Author Topic: Keyboard Cleaner from Amazon, 5 bucks...anyone tried this yet?  (Read 1159 times)
Offline spitfire6000
http://www.amazon.com/gp/product/B00006B7V9
Its only 5 bucks and covered by amazon prime...so i couldn't NOT buy it for no reason =P
Seems like a nifty little tool, anyone tried it yet?
I also ordered:
http://www.amazon.com/gp/product/B003DZ16XE
For my logitech g500 mouse. The replacement mouse feet cost 2 dollars each, and logitech charges you 6 bucks shipping...so i figured rather get these instead. G500 has 3 mouse feet, this is a pack of 20, so this should last for 6x and more replacements, nice deal for any mouse I think. You need these if you use a hard plastic gaming mousepad...like the Razer Scarab that I use at the moment.
Offline theferenc
« Reply #1 on: Sun, 10 July 2011, 22:59:34 »
It seems that it's just for cleaning the caps. Are the little prongs long enough to each around a full height key cap? They don't look like it, at least not to me. And the pictures are all of those stupid low profile things.
I think I would still rather pull them all and just use denture cleaner. Or the dishwasher, if that's more your speed.
Offline bdpq
« Reply #2 on: Mon, 11 July 2011, 00:45:54 »
Quote from: theferenc;377875
Can you clean my keyth as well while you are at it?
I usually blow it with a shopvac then scrub with an old tooth brush using Isopropyl alcohol gel (cheap!) like a tooth paste
[SIGPIC][/SIGPIC]
where the heck is green?
