has multiples layouts available to choose from and does ship internationally?
« Reply #23 on: Sat, 09 July 2011, 00:40:22 »
For the das? I'm pretty sure they sell just the one thing.
Offline F u r u y á
« Reply #24 on: Sat, 09 July 2011, 01:10:28 »
What about for the other brands?
Is really just ZOWIE that has different layouts option?
Offline F u r u y á
« Reply #25 on: Sat, 09 July 2011, 02:16:26 »
I've just done reading this whole thread. The main issue are that the printing wears out fast. And some reported bad space bar.
But one user has reported that the Brown switch tactile feedback is uncharacteristically sharper, and I liked that.
If there are any other issues not covered in that thread please let me know. For now I'm still sticking with it.
« Reply #26 on: Sat, 09 July 2011, 05:40:08 »
spitfire6000
« Reply #27 on: Sat, 09 July 2011, 05:44:37 »
Quote from: F u r u y á;376759
Could there really be that much of a difference between the different boards feel? I mean....the switches are all exactly the same...all made in the same Cherry factory in germany if im not mistaken. Only difference is maybe some manufacturers "cherry pick" their switches, to make sure not to get any bad ones. Otherwise...the only difference would be key caps and back plate...neither of which can make a big difference in the tactile feel of the bump.
If im wrong, correct me plz, im curious about this as well.
Offline Haes
« Reply #28 on: Sat, 09 July 2011, 08:26:45 »
srsly, i like mx blues for gaming and i know a lot of gamers who are playing with mx blues (yes, even double tapping).
if mx blues are your first mechanical keys, you get used to them while gaming. but in general i would say mx browns, blacks and reds.
if you like the feeling of a bump go for browns.
i'll buy in few weeks mx red for gaming because i like them a bit more for gaming like mx blues and i don't like the bumpy feeling of the mx browns.
but else i take mx blues all day long. but that's just me. probably if you've a chance to test some mechnical keyboards with different switches in the
electromarket like steelseries 6gv2, 7g, zowie celeritas or razer black widow - do that !
Daily Driver: Filco Majestouch 2 (MX Blue) with Cherry ABS Doubleshots | Future Gaming Driver: Filco Majestouch 2 (MX Red) with Cherry ABS Doubleshots | Favorite Switches: Cherry MX Blue > Cherry MX Red  > Cherry MX Ergo Clears > Cherry MX Black > Cherry MX Brown | Interessting in: Topre Realforce , Noppoo Choc Mini & KBC Poker[/COLOR]
Offline hella
« Reply #29 on: Sun, 10 July 2011, 01:03:48 »
While I still disagree with The Solutor I feel we're past the point now.
Furuya, if you're set on purchasing a cherry brown switch keyboard I'll give you my experiencse with the Ducky-9008.  Howver before I discuss my review I want to highlight that you wanted your brown switch to be tactially sharp.  I still believe a buckling spring keyboard would be a great choice as the tactile feedback, both the palpable click and the auditory sound occur right at the electrical actuation point of the switch.  Additionally, the spring also rebounds back very fast upon depression, faster than any cherry switch.  This, paired with easy double-tapping makes for a great keyboard.  I use an IBM Model M variation for my Starcraft II gaming.  I'm top 300 in the NA ladders if that matters.
Anyway, onto the Ducky DK-2008.  This board was slightly tactile and non-clicky and I found the tactile response to be more palpable than that of the Filco Majistouch brown keyboard.
Back to the general switch.  The electrical actuation point occurs right after the palpable feedback from pressing the key.  Double tapping is slower when fully bottoming out the key and double tapping can be done at the same speed when not bottoming out.  It took me some time to be able to double-tap this way as you have to find the point where the electrical leads connect.
The Ducky DK-2008 outperforms a buckling spring switch when quadruple (or more) tapping.  While a double tap can occur at lightning speed on either your hand will fatigue from doing triple taps on a buckling spring.  With that being said I can also double/triple tap on a buckling spring keyboard all day and be fine.  However, quadruple taps will make my hand fatigued.  If quadruple tapping is important to you I would stick with any mx-brown switch.
Build quality was excellent.  The keys were made of PCB and had a rough texture.  The keys were thick, the keyboard was solidly built, and the spacebar was mounted well.
I hope this helps you out buddy!  Hit me up if you have any more questions.  I'll be glad to help you out dude.
Offline The Solutor
« Reply #30 on: Sun, 10 July 2011, 03:18:11 »
Quote from: hella;377267
I haven't posted a single opinion in this tread, so what's the point ?
Offline TacticalCoder
« Reply #31 on: Sun, 10 July 2011, 08:26:13 »
Quote from: The Solutor;377331
Well, you have expressed the opinion that RD were better than mechanical switches with regards to double tapping.  Besides the obvious trolling, once again, about rubber domes (even though the OP specifically started his post with his first sentence saying he was looking for a new mech board), it's also just an opinion, not science.
What if there's more to double tapping than just raw speed: you may need some immediate feedback to know you actually did double tap and you also may want to know you did not triple tap.  How would RD be doing in that regard compared to, say, browns?
It's just an hypothetical question, but in the case sharp feedback is important to instantly be sure the double tap did happen or in the case that it would be important to only "double tap" and not "triple tap" (or at least get feedback as soon as possible if you triple tap so that you can "correct" your mistake) well, then, you've expressed an opinion.  One that hella and myself (and many others, but that's exactly what you're constantly looking for by constantly trolling about RD on a forum about good switches) are disagreeing with.
How, damn, I noticed the OP also wrote this latter in the thread: "one user has reported that the Brown switch tactile feedback is uncharacteristically sharper, and I liked that."
I know you have 1000+ posts (a lot being pointless trolling that said) but with regards to SC2 and with OP specifically starting his post with his first sentence stating "I'm looking for a new mechanical keyboard", I think the post made by user RayRay (who has a very low post count) will be much more helpful to him than your trolling.
RayRay said, to summarize: "I'm a 200 APM High-Master Zerg player" and "Screwed around with a few switch types, and I'm really quite fond of Browns. I got myself an oldschool Cheery NKRO Brown keyboard and haven't looked back." and "if you have no idea what switch you might enjoy (coming from a rubber dome keyboard etc) I'd say Browns."
I know it may come as a shock to you that a 130 wpm / 200 APM SC2 players would recommend browns over rubber dome but, well, it's a fact that user RayRay knows more about the issue the OP is concerned about than you do (you don't type that fast nor play SC2 at 200 APM do you The Solutor?).
Now ironically enough had you spent all the time you spent here trolling, insulting, writing logical fallacies, etc. playing SC2, you actually may have been able to help the OP choosing a good keyboard to play SC2.
Offline The Solutor
« Reply #32 on: Sun, 10 July 2011, 08:43:48 »
Quote from: TacticalCoder;377397
This is not on opinion this is a clear FACT regardless the personal likings.
The only obvious trolling here, is yours. Is not continuously mixing fanboysm and ignorance that an opinable point becomes true.
I couldn't care less if you are a mech taliban or if you don't like what I write. I write (and I will write) about facts when they are available, like in this case, and I post my opinion (no matter if you like it or not) when an opinion is needed and when there isn't a definite answer to a question.
As I did in the last 15 years in any forum that I'm registered and in any website/magazine I wrote for.
So try to learn a bit of respect for the people, (especially when they are more experienced/skilled than you), try to act as an adult w/o insulting the other users just because they don't share your (usually wrong) ideas.
Try to understand that if someone ask for a refreshing drink a cocacola is better than any brand of champagne
Is not that hard.
« Last Edit: Sun, 10 July 2011, 08:55:08 by The Solutor »
Offline ashort
  • Hoosier Daddy
    • http://andrew.wingedwheel.net
« Reply #33 on: Sun, 10 July 2011, 12:31:52 »
Wow.  You two are arguing over the best double tap key switch.  Please say that out loud, slowly, to yourself ten times.  See if it doesn't sound petty.
I guarantee that it is more than the physical properties of the switch.  Everyone's hands and fingers are different!  It is a preference built around personal experience, physiology, and how those adapt to the physical characteristics of a particular switch.   Formula 1 and some motorcycle engines, most (all?) turbine engines, and a few other things, rotate at 200+ rotations per second (in excess of 12,000 RPM if you're doing the math), but you wouldn't put any of it on top of your keyboard to help you play SC2.  God help you if you would.
No one should vilify another user for preferring a rubber dome keyboard.   My two hand surgeries cause me to never type on one when i have a choice, ever again.  I do not walk around calling my co-workers ignorant fools for continuing to use theirs. I am BAFFLED at why that kind of practice seems acceptable to some people here. Co-worker asks me about my loud keyboard, I tell them my story and I show them my operation scars. Sometimes we have fun talking about our common experiences with Vicodin and Oxycodone.
This entire forum is about people having different preferences in a keyboard switch and keyboard layout.  Not a single one makes you or I any better than anyone else. I would hope to use the opportunity to find out why you think the RD is best for you and maybe learn something from the interaction. The great thing about Geekhack is that no one (Sorry Ripster, not even you) knows everything about keyboards, we get enriched by the interaction and our collective experience.  It's a very "internet" thing.
Since RDs are the most prevalent unfortunately (I say this for ME) rubber domes frequently get a lot of the really advanced functionality that I'd not mind seeing in a Filco or Poker.  Bluetooth, for example.  I understand wanting some of them out there.
I think this topic has some warrant, albeit WAY outside my area of interest - the best SC2 keyboard?.   My kids play StarCraft 2 on an SMK-88 with black cherry switches and they have TONS of fun with it.  No one's asked me for "a better keyboard because we keep getting pwned."
I am sick and tired of the trolling, the troll accusations (which are A LOT of the problem), and the arguing over NOTHING.  Can you have a solid defensible opinion on what's a good double tap key switch, express it, read about a differing opinion, have fun discussing points and counterpoints, and move on...without name-calling or getting emotional...over a keyboard switch?
Let me respond to your "but he started it..." with this:  I don't give a ****.
BTW:  there are plenty of times when thirsty me would choose champagne (or ANYTHING with rum in it) over a Coca-Cola.
And now I'm taking my kids to the pool.
Andrew
{ KBC Poker - brown | Filco Majestouch - brown | Dell AT101W | Cherry G84-4100 }
Offline theferenc
« Reply #34 on: Sun, 10 July 2011, 12:35:50 »
Quote from: ashort;377515
Awesome stuff
Bravo, sir, bravo!
Offline The Solutor
« Reply #35 on: Sun, 10 July 2011, 13:54:57 »
That was the OP's question, so I assume you don't like both the answer and the question.
Then why post in a thread you don't like ?
It's all about personal preference, you can choose to dress a miniskirt on a marriage party, or eat spaghetti and ketchup or drink champagne after two days spent in the desert, but if someone ask I reply with the more reasonable answer.
My personal preference is for ergo clears and I not even mentioned them in this thread, because the OP asked for the better switch for DT and not about my personal preference, Is not that hard to understand.
Offline ashort
  • Hoosier Daddy
« Reply #36 on: Sun, 10 July 2011, 16:47:02 »
Quote from: ripster;377578
ANOTHER one for the In Praise of Ashort thread!
(although why my name was mentioned since I'm not even IN this thread and I say it's all personal preference what switch you choose (even rubber domes) in the Geekhack Mechanical Keyboard Guide I'll never know).
...even the "Number One Keyboard Expert On the Planet" doesn't know everything.  :D
Andrew
Offline hella
« Reply #37 on: Sun, 10 July 2011, 17:21:55 »
Lol boys, let's agree to disagree.  I was just giving my personal experiences to help the OP with his purchasing decisions.  Don't take my advice the wrong way, it's not personal.
Regardless, the original poster hasn't popped his head in here recently so there's no point to further digress from the intended topic until he returns.
« Last Edit: Sun, 10 July 2011, 17:24:44 by hella »
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #38 on: Sun, 10 July 2011, 17:52:59 »
I can double tap just fine on anything. I do prefer reds, browns, blacks, rubberdomes in that order. Rubberdomes is not as fast for me as I am a light touch, and I would rather not have to smash the key to the bottom.
Offline F u r u y á
« Reply #39 on: Sun, 10 July 2011, 21:26:31 »
Thank you for your reply, hella!
In SC2, do you often find yourself in situations where you need to triple or quadruple tap? The only situation I can't think of are macroing Terran with multiples barracks (doing the same unit), but for me the multiple tap in that situation is not as critical as going to a building or unit throught its numbered hotkey.
What do you mean with "The keys were made of PCB and had a rough texture"? That the keys are not mounted to a metal plate?
I found the actuation force of Buclking Spring too hard (harder than my current keyboard, and I wanted one a bit lighter). So I will stick with Browns. But I'm only saying that from the specs I've read, and I've never tried neither BS and Browns.
If only Ducky had alternative layouts available... but it's only US layout, right?
Offline The Solutor
« Reply #40 on: Sun, 10 July 2011, 21:32:43 »
I think is the "I'm the best typist in the world" version of PBT (Polybutylene Terephthalate) a kind of plastic.
Offline F u r u y á
« Reply #41 on: Sun, 10 July 2011, 21:37:20 »
oh, I didn't notice that there was a 3rd page.
Please keep fighting. The more fighting the more information spills out of it (as long as the subject is kept more or less the target of discussion).
:biggrin1:
Offline hella
« Reply #42 on: Sun, 10 July 2011, 23:17:16 »
I don't ever triple+ tap in sc2, dude.  However many players triple+ tap certain buttons when they have insufficient resources and are trying to build a structure or unit RIGHT when they harvest enough minerals or gas.
With regards to the keys the actual key is made of PCB, a plastic polymer.  The keys are attached the say way as all cherry switch keys.
Also, if you're looking for a soft keyboard buckling springs are going to satisfy you.  While I don't consider them hard to type on your mileage may vary.  Based on your preferences it seems that a cherry switch would better suit you.
I actually think we may need to regress away from you definitively purchasing the brown keys and a better switch may be better for you.  Do you know what type of switch you want?  Do you want something that's tactile or nontactile, and clicky, or non-clicky?
« Last Edit: Sun, 10 July 2011, 23:19:51 by hella »
« Reply #43 on: Sun, 10 July 2011, 23:38:13 »
PCB (PolyChlorinatedBiphenyl) are a group of oily liquids used chiefly as transformer oil and sometimes found in the ballasts of old fluorescent lights. Some old paints and inks also contained PCB. Like many other chlorinated aromatic compounds (like DDT), PCB is very resistant to weathering and is heat resistant. It can be metabolized in living organisms however, and can be quite toxic...
Keycaps are hopefully not made with this. I think you mean PBT (Polybutylene terephthalate), though majority of keycaps are abs (Acrylonitrile butadiene styrene).
Offline hella
« Reply #44 on: Mon, 11 July 2011, 01:03:49 »
Definitely a typo ;)
Offline Kenshin
« Reply #45 on: Mon, 11 July 2011, 02:08:42 »
Quote from: hella;377894
For all races, double taping is pretty important to quickly switch your camera view to keep a constant eye on what needs to be done, shifting back and forth between micro/macro and building things as close to zero as possible. As Zerg, you will find yourself holding keys to spawn from larva, as terran you will find yourself spamming keys to build one unit from each structure type (bad to queue as it pre-allocates resources) and spamming spawns as protoss from warpgate tech.
What's good for all of that? Currently using a Filco brown, and I feel that I've made a good choice.
Offline F u r u y á
« Reply #46 on: Mon, 11 July 2011, 05:30:05 »
I want tactile, light (less than 60g), non-clicky.
So.......
  • Is ZOWIE the only brand with UK layout avaiable?
I would get a Ducky or a Das but unfortunately they're available only with US layout (from stores I've found that ship to Brazil).
Stores that ships to Brazil:
Please let me know if you know other stores that ships internationally.
Offline hella
« Reply #47 on: Mon, 11 July 2011, 05:36:34 »
Browns sound like a good fit then buddy.   Layout specifications are not my expertise, you'll have to find someone else to help you.  Best of luck dude!
Offline skwan
« Reply #48 on: Mon, 11 July 2011, 07:55:20 »
I don't know how to make this post not look like a troll post, but purely from interest and being OCD about facts being facts, I would like to just point out a few things that i don't agree with Solutor's argument for RD being the best for DT.
He first define best as which switch has the simplest (or just have a simple) mechanism to actuate the switch repeatedly as quickly as possible.  Not how i would define it, but i see the simplicity in it, and elegance and understandability counts for something, and will go with it and explain why even if it is true RD wouldn't be best.
(As a side note for interest, a more simple one i thought up could be, just how quickly can the switch theoretically actuate repeatedly reliably, ie don't think about the external mechanism needed to actuate it, but just what the switch can do... and i think a capacitive switch would win, since there is no clattering which mech switches have... but i could be wrong, i was a physics major but focused on quant mech, so i think i can understand why i am wrong if someone bother to explain, but i am claiming no expertise in electrical circuits at all)
Using his definition, and his set up, it is much easier to create a machine that can actuate a red/brown/black repeatedly and in quicker succession than quite a few RD, simply because the dome due to the nature of the rubber, does not rebound nearly as quickly as would a spring, since it is in its collapsed state, one could build a RD that flexes harder but one could also insert a stronger spring in the switch, but i would suspect that black would simply beat most RD that exist right now simply because it bounces back faster.  I do feel that i can beat most keyboards on the upward rebound if i try (especially crappy RD, i have tried ones where it kinda stick to the bottom if i press really hard, and really messes with DT, so at least for those RD i can speak for fact that they are no good for DT), but i would be swinging my finger back up so fast, i can't come back for a second tap before the key have rebounded sufficiently, that said, i believe we need to incorporate some sort of the mechanism of the human finger in any justification for any switching being best for DT.
I believe that was his strongest argument, the rest feels less justified by firm facts, eg. Red/Brown/Black being more difficult to calibrate. Everything has a learning curve, if we are discussing what is BEST, then learning curve should not be an issue, unless you can show it is not achievable by humans, if people can not bottom out on reds, with no feedback, that means people can train their finger to reach a pretty precise spot and come back up and ride that actuation point pretty well, (i digress but it would have alot less strain on the finger because you are not smashing your finger) i would believe any method relying on feed back from the keys would be too slow anyways or at least slower than someone who have it in their muscle memory.
I am not saying Solutor is wrong in whether RD is best, but i am saying that his proof falls short of proofing that RD is in FACT the best.
I can discuss more about what i feel is best for DT, but their justification are more like my opinion, and so i await Solutor's further enlightenment and see if they assist in turning them to facts, cuz having facts back up my opinions is always good.
TL DR, according to Solutor's "proof", the bottle neck for repeated presses is most likely the upspring of the key, which IMO rubber dome would lose
Offline The Solutor
« Reply #49 on: Mon, 11 July 2011, 08:24:40 »
Quote from: skwan;378080
You are nicely dissecting the argument starting from a wrong assumption: the needs to rebound.
There's no need to rebountd.
On A RD, once you actuated the contact firstly you have just to move your finger back by a very very short travel, likely just some tenths of microns, the same happen to reactuate the contact.
And all this happen near a definite reference point represented by the bottom of the key stroke.
The tactile Cherry switches have an hysteresis (larger or smaller depending on the switch taken in account), the linear ones don't have a definite actuation point so, again can't be on par with a RD.
Then, one becomes used to everything and a cherry board cant be considered bad, but an RD is still better
« Last Edit: Mon, 11 July 2011, 09:37:14 by The Solutor »
