Author Topic: Loose Cherry Keycap  (Read 2737 times)
Offline daerid
    • Rossipedia
Loose Cherry Keycap
« on: Sun, 10 July 2011, 14:50:17 »
So on my Poker with reds, my left Ctrl is a little loose. If I press it and let it pop up a few times, it'll pop right off the stem.
There anything quick and dirty I can do to fix this?
In practice, it's not really an issue since I don't really type that way (letting the keys snap upwards), but I'm a bit anal about stuff like this
« Last Edit: Mon, 11 July 2011, 11:18:22 by daerid »
Offline Atenacius
Loose Cherry Keycap
« Reply #1 on: Sun, 10 July 2011, 14:59:56 »
You just need a tighter joint connection between the keycap and stem. You could coat the inside of your key with something to make the opening smaller. I use to put tissue paper in toys when the joints would become loose but I don't think it will work well here
Keychron Q6 GATERON G PRO YELLOW
Vortex Pok3r CHERRY MX RED
Das Keyboard Model S CHERRY MX BLUE
IBM Model M
1391401 09 MAR 93
Offline daerid
    • Rossipedia
Loose Cherry Keycap
« Reply #2 on: Sun, 10 July 2011, 15:01:20 »
Yeah, just found out it's happening on my tab key, too :( Maybe I should just see if I can get some PBT poker caps from qtan
Edit: make that most of my keys, what the hell. KBC quality control department FAIL
« Last Edit: Sun, 10 July 2011, 15:04:00 by daerid »
Offline Atenacius
Loose Cherry Keycap
« Reply #3 on: Sun, 10 July 2011, 15:09:02 »
I wonder if it could be temperature related. Is it really hot for you right now? Also do you have the ABS or PBT keys?
IBM Model M
1391401 09 MAR 93
Offline daerid
    • Rossipedia
Loose Cherry Keycap
« Reply #4 on: Sun, 10 July 2011, 15:11:47 »
They're ABS keys, and it's sitting right next to my Filco Brown and Filco Red, both with ABS keys and don't have that issue. Plus, my Poker w/ Browns doesn't have this problem. Think it's just a bad batch.
Offline Tony
Loose Cherry Keycap
« Reply #5 on: Sun, 10 July 2011, 21:53:45 »
I suppose you do a lot of exchanging keycaps. With use, the joint connection become bigger and the keys feel loose.
Is it the right time to buy some new keycaps?
Offline daerid
    • Rossipedia
Loose Cherry Keycap
« Reply #6 on: Sun, 10 July 2011, 22:50:52 »
I'm thinking I'll buy some engraved black PBTs for it, but this was a problem before I ever pulled a single key off of it. I think it's a small manufacturing defect. No worries, I was planning on getting new caps for it anyways.
Offline IvanIvanovich
  • Mr. Silk Underwear
Loose Cherry Keycap
« Reply #7 on: Sun, 10 July 2011, 23:52:33 »
Loose cherry eh? So not a virgin after all. I got some white engraved pbt for my Poker, they are much nicer feeling than the stock by far. I also like not having all of the 2nd layer legends all over. It makes it look less busy.
Offline daerid
    • Rossipedia
Loose Cherry Keycap
« Reply #8 on: Mon, 11 July 2011, 00:01:23 »
I don't mind the busy look, and actually prefer having the legends, at least until I get used to the layout. I'm saving my white engraved for the MJ2 Brown -10key.
Offline guilleguillaume
Loose Cherry Keycap
« Reply #9 on: Mon, 11 July 2011, 07:19:16 »
This happened to me all the time on the Steelseries 7G, so annoying.
Offline hoggy
  • * Ergonomics Moderator
Loose Cherry Keycap
« Reply #10 on: Mon, 11 July 2011, 07:26:20 »
Put a tiny square of selotape (sticky side down) over the stem and refit the cap.  You'll have a harder time removing it in the future, but you can't have everything.
