Author Topic: cherry POS keyboard options  (Read 1297 times)
Offline N8N
« on: Sun, 10 July 2011, 06:56:12 »
saw this on the 'bay while looking for something in black
item no. 200627143306
it's a G81-8000LPCUS - idea is this.  do the MX and MY switches have the same pinout?  Could I use that board and the clears from the cheap one that's been on the bay to turn the cheap clear board into ANSI?  (or just use the whole M81 board w/ clear switches?)
I don't think I want to pay $50 plus shipping to try it though... any reason an old POS board is so expensive?
Offline Ascaii
« Reply #1 on: Sun, 10 July 2011, 06:57:13 »
simple answer...no. you cannot mount mx switches on my boards.
Offline N8N
« Reply #2 on: Sun, 10 July 2011, 07:29:07 »
figures.  I thought that maybe since the keycaps were compatible so would be the circuit boards.
I do have a perfectly good set of ANSI black doubleshots w/ nothing to use them on :/  (unless I want to type on mush)
Offline mich
« Reply #3 on: Mon, 11 July 2011, 02:04:06 »
MY switches work by pressing contacts on membranes laying below. These boards are completely different.
