Author Topic: Broken black mx stabilizer holder [THEY STOCK THEM NOW!]  (Read 2719 times)
Offline LivingChampion
« on: Thu, 07 July 2011, 15:24:32 »
Not exactly sure whats it called, but when I was removing my 0 key on my numpad of my Das I accidently pulled this black stabilizer holder with the key and one of them broke right out. I was wondering what this is called and if I can get a replacement.
Pictures are not mine. Found it from a Ripster guide. Circled what I'm talking about for reference.
Thanks.
http://www.wasdkeyboards.com/index.php/cherry-mx-plate-mounted-stabilizer-clips-2pcs.html
After months of asking for it from them, they finally stock it! I'm not sure when they started, but I checked today and they are in!
« Last Edit: Sat, 21 January 2012, 15:50:30 by LivingChampion »
« Reply #1 on: Thu, 07 July 2011, 23:49:39 »
No one can even give me the name of the piece? :(
Offline bpiphany
« Reply #2 on: Fri, 08 July 2011, 00:47:15 »
Did it break or just come out? I've been asking for places to get the Costar stabilizers, but noone have come up with an answer. Keyboard retailers might sit on a few as spare parts I think though, ask where you bought the board from.
« Reply #3 on: Fri, 08 July 2011, 01:30:49 »
Quote from: PrinsValium;375926
Thanks for the reply. It broke, the piece that holds that on the board has a little broken bit to it. I think the little broken bit of it fell into the board. So I assume it's called a Costar stabilizer?
« Reply #4 on: Fri, 08 July 2011, 01:50:19 »
Well, if anyone knows where I can buy these from, please post it here or PM me.
Thanks
-Tony
Offline bpiphany
« Reply #5 on: Fri, 08 July 2011, 05:03:30 »
Quote from: LivingChampion;375982
Thanks
-Tony
No, please post it here, I want to know too!
Offline The Solutor
« Reply #6 on: Fri, 08 July 2011, 07:48:34 »
Trey to PM ascaii or half-saint, maybe they have a cheap donor board with or spare pieces.
I have just the cherry style atm.
« Reply #7 on: Sat, 09 July 2011, 18:52:51 »
I found the tiny piece of broke off of the stabilizer. Hopefully some glue will patch this baby right up.
« Reply #8 on: Sat, 09 July 2011, 20:02:38 »
Got it glued perfectly, going to let it dry the whole day. If this fails I'm probably going out to buy some super "duper" glue.
I'll try the twisties if all else fails.
Offline bluecar5556
« Reply #9 on: Sat, 09 July 2011, 20:19:55 »
Should the super glue fail, from my experience super gluing like people use duct tape, I found it helps to roughen up the pieces with sandpaper.  Stuff breaks "clean" microscopically is my guess?
« Reply #10 on: Sun, 10 July 2011, 00:06:42 »
Fixed for now. Wouldn't mind buying 2 new ones though if anyone's selling em for backups
-Tony
« Reply #11 on: Sat, 21 January 2012, 15:43:51 »
